Becker AR3201
Old March 25th 13, 04:21 PM posted to rec.aviation.soaring
Default Becker AR3201
Check your grounding. Noise in radios is generally caused by poor grounding paths. Run a separate lead from the radio ground to the negative of the battery. If it clears it up then you should troubleshoot the grounding lead. Good luck.
Becker AR3201 [email protected] Soaring 4 April 7th 09 12:15 AM
AR3201 Harness? noel.wade Soaring 13 March 10th 09 03:23 PM
Wanted: Becker AR3201 Ira Blieden Soaring 0 December 14th 06 07:28 PM
Looking for a Becker AR3201 Ira Blieden Soaring 0 December 8th 06 02:38 PM
Problems with Becker [email protected] Soaring 6 August 26th 05 10:33 AM
