Hi All!
OK... Piper Warrior...PA28-151 Considering purchase... It's is a 1976 Model.. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ....1977 and later is 44 knts! WHAT changes were made to bring the stall speed down by 14 knts! I have looked at both, I cannot (untrained eye) see what is different.. Owner of the '76 says 52 knts(w/flaps) , 58 knts "clean" (????) Tis a huge difference... is this correct? Why? Can the 76 be modified to get the stall speed lower? Can any one help here? What is the story? Thanks in advance! Dave |
Good bird -- I owned a '75 from '98 - '02. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ...1977 and later is 44 knts! Where in the world did you get THAT figure? Here are the actual Warrior specs: Warrior 1974-1977 Performance: (Knots, nautical miles in parentheses) Top Speed (Sea Level) 135 (117) Cruise: 133 (115) Best Rate of Climb: 91 (79) Stall Speed (with flaps) 58 (50) Fuel Consumption (75% power): 8.5 gph Range (75% at 7,000 ft.) 720 (626) Takeoff over 50' obstacle: 1,760 feet Ground run: 1,065 feet Landing over 50' obstacle: 1,115 feet Ground run: 595 feet Rate of climb (Sea Level): 649 feet Service Ceiling: 12,700 feet Specifications Fuel capacity: 50 gallons Engine: Lycoming 0-320-E3D TBO: 2,000 hours Power: 150 hp Wing Span: 35 ft 0 in Wing Area: 170 sq ft Length: 23 ft 9 in Height: 7 ft 4 in Wing Loading: 13.7 lb/sq ft Power Loading: 15.5 lb/hp Gross Weight: 2,325 lbs Empty Weight: 1,301 lbs Useful Load: 1,024 lbs Baggage Capacity: 200 lbs The Warrior is a great plane. It's forgiving, it's tough, it burns car gas at just 8 gph (or less!), it'll haul four people if you go light on fuel, and it's easy to land. (That useful load figure in the stats, above, is highly suspect, IMHO. Plan on closer to 900 lbs.) If you're not in a big hurry, and you don't need to haul a ton, the Warrior is the perfect plane. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Avation Destination" |
Make sure it's apples to apples. One could be indicated
and one calibrated airspeed. "Dave" wrote in message ... Hi All! OK... Piper Warrior...PA28-151 Considering purchase... It's is a 1976 Model.. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ...1977 and later is 44 knts! WHAT changes were made to bring the stall speed down by 14 knts! I have looked at both, I cannot (untrained eye) see what is different.. Owner of the '76 says 52 knts(w/flaps) , 58 knts "clean" (????) Tis a huge difference... is this correct? Why? Can the 76 be modified to get the stall speed lower? Can any one help here? What is the story? Thanks in advance! Dave |
Hi Jay!
Figured you would be out there! (yeah, the 172 may be gone, I will send a new pic for the gallery if this happens) I got this 44 kns off of 3 websites with Warrior specs ... Your numbers SPAN the "break" in my specs at 1976/7...(?) TY 4 UR help on this... The Warrior is a great plane. It's forgiving, it's tough, it burns car gas at just 8 gph (or less!), it'll haul four people if you go light on fuel, and it's easy to land. (That useful load figure in the stats, above, is highly suspect, IMHO. Plan on closer to 900 lbs.) If you're not in a big hurry, and you don't need to haul a ton, the Warrior is the perfect plane. We are not, and don't need to! ![]() I have early time in a 161, loved it! Cheers! Dave |
Hmmm... thought of that Otis, but a 30% spread? (44 - 58)
? Dave On Fri, 03 Jun 2005 22:11:08 GMT, "OtisWinslow" wrote: Make sure it's apples to apples. One could be indicated and one calibrated airspeed. "Dave" wrote in message .. . Hi All! OK... Piper Warrior...PA28-151 Considering purchase... It's is a 1976 Model.. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ...1977 and later is 44 knts! WHAT changes were made to bring the stall speed down by 14 knts! I have looked at both, I cannot (untrained eye) see what is different.. Owner of the '76 says 52 knts(w/flaps) , 58 knts "clean" (????) Tis a huge difference... is this correct? Why? Can the 76 be modified to get the stall speed lower? Can any one help here? What is the story? Thanks in advance! Dave |
My Aircraft Bluebook Price Digest, under Specs, shows a PA28-151 Warrior
