Quite a few mechanics and quite a few shops tend to shy away from the
"pre-buy" inspection for one main reason. There are a gazillion items that can be inspected to a fare-thee-well and wind up being unairworthy next week. Then you come back to me and ask me why I didn't find this glaring problem on the pre-buy and expect me to fix it for free. Example -- on July 20th last year I did an annual on a 182. I found a couple of minor things wrong, fixed them, and signed off the annual. Two weeks later that aircraft split a cylinder in two in flight and had to make a forced landing in a cow pasture. Now the question becomes -- how could I have detected this fault by inspection? Perhaps if I had removed all the cylinders and taken them down to be nondestructively tested (mag particle, zyglo, etc.) we might have spotted that incipient crack. We might not have. But that's not reality. Pulling the jugs on every annual (and removing the wings to inspect for corrosion, taking out all the radios to run a bench specifications test, and all that stuff) just isn't the real world. I won't take a pre-buy job except for a good friend and even at that we have to have the understanding that (s)he is going to be standing right at my side during the entire process and watch everything that I look at. Six months later when the veeblefeltzer snaps a rittit both (s)he and I looked at the damned thing and agreed that it looked normal. That and I charge double for a prebuy what I charge for an annual. Jim " My specific question is ... Since the plane was just annualled, what should I look for in my (free, amatuer) pre-buy and ask the mechanic too look for in the professional inspection, that would indicate a "don't buy" decision, even if the annual is fresh. |
Well, thank you for a mechanic's perspective on this.
Seeing as every piece of "how to buy a used airplane" literature recommends a mechanic's pre-buy, what do consider a real-world way for the amatuer to avoid the big money pits like wing spar problems? "RST Engineering" wrote in message ... Quite a few mechanics and quite a few shops tend to shy away from the "pre-buy" inspection for one main reason. There are a gazillion items that can be inspected to a fare-thee-well and wind up being unairworthy next week. Then you come back to me and ask me why I didn't find this glaring problem on the pre-buy and expect me to fix it for free. I won't take a pre-buy job except for a good friend and even at that we have to have the understanding that (s)he is going to be standing right at my side during the entire process and watch everything that I look at. Six months later when the veeblefeltzer snaps a rittit both (s)he and I looked at the damned thing and agreed that it looked normal. That and I charge double for a prebuy what I charge for an annual. |
Wing spars are fairly accessable and moderately easy to inspect thoroughly.
It is the stuff that you can't get inside to see without ripping the airplane completely apart that generally rise up and bite you. How do you detect that an oil pump gear has a hairline fracture and is about to self-destruct without pulling the back end of the engine apart? How do you tell that a bladder cell is about to start leaking from an invisible internal split in the cell wall? The stuff you can see is generally not the problem ... but in the case of an invisible crack in a cylinder wall it was. The answer is that there is no good answer except for a record of preventive maintenance. Jim "Douglas Olson" wrote in message ink.net... Well, thank you for a mechanic's perspective on this. Seeing as every piece of "how to buy a used airplane" literature recommends a mechanic's pre-buy, what do consider a real-world way for the amatuer to avoid the big money pits like wing spar problems? |
Jim,
Is there an easier way to check a Cherokee wing spar than pulling the tanks? I mine inspected (SB-1006?) when I bought my PA28-140 in 2000. Did it again last year when my tanks were sent to New Hampshire for overhaul. "RST Engineering" wrote in message ... Wing spars are fairly accessable and moderately easy to inspect thoroughly. |
Christmas Annual - long drivel | Denny | Owning | 23 | December 31st 04 08:52 PM |
My Aztec's first Annual | Louis L. Perley III | Owning | 11 | November 11th 04 05:04 AM |
Annual Report Final. "Long" | NW_PILOT | Owning | 20 | October 28th 04 07:20 PM |
Annual Report Final. "Long" | NW_PILOT | Piloting | 22 | October 28th 04 07:20 PM |
Annual Costs - Take the Pledge | Roger Long | Owning | 25 | February 1st 04 03:41 PM |
