Engine case sealer?
Old March 23rd 06, 03:28 AM posted to rec.aviation.homebuilt
Default Engine case sealer?
After splitting the engine cases, what is recommended for resealing them?
Thanks!
Old March 23rd 06, 03:44 AM posted to rec.aviation.homebuilt
Thanks!
Silk thread - on old Continentals.
Old March 23rd 06, 04:12 AM posted to rec.aviation.homebuilt
In article . net,
Richard Lamb wrote:
Thanks!
Make sure that you use *SILK* -- NOT nylon thread! Silk will compress,
while nylon will cause fretting. Your overhaul manual should tell you
how to do this.
Also, use some either Hylomar (blue) or the pink Continental sealant.
Old March 23rd 06, 05:29 AM posted to rec.aviation.homebuilt
"Richard Lamb" wrote in message
ink.net...
them?
Thanks!
Thanks for the reply Richard.
I think I should have provided a few more details- we were in a rush
earlier.
I split the cases on a military aircraft gearbox for inspection. It appears
to be sealed with what we used to call 8802 (I think the proper title is
MIL-S-8802 sealant). This gearbox is for a non-aircraft project and is
exposed to high temperatures as it's nestled in the cheeks of a turbine
exhaust duct.
The lube oil supposedly reaches 180F but I think the housing may see 300F. I
think the case reaches pressures of 25 psi. The lube oil passages reach 120
psi.
I tried to locate 8802 or a substitute, without success. If you are not
familiar with 8802, when set it is like a grey colored 3M 5200 sealant. It's
a little tougher than Blue RTV.
What products should I be looking at to reseal this gearcase?
Thanks in advance.
Old March 23rd 06, 06:02 AM posted to rec.aviation.homebuilt
There is a red sealant the auto atores are handling now that is even
approved by faa (so I waS told) it acts like an anaerobic sealer with
silicone rubber in it. forgot the number--in a red tube quite a bit
higher than the other types, but well worth it. Jerry
ink.net...
them?
Thanks!
earlier.
exhaust duct.
psi.
Thanks in advance.
Old March 23rd 06, 06:10 AM posted to rec.aviation.homebuilt
"jerry wass" wrote in message
Is it like the red sealant shown here?
http://tinyurl.com/znk34
Old March 23rd 06, 06:28 AM posted to rec.aviation.homebuilt
here is the now superceded Mil-Product spec for this stuff:
http://assist.daps.dla.mil/docimages...74/12/7194.PD9
you want type II, Class C. Manganese cure, faying surface grade
polysulfide.
There is now an SAE spec for this stuff, SAE-AMS-8802
Pro-Seal, beloved (not!) of many RV builders is the same chemistry,
just thicker. You could use the class A stuff, and thin it with
Toluene.
Another poster mentioned what sounds to me like Loctite Gasket
Eliminator, good for up to 200 deg Celsius. That oughta do it, and
it's a whole lot easier to find than the polysulfide.
Volkswagen engine builders use Gascacinch, Yamabond, and some german
goo who's name escapes me at the moment to seal similar faying surfaces.
Old March 23rd 06, 06:38 AM posted to rec.aviation.homebuilt
"flybynightkarmarepair" wrote in message
polysulfide.
Toluene.
Thank you kind sir!
Old March 23rd 06, 06:50 PM posted to rec.aviation.homebuilt
In article .net,
Richard Lamb wrote:
Orval Fairbairn wrote:
In article . net,
Richard Lamb wrote:
Thanks!
how to do this.
Pink is for girls, Orval!
Or for Continentals!
Old March 23rd 06, 06:56 PM posted to rec.aviation.homebuilt
In article . com,
polysulfide.
Toluene.
Do nor use RTV to seal crankcase halves! It allows minute movement and
will cause the mating surfaces to fret.
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 01:51 AM
ROP masking of engine problems Roger Long Owning 4 September 27th 04 08:36 PM
ROP masking of engine problems Roger Long Piloting 1 September 25th 04 08:13 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 07:11 AM
