What the difference between the
Old April 3rd 07, 02:38 PM posted to rec.aviation.piloting
andrew m. boardman
Default What the difference between the
In article , Aluckyguess wrote:
So the radios are hard to work on the 480? I heard the 480 was a lot harder
to learn
I don't think "a lot" is warranted; I could figure out how to do most of
what I wanted to do on the 480 without manual-reading and found it
reasonably intuitive, though the 430 makes the basics more obvious. On
the other hand, if you want to use the full functionality of the box I
like the 480 better than the 430; I think the flight planning functions
are more logical.
Physically, the 480 has a larger screen than the 430.
I gather there are places where /G aircraft can actually get direct
clearances instead of airways, but not around here; having airways saves
a bunch of twiddling.
Old April 4th 07, 01:48 PM posted to rec.aviation.piloting
Ron Natalie
to learn
I haven't found the 480 difficult. Neither has really Margy. The
advantage for us is that we weren't tainted by having learned the
Garmin-style interface first. There's a lot of key multiplexing
due to cramming a lot of features in a tiny amount of space.
The basic is, if you want to use a non-GPS function, make sure
you press it's button first. If you want to use a GPS function,
press MAP first to get to a known state.
Old April 4th 07, 02:49 PM posted to rec.aviation.piloting
john smith[_2_]
harder to learn
The Apollo/IIMorrow systems were very logical and followed a branching
tree structure (I believe the present term is chapters and pages).
IIMorrow originally placed a diagram of structure in each manual.
Viewing the diagram made the operation and functions self-explanatory.
As the systems grew in complexity, the manuals changed and the "tree"
was no longer included. By sitting down with the manual, you can create
your own tree by diagraming the "chapters and pages" from the manual.
Old April 5th 07, 01:22 PM posted to rec.aviation.piloting
Ron Natalie
harder to learn
The MX20 quick reference certainly shows the tree. I guess you're
right about the 480 manual.
But the tree isn't all that complex.
Old April 6th 07, 03:25 AM posted to rec.aviation.piloting
John T
"Aluckyguess" wrote in message
I downloaded the simulator and the radio does have a nice function in
remembering 10 of the last radio frequencies. The 480 seems a little
similar to the Apollo 60 that is in the plane already.
There's a very good reason for that.
http://www.garmin.com/pressroom/corporate/082203.html
John T
http://sage1solutions.com/blogs/TknoFlyer
Reduce spam. Use Sender Policy Framework: http://openspf.org
____________________
KY197, KY 97 what's the Difference? Roger[_4_] Owning 17 April 12th 07 04:25 AM
What is the difference between... expresstechonsite Home Built 7 June 5th 06 03:00 PM
what a difference! Chris Piloting 3 January 12th 06 11:52 PM
Anyone know the weight difference? Lou Home Built 4 January 5th 06 09:33 PM
Another Canadian difference? Paul Tomblin Instrument Flight Rules 6 October 25th 05 04:04 PM
