VOR approach SMO
Old July 23rd 07, 09:23 PM posted to rec.aviation.piloting,rec.aviation.ifr
Robert M. Gary
Default VOR approach SMO
On Jul 23, 12:17 pm, "karl gruber" wrote:
I see no problem with the weather 800/3 as you point out. Inside BEVEY drive
down to 680 outside CULVE, and have 3 miles to descend 505 feet. Any jet
will do that all day long.
No, you misread the chart. It is not 3 miles from CULVE, its about 1/2
that. The distances you are looking at are *NOT* the distances to the
threshold, those are to the DME, on the other side of the field.
-Robert
Old July 23rd 07, 09:25 PM posted to rec.aviation.piloting,rec.aviation.ifr
Robert M. Gary
On Jul 23, 1:18 pm, "karl gruber" wrote:
Where are you digging up such erroneous thoughts?
With 800/3 you'll be way outside CULVE when you see the runway.
No, with 800 foot ceiling you will be at 1120 when at CULVE, making it
hard to see the runway through the clouds.
-Robert
Old July 23rd 07, 09:28 PM posted to rec.aviation.piloting,rec.aviation.ifr
Hamish Reid
Roy Smith wrote:
"Robert M. Gary" wrote:
The other day I shot the VOR approach into SMO for the first time in
low actual. I've often looked at that approach as one of the most
difficult I've seen published
Why do you think this is difficult? The only thing I see that's tricky
about it is that you need to keep up a steep descent (360 ft/nm from DARTS
to the threshold, and about 500 ft/nm from CULVE to the threshold, by my
calculations), but that's just a matter of energy management.
Indeed. The only time I've done that approach for real (in marginal VMC
through a thin layer of stratus) SoCal vectored me well inside DARTS at
6,000' in a 172, which is SOP, apparently. Energy management's
definitely the key in a situation like that -- there's a reason I've
heard it called the "Santa Monica Slam" -- but dropping like a rock like
that would surely take a bit of faith in hard IMC....
The other point is that you're on an approach with a lot of faster
aircraft behind you, and I'm sure the temptation is to keep going like a
bat out of hell right up until the MDA, at which point you don't have a
lot of time and space to slow down. That hasn't happened to me, but I
can understand why it might. I was asked for best forward speed all the
way from somewhere out near OHIGH to CULVE. But it was VFR below the
stratus, and I knew my way around...
Hamish
Old July 23rd 07, 09:36 PM posted to rec.aviation.piloting,rec.aviation.ifr
Hamish Reid
So you'd drop below 1120 *outside* CULVE? Even if you were just cutting
things a little fine, the 2.4 miles from CULVE is from the *far end* of
the runway you're landing on... and if you were descending below 1120
just inside BEVEY in IMC, you might be in more trouble than you'd like.
Hamish
Old July 23rd 07, 10:07 PM posted to rec.aviation.piloting,rec.aviation.ifr
pgbnh
I think all but one of the posters have missed the fact that the MDA is not
1120 but 680. If indeed the vis was 3 miles, then the runway should have
been in sight from the MDA of 680 feet about a mile OUTSIDE of Culve.
(Remember what you can do once you have the runway in sight????) At which
point it's not a particularly big deal to lose 500 feet to land on the
numbers. Maybe even crossing Culve at 3-400 feet agl.
"Hamish Reid" wrote in message
drive
Hamish
Old July 23rd 07, 10:09 PM posted to rec.aviation.piloting,rec.aviation.ifr
karl gruber[_1_]
No, the VIS is 3. It doesn't matter where the VOR is. You can be at 680 6.7
miles out. When you are 3 miles from the AIRPORT, it will be in sight.
Karl
No, he's right. The VOR (and therefor the DME readings) are on the
*OTHER* side of the runway. So the distance from CULVE to the
threshold is pretty short, and creates a pretty wild let down from
1000 feet.
-Robert
Old July 23rd 07, 10:10 PM posted to rec.aviation.piloting,rec.aviation.ifr
karl gruber[_1_]
Not with DME, you'll be at 680 far before CULVE.
Karl
-Robert
Old July 23rd 07, 10:12 PM posted to rec.aviation.piloting,rec.aviation.ifr
karl gruber[_1_]
No.
You can be 6.7 miles out at 680/DME.
Karl
Read and UNDERSTAND the chart
drive
-Robert
Old July 23rd 07, 10:15 PM posted to rec.aviation.piloting,rec.aviation.ifr
karl gruber[_1_]
Once inside BEVEY you're good for 680. There is no glideslope and it's "Dive
and Drive." That's why the pros make it in with no trouble, they can read
charts.
Karl
Karl
drive
Hamish
Old July 23rd 07, 10:18 PM posted to rec.aviation.piloting,rec.aviation.ifr
karl gruber[_1_]
Thanks!!!!!!!!!!!
Karl
"pgbnh" wrote in message
news
drive
Hamish
VOR approach SMO Robert M. Gary Piloting 124 August 3rd 07 02:17 AM
first approach in IMC G. Sylvester Instrument Flight Rules 10 July 12th 05 02:14 AM
No FAF on an ILS approach...? John Harper Instrument Flight Rules 7 December 24th 03 03:54 AM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
Brief an approach Ditch Instrument Flight Rules 11 October 14th 03 12:10 AM
