Transponder Antenna Ground Planes
Old April 6th 07, 01:53 PM posted to rec.aviation.soaring
Ken Kochanski (KK)
Default Transponder Antenna Ground Planes
A friend forwarded the following study ... has anyone tested
Transponder Antenna output on a graphite ship without an additional
ground plan?
Title:
Performance of graphite epoxy as an antenna ground plane
Authors:
Erickson, J. E.; Graham, O. D.
Affiliation:
Air Force Academy, CO.
Publication:
Final Report Air Force Academy, CO.
Publication Date:
08/1978
Category:
Communications and Radar
Origin:
STI
NASA/STI Keywords:
AIRCRAFT ANTENNAS, GRAPHITE-EPOXY COMPOSITES, GROUND SUPPORT EQUIPMENT,
PLATES, ANTENNA RADIATION PATTERNS, DIPOLE ANTENNAS, IMPEDANCE MEASUREMENT,
MONOPOLE ANTENNAS
Bibl iographic Code:
1978aifo.reptQ....E
Abstract
This final report describes work undertaken by members of the Department of
Electrical Engineering at the USAF Academy, Colorado for the Post Doctoral
Program/Rome Air Development Center/Griffiss AFB, N.Y. This effort involved
a study of graphite epoxy composite material as an antenna ground plane at
the frequencies of 370 and 837 MHz. Five by five foot sheets of graphite
epoxy were provided by the Composites Laboratory of the Air Force Flight
Dynamics Laboratory at Wright-Patterson AFB. Antenna impedance and antenna
pattern measurements were made using these graphite epoxy sheets and also an
identically sized sheet of aluminum. These measurements were made with both
monopole and dipole antennas and also with a UHF blade antenna from an F4
aircraft. Results show that the 50 ply sheet of graphite epoxy behaves
identically with an aluminum ground plane when used with a monopole or
dipole receiving antenna at 370 and 837 MHz
Old April 6th 07, 02:52 PM posted to rec.aviation.soaring
"Ken Kochanski (KK)" wrote in message
ground plan?
.....Snip....
.... Results show that the 50 ply sheet of graphite epoxy behaves
50 ply! How many layers of graphite are used in the construction of the
average sailplane?
HP-14 "6F"
http://www.soaridaho.com/
Old April 6th 07, 03:07 PM posted to rec.aviation.soaring
Ken Kochanski (KK)
yeah, understood, hardly that many ... I just want to know if we have
any actual test results.
KK
Old April 6th 07, 03:40 PM posted to rec.aviation.soaring
5Z
On Apr 6, 8:07 am, "Ken Kochanski (KK)"
Standard practice for Schleicher is to install the antenna on the
ASH-26E, ASW-27, etc... just behind the main wheel. Pretty much looks
like they just drill a hole and install a typical antenna with no
other prep work.
Beyond the lack of complaints of poor performance, I don't know if
there has been any scientific testing performed to prove out the
installation.
-Tom
Old April 6th 07, 04:09 PM posted to rec.aviation.soaring
Ray Roberts
I have a stub antenna installed on the underside of my Ventus 2cM fuselage
(carbon-fiber / epoxy).
No scientific testing, but it seems to work just fine.
The high frequency electro-magnetic fields generated by transponder antennas
hardly penetrate at all into metal or graphite, so I wouldn't expect 5
layers or 50 layers to make any significant difference.
Ray
"5Z" wrote in message
other prep work.
installation.
-Tom
Old April 6th 07, 05:48 PM posted to rec.aviation.soaring
Bob Greenblatt
Notice that they stated for use as a receiving antenna. I haven't done any
studies either, but the stub antenna mounted just forward of my landing gear
on my discus 2b seems to work fine. There is no trouble in the static tests
to get it certified, and local controllers seem to "see" my reply just fine.
Bob Greenblatt
Old April 6th 07, 08:13 PM posted to rec.aviation.soaring
Bob Kuykendall
average sailplane?
Average, I couldn't say. But when we made Brad's carbon fiber HP-24
fuselage, we used the equivalent of about 5 plies at 0.010" (0.25mm)
per ply. In thickness, weight, and stiffness it came out to be about
like what the European factories do.
Thanks, Bob K.
antenna ground planes [email protected] Home Built 12 November 4th 05 11:30 PM
VHF & Transponder antenna Steve Home Built 1 December 6th 04 04:29 PM
Oil on transponder antenna Bob Owning 12 May 9th 04 08:59 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
Wanted: Transponder antenna Grandpa B. Home Built 22 November 28th 03 08:03 AM
