Minumum Sink Rate/Best L/D at 17,000 feet ?
Old April 12th 09, 02:26 PM posted to rec.aviation.soaring
Jack[_12_]
Default Minumum Sink Rate/Best L/D at 17,000 feet ?
Andy wrote:
You'll need to define how height and altitude
are independent.
Height = AGL
Altitude = above MSL
Jack
  #42
Old April 16th 09, 05:13 AM posted to rec.aviation.soaring
On Apr 12, 8:26*am, Jack wrote:
Andy wrote:
* You'll need to define how height and altitude
are independent.
Height = AGL
Jack
My understanding is NO. Here's an example:
On the CRJ at 10,000 feet best L/D is 170 kias......then at the same
weight and ISA deviation and flap setting, stall speed at 41,000 feet
is 173. So if you pitched for best L/D for 10,000 at an altiude of
41,000 feet you would stall the airplane. I know this because I have
studied in great detail flight 3701. Those pilots just a few years
ago, stalled the crj at 41,000 feet at 173 knots. Then they glided
the 50 seat passenger jet into a neighborhood in the middle of the
night. The plane exploded and both pilots died. No passengers aboard
the flight. It was a reposition. Very sad day.
KIAS stall speed changes with altitude....so does L/D KIAS.
  #43
Old April 16th 09, 11:01 PM posted to rec.aviation.soaring
Mats Henrikson (test account)
41,000 feet you would stall the airplane. *I know this because I have
studied in great detail flight 3701. *Those pilots just a few years
ago, stalled the crj at 41,000 feet at 173 knots. *Then they glided
night. *The plane exploded and both pilots died. *No passengers aboard
the flight. *It was a reposition. *Very sad day.
I think you'll find that you are confusing KTAS and KIAS. The NTSB
investigation of Pinnacle Flight 3701 is he
http://www.ntsb.gov/Publictn/2007/AAR0701.pdf
See section 1.16.1.2, footnote 54, saying all airspeeds are in KCAS
(which is basically KIAS). Section 1.16.1.3 para gives the best L/D of
170 KCAS. It doesn't say anything at which altitude that was, because
L/D given in KCAS doesn't change with altitude.
I find that flying at 1,000 feet and 20,000 feet my glider will stall
at the same KIAS, you should try it yourself.
Question: Standard rate turns, constant rate turns, and airspeed Robert Barker Piloting 5 April 15th 07 04:47 PM
My weird sink drain AES Piloting 11 April 13th 06 10:17 AM
will the CBS forgeries sink Kerry? Cub Driver Military Aviation 3 September 14th 04 12:12 AM
Rounding a turnpoint in sink CV Soaring 13 July 22nd 04 05:27 PM