with a stall speed of 44 and a note saying "Prior 77 stall = 58" with no further explanation. Lists both 76 and 77 with a 150 hp engine. Aviation Consumer's Used Aircraft Guide shows that the 77 got a 10hp boost...owners of the 150hp version complained of poor climb performance. Can't quite figure out how ten more horses would affect power-off stall speed. To further confuse the issue, Motorbooks International's Piper Buyer's Guide says that Piper went to 160hp in 1975 and doesn't discuss stall speed at all. I was instructing full-time at a Piper operation during the time period when the 140 turned into a 151 and can't recall anything about the Warrior that I didn't like. Pretty bulletproof in my opinion. There are mods available that affect stall speed, like aileron gap seals, but their effect wouldn't show up in the pubs I have, which deal in unmodified airframes. Bob Gardner "Dave" wrote in message ... Hi All! OK... Piper Warrior...PA28-151 Considering purchase... It's is a 1976 Model.. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ...1977 and later is 44 knts! WHAT changes were made to bring the stall speed down by 14 knts! I have looked at both, I cannot (untrained eye) see what is different.. Owner of the '76 says 52 knts(w/flaps) , 58 knts "clean" (????) Tis a huge difference... is this correct? Why? Can the 76 be modified to get the stall speed lower? Can any one help here? What is the story? Thanks in advance! Dave |
"Jay Honeck" wrote in message oups.com... OK... Piper Warrior...PA28-151 Good bird -- I owned a '75 from '98 - '02. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ...1977 and later is 44 knts! Where in the world did you get THAT figure? Here are the actual Warrior specs: Warrior 1974-1977 Performance: (Knots, nautical miles in parentheses) Top Speed (Sea Level) 135 (117) I assume that you are saying STATUTE MILES PER HOUR outside of parentheses, and knots IN parenthesis, right? |
Look here Jay..
http://www.pilotfriend.com/Piper%20aircraft.htm and http://www.premi-air.co.nz/singlespe...iper+PA-28-151 Dave On 3 Jun 2005 15:00:37 -0700, "Jay Honeck" wrote: OK... Piper Warrior...PA28-151 Good bird -- I owned a '75 from '98 - '02. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. |
The plot thickens!
![]() I mn finding the same. (note links posted above) from several sources. This 14 knts had to come from SOMEWHERE... TY! Dave On Fri, 3 Jun 2005 15:21:52 -0700, "Bob Gardner" wrote: My Aircraft Bluebook Price Digest, under Specs, shows a PA28-151 Warrior with a stall speed of 44 and a note saying "Prior 77 stall = 58" with no further explanation. Lists both 76 and 77 with a 150 hp engine. Aviation Consumer's Used Aircraft Guide shows that the 77 got a 10hp boost...owners of the 150hp version complained of poor climb performance. Can't quite figure out how ten more horses would affect power-off stall speed. To further confuse the issue, Motorbooks International's Piper Buyer's Guide says that Piper went to 160hp in 1975 and doesn't discuss stall speed at all. I was instructing full-time at a Piper operation during the time period when the 140 turned into a 151 and can't recall anything about the Warrior that I didn't like. Pretty bulletproof in my opinion. There are mods available that affect stall speed, like aileron gap seals, but their effect wouldn't show up in the pubs I have, which deal in unmodified airframes. Bob Gardner "Dave" wrote in message .. . Hi All! OK... Piper Warrior...PA28-151 Considering purchase... It's is a 1976 Model.. Specs, (published) say stall, dirty ( Full Flaps ) for a 1976 built is 58 knts. ...1977 and later is 44 knts! WHAT changes were made to bring the stall speed down by 14 knts! I have looked at both, I cannot (untrained eye) see what is different.. Owner of the '76 says 52 knts(w/flaps) , 58 knts "clean" (????) Tis a huge difference... is this correct? Why? Can the 76 be modified to get the stall speed lower? Can any one help here? What is the story? Thanks in advance! Dave |
Dave wrote: The plot thickens! ![]() I mn finding the same. (note links posted above) from several sources. This 14 knts had to come from SOMEWHERE... I'm thinking that "Prior 77 stall = 58" might have come from the point where Piper shifted from using MPH to Knots for their performance figures. 58 mph is right where the dirty stall should be on most 150 - 180 hp PA28s. Where the "44" came from is anybody's guess. 58 mph converted to knots is around 50-51 kts. Perhaps the missing 6 kts might come from a measurement in indicated airspeed rather than calibrated airspeed. One thing I can tell you is that they all stall at around the same speed. There were no drastic changes that changed the stall characteristics from '76 to 77. If you're seriously considering buying one, this is not something you should spend a lot of time worrying about. John Galban=====N4BQ (PA28-180) |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Piper Pilots! Ned Warrior help! | Dave | Owning | 8 | June 8th 05 12:15 AM |
| Reading back altimeter settings? | Paul Tomblin | Piloting | 31 | April 12th 05 05:53 PM |
| Here we go again | Roger | Piloting | 39 | April 7th 05 08:20 AM |
| WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 04:01 PM |
