Glider for heavy Pilot
Old March 22nd 21, 02:07 PM posted to rec.aviation.soaring
Tango Whisky
Default Glider for heavy Pilot
Tha Caproni Calif A21S will do that. No limits on the belts, just a max total cockpit load (typically around 400 lb). As it is a side-by-side, CoG is not an issue.
Le dimanche 21 mars 2021 Ã* 14:55:24 UTC+1, Hank Nixon a écritÂ*:
We are looking at what gliders may be suitable for heavy pilots. Gross weight, max mass of non lifting components, and forward CG limits. Subject pilot weighs 280 lb.
Ant experience out there?
Thx
UH
Old March 22nd 21, 08:18 PM posted to rec.aviation.soaring
AS
Not an issue is not quite true but it has far less of an influence when compared to a conventional tandem seat configuration. The seats are still a little bit ahead of the CoG.
Uli - Calif-wrangler
'AS'
Old March 22nd 21, 10:07 PM posted to rec.aviation.soaring
I have an opportunity to buy a glider with a parachute, both of which are weight limited. That’s all the motivation I need ... diet started .... 40lbs to go!
Old March 23rd 21, 01:00 AM posted to rec.aviation.soaring
2G
Here a couple of possibilities:
1. Put him in a 2-seater solo.
2. Get a DG400 and remove the engine (this requires a new weight & balance and likely adding lead weight in the tail.
Tom
Heavy pilot - what glider to opt for? [email protected] Soaring 53 April 7th 14 04:38 PM
Hangar dolly for heavy glider Dave Nadler Soaring 20 May 29th 13 05:49 PM
Glider pilot and ME 163 Komet Pilot Rudy Opitz Has Died Paul Remde Soaring 5 May 12th 10 12:56 AM
ETA glider landing with heavy front wind in Rieti, videoclip PCool Soaring 2 October 1st 09 03:10 PM
Heavy pilot & lead in tail Flyhighdave Soaring 8 January 4th 04 01:28 AM
