Becker AR3201
Old March 24th 13, 11:54 AM
Lazarost Lazarost is offline
Junior Member
First recorded activity by AviationBanter: Mar 2013
Default Becker AR3201
Hi to all.
I'm electronic technician and i start to repair some equipments for gliders and planes.So i have a problem with a Becker AR3201. The problem is when you press the PTT to talk or you receive a signal you hear at the headset or at the speakers a noise like the noise from alternator. I try to install a power line filter but without any success. I try with the engine not running (only with the battery) and the problem is still presents.
Any idea what happen ???
Thanks for any help.
Lazaros Greece
Old March 25th 13, 10:48 AM posted to rec.aviation.soaring
David Salmon[_2_]
At 10:54 24 March 2013, Lazarost wrote:
Hi to all.
presents.
Lazaros Greece
Lazarost
I know next to nothing about radios, but could it be that the squelch needs
turning down? On the 3201 there is an adjustment screw that you get at
through the lowest of 3 holes in the RH side of the casing.
Dave
Old March 25th 13, 04:21 PM posted to rec.aviation.soaring
Check your grounding. Noise in radios is generally caused by poor grounding paths. Run a separate lead from the radio ground to the negative of the battery. If it clears it up then you should troubleshoot the grounding lead. Good luck.
Old March 26th 13, 07:16 AM
Junior Member
Quote:
Yea i start first with the grounds and for any broken joints.
I place the unit on my desk and checking with a microscope for any damage.
So if i find something i post it here for reference to all.
Thanks for everything !!
Becker AR3201 [email protected] Soaring 4 April 7th 09 12:15 AM
AR3201 Harness? noel.wade Soaring 13 March 10th 09 03:23 PM
Wanted: Becker AR3201 Ira Blieden Soaring 0 December 14th 06 07:28 PM
Looking for a Becker AR3201 Ira Blieden Soaring 0 December 8th 06 02:38 PM
Problems with Becker [email protected] Soaring 6 August 26th 05 10:33 AM
