polyurethane finishes
Old April 18th 21, 05:47 PM posted to rec.aviation.soaring
Default polyurethane finishes
Hi all,
I just purchased a glider with a factory PU finish. I'd like to know more about them, including:
- best practices for maintenance
- failure modes
- method for repairing minor dings etc.
- causes of wear and tear
I am pretty familiar with gelcoat but know very little about PU.
Thanks,
Matt
Old April 19th 21, 12:53 AM posted to rec.aviation.soaring
John Sinclair[_5_]
On Sunday, April 18, 2021 at 9:48:01 AM UTC-7, wrote:
Hi all,
- failure modes
Thanks,
Mat
Hi Matt,
First off, there are lots of urethanes available, but the one used by factory is Acrylic Urethane and it is an unbelievable great finish............with one notable exception! It will blister if left in an closed trailer too long! My bird is 20 years old and the finish looks as good today as the day it was produced, but it spends its Winters inside its trailer which is inside my barn! If you are unable to get inside storage, I’d recommend opening your trailer every month, even if you don’t fly, let the damp trailer dry out!
As for upkeep, I wax her every Spring and buff and wax it every other year.........changing the transition tape after buffing, but before new wax is applied.
AU remains ever so slightly flexible and won’t crack. Scrapes can be filled, sanded, primed and painted in a conventional manner. Color match can be a problem, but several manufacturers use an auto paint color, so exact match can be ordered...........Most will not use any “tint”, so specify “no tint” in most cases.
Hope this helps,
JJ
Old April 19th 21, 10:49 AM posted to rec.aviation.soaring
Hi Matt,
As for upkeep, I wax her every Spring and buff and wax it every other year........changing the transition tape after buffing, but before new wax is applied.
Hope this helps,
JJ
The blistering is so irritating. A friend refinished his Phoebus in AU and experienced blisters in area of the fuselage dolly. We suspect that was caused by water leaking through a seam in his trailer roof getting the dolly wet. This happened is a short time during the summer since he stored the glider out of the trailer in a heated garage during the winter. I have also seen blistering on an SZD Junior horizontal stabilizer trailing edge (not the elevator), seeming from moisture entering the sharp edge ( never in a trailer but always in a hangar.) There are also many accounts of cars being refinished in urethanes and experiencing blisters while in storage under car covers, even in barns, in some cases fairly soon after painting and in other cases 20 years later! Just when we thought urethanes were the answer! I suspect in all cases it comes down to proper application.
Old April 19th 21, 01:11 PM posted to rec.aviation.soaring
This sounds good! I will make sure the plane stays dry. It is 18 years old and looks brand new. It's been stored in a trailer in a garage and has not flown much. I will keep it assembled in a t-hangar where water should not be an issue.
Old April 19th 21, 03:58 PM posted to rec.aviation.soaring
Christoph Barniske
Urethane finishes are less prone to cracking and do not change their color over the years. They are in general more durable than Polyester. But cracks in the underlying laminate are more difficult to spot. In case of repairs, you will need to make sure the surface is flat before applying the final coat. Colors can be matched more easily than with T35 and small repairs are easy to do. Sanding requires high quality materials, but they easy to polish unless they contain too much softening agent. An urethane finish definitely worth the extra money when buying a new glider.
Blistering occurs with Polyester and Urethane finishes if the surface has been wet-sanded and not dried properly before the final coat is applied.
Christoph
Old April 19th 21, 07:34 PM posted to rec.aviation.soaring
Christoph
You say that with some sense of authority but I have seen urethanes blister when they either were not wet sanded at all or only wet sanded on the final coat. I’m also sure the SZD factory knows what they are doing and yet that one is blistering too!
Old April 19th 21, 07:51 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
The process details and products on this page
http://www.craggyaero.com/ventus.htm
Held up extremely well on my wings done 20 years ago. The glider was out in the sun from April to Oct in Northern California and in a trailer outside all winter. No blister etc.
The page above details the refinish of the fuselage, it was also done 20 years ago with PolyFiber waterborne polyurethane that did not hold up at all.
The acrylic urethane used on the wings and the refinish of the fuselage was PPG JAU Direct Gloss Acrylic Urethane Shopline, 1/2 the price as the expensive stuff.
Richard
www.craggyaero.com
Sailplane Finishes Buba Smith Soaring 7 December 27th 11 03:40 PM
UK Contest Finishes johngalloway[_2_] Soaring 1 September 1st 11 02:28 AM
Polyurethane finish? Uniform Zulu Soaring 5 February 7th 08 07:32 AM
competition finishes Derek Ruddock Soaring 7 February 13th 07 01:00 PM
GP finishes bagmaker Soaring 0 May 25th 06 12:11 AM
