#11
Richard
Arn't engines she's? Never heard anyone say 'he' quit. Big John ````````````````````````````````````````````````` On Thu, 23 Mar 2006 08:05:47 GMT, Richard Lamb wrote: Orval Fairbairn wrote: In article . net, Richard Lamb wrote: bBob wrote: After splitting the engine cases, what is recommended for resealing them? Thanks! Silk thread - on old Continentals. Make sure that you use *SILK* -- NOT nylon thread! Silk will compress, while nylon will cause fretting. Your overhaul manual should tell you how to do this. Also, use some either Hylomar (blue) or the pink Continental sealant. Pink is for girls, Orval! |
![]() "bBob" wrote in message news:eJnUf.10210$TK2.5516@trnddc07... After splitting the engine cases, what is recommended for resealing them? Thanks! I split a case recently that was nice and dry on the outside. The previous overhauler had placed two strands of silk thread on the parting flanges, one strand on the inside of the fastener holes and one strand on the outside. For the goo use Permatex Aviation Formagasket. I don't know if Hylomar is legal or not but it's great stuff too. Thin it a little with acetone. |
![]() "Orval Fairbairn" wrote in message news ![]() In article . com, "flybynightkarmarepair" wrote: here is the now superceded Mil-Product spec for this stuff: http://assist.daps.dla.mil/docimages...74/12/7194.PD9 you want type II, Class C. Manganese cure, faying surface grade polysulfide. There is now an SAE spec for this stuff, SAE-AMS-8802 Pro-Seal, beloved (not!) of many RV builders is the same chemistry, just thicker. You could use the class A stuff, and thin it with Toluene. Another poster mentioned what sounds to me like Loctite Gasket Eliminator, good for up to 200 deg Celsius. That oughta do it, and it's a whole lot easier to find than the polysulfide. Volkswagen engine builders use Gascacinch, Yamabond, and some german goo who's name escapes me at the moment to seal similar faying surfaces. Do nor use RTV to seal crankcase halves! It allows minute movement and will cause the mating surfaces to fret. According to the FAA an A&P in NC put a 6-cylinder Continental back together with RTV silicone on the studs and under the cylinder flange nuts. The engine later failed catastrophically in flight killing two in a Bonanza. One of the cylinders had departed the crankcase, apparently because the nuts backed off. |
Big John wrote:
Richard Arn't engines she's? Never heard anyone say 'he' quit. Big John ````````````````````````````````````````````````` Point taken... The Bitch! |
jls wrote:
"Orval Fairbairn" wrote in message news ![]() Volkswagen engine builders use Gascacinch, Yamabond, and some german goo who's name escapes me at the moment to seal similar faying surfaces. Do nor use RTV to seal crankcase halves! It allows minute movement and will cause the mating surfaces to fret. According to the FAA an A&P in NC put a 6-cylinder Continental back together with RTV silicone on the studs and under the cylinder flange nuts. The engine later failed catastrophically in flight killing two in a Bonanza. One of the cylinders had departed the crankcase, apparently because the nuts backed off. You know, this might address some of the VW problems as well. |
A good sealer is Loctite 515 or 518
"Richard Lamb" wrote in message ink.net... jls wrote: "Orval Fairbairn" wrote in message news ![]() Volkswagen engine builders use Gascacinch, Yamabond, and some german goo who's name escapes me at the moment to seal similar faying surfaces. Do nor use RTV to seal crankcase halves! It allows minute movement and will cause the mating surfaces to fret. According to the FAA an A&P in NC put a 6-cylinder Continental back together with RTV silicone on the studs and under the cylinder flange nuts. The engine later failed catastrophically in flight killing two in a Bonanza. One of the cylinders had departed the crankcase, apparently because the nuts backed off. You know, this might address some of the VW problems as well. |
![]() Richard Lamb wrote: You know, this might address some of the VW problems as well. --------------------------------------------------------------------------------------------------- Gee, you think so? Hahahahahahahahahahahhh... -R.S.Hoover Who was shown the 'silk thread' trick by one of the German-trained mechanics at Deet Eichel VW in Modesto, California more than fifty years ago :-) (Volkswagen was one of the first manufacturers to use gasket-less surfaces on mass-produced items.) The silk thread trick is somethng all professional VW mechanics know about - - and just another of the million things the shade-tree types have never heard of. Just make sure it sez 'pure silk.' And be careful not to use a thread that is too large. Embrodery silk is a good source. It comes as a kind of roving rather than twisted into a thread. Just cut a hank to the required length then fan out one end and strip off a FEW strands -- that's all it takes. Fly-tying thread is another good source and some find it easier to handle. Some sewing threads are simply too thick -- they will emboss themselves into the magnesium. |
![]() "bBob" wrote in message news:r5qUf.4989$hC.1856@trnddc08... "jerry wass" wrote in message ... There is a red sealant the auto atores are handling now that is even approved by faa (so I waS told) it acts like an anaerobic sealer with silicone rubber in it. forgot the number--in a red tube quite a bit higher than the other types, but well worth it. Jerry Is it like the red sealant shown here? http://tinyurl.com/znk34 Be careful with sealants on aircraft engine cases. Continental specified a single silk thread because it would compress to almost nothing and still seal the case halves. Remember, with most aircraft engines the main bearings are held by the two case halves. Anything that causes the seam to widen at all reduces the crush on the main bearings and can contribute to early bearing failure. If the case halves are true and they are properly bolted up no sealant other than the single silk thread is required. Don't mess up your main bearings trying to get the case to not leak a tiny amount. It isn't worth it. Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) A reminder, the 11th annual rec.aviation flyin that started here many years ago is coming up May 19, 20, and 21 at Pinckneyville. If you are planning to come please let Mary know at so that she can make sure to have enough steaks on hand to dinner. :-) |
![]() "Cy Galley" wrote in message news:v1JUf.841915$x96.640552@attbi_s72... A good sealer is Loctite 515 or 518 Agreed. The specs look perfect for what I need. I just snagged a couple 50 ml tubes of 515, so I'll use that. Thanks again for all the inputs. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
ROP masking of engine problems | Roger Long | Piloting | 1 | September 25th 04 07:13 PM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
