Phil Verghese writes:
I posted earlier about seeing differences of up to 500' between the altitude shown on my Garmin GPS 196 (even while receiving WAAS) and my altimeter. The GPS would consistently indicate higher than the altimeter. Dan Luke suggested the cause might be non-standard temperatures. After some more experimenting, I think Dan was correct. In Canada, learning about temperature errors in the altimeter is a standard part of the PPL curriculum, but I've noticed that it's not so familiar to U.S. pilots (at least not private pilots). We have tables in our AIP and other publications showing what errors to expect, and when flying IFR, we are required to add those errors to all instrument approach altitudes (MDA, DH, etc.) in very cold temperatures. So the GPS is showing the right value. However, that value is different than what you altimeter shows when the temperature is not standard. When temperatures are above standard, the GPS altitude will be higher than indicated and when termperatures are below standard the GPS altitude will show lower than indicated. Does this make sense? Yes. A rough rule of thumb is that your altimeter will be off by 4 feet, per degree Celsius difference from ISA, per thousand feet above the station reporting the altimeter setting. This works, of course, only with the standard lapse rate -- if there's an inversion or any other non-standard lapse rate between you and the field reporting the altimeter setting, this formula won't work. Let's assume that your field is at 1000 ft MSL with 20 degC above standard temperature and a standard lapse rate all the way up. When you're sitting on the field, your altimeter should show your actual elevation: 4 * 20 * 0 = 0 ft error So you'll see 1000 ft on your altimeter when you dial in the field's altimeter setting. At 200 ft AGL (typical ILS DH), your error will will be 4 * 20 * 0.2 = 16 so that when your altimeter reads 1200 ft on short final, you're really around 1216 ft MSL, or 216 ft AGL. At 9000 ft MSL (8000 ft AGL), the error will be much larger: 4 * 20 * 8 = 640 ft So when your altimeter says 9000 ft, you'll really be up at 9640 ft. That's no big deal, but it could be dangerous in cold temperatures, if you were trying to clear (say) an 8000 ft ridge with 1000 ft clearance. If the temperature was 20 degC below standard, and your altimeter setting was from a field at 1000 ft MSL, you'd actually be flying at 8360 ft when your altimeter read 9000 ft, just barely clearing the ridge. I wonder how this will affect the upcoming WAAS LPV approaches. They are going to have a decision altitude based on indicated altitude, not true altitude. How will the difference between true altitude and indicated altitude affect the approach, since the GPS will be giving vertical guidance based on true altitude? The approach will be a safer than approaches based on a barometric altimeter, all things considered. Barometric altimeters are fine for cruise, since everyone sees the same error and flies at the same altitude anyway (just not the one they think they're flying at). All the best, David |
David Megginson wrote
In Canada, learning about temperature errors in the altimeter is a standard part of the PPL curriculum, but I've noticed that it's not so familiar to U.S. pilots (at least not private pilots). I'm sure that Canada is the promised land as far as aviation education goes, and that no instructor there ever sends a student to a checkride when the student isn't REALLY ready to exercise ALL the privileges of the certificate but is likely to be able to pass the flight test. Unfortunately, this is not the case in the US. Nonetheless, altimeter temperature errors ARE a part of the standard US private curriculum. We have tables in our AIP and other publications showing what errors to expect, I'm sure that in this case you are referring to the ICAO Cold Temperature Error Table, which is part of the AIM. Check it out online: http://www1.faa.gov/ATPubs/AIM/Chap7/aim0702.html#7-2-3 I don't know about you, but I have yet to meet a US flight instructor who does not require his students to have a copy of the AIM and be conversant with it. Thus I have to assume that every US student pilot has seen this table at one time or another. It doesn't particularly surprise me that many don't recall this. I'm sure you learned how to extract a square root manually in primary school, as did everyone else. Can you still do it? Maybe. But I assure you that not only are most adults incapable of doing it, but that many will claim never to have learned. Use it or lose it. For most private flying in the continental US, altimeter errors are not particularly relevant. and when flying IFR, we are required to add those errors to all instrument approach altitudes (MDA, DH, etc.) in very cold temperatures. See, that's the basic difference. We are not REQUIRED to do anything about those tables. The information is made available to us, along with a recommendation to adjust minima as appropriate. It is part of the AIM, which every private pilot candidate is expected to become familiar with. How we choose to use the information is up to us. The altimeter errors are very real - but a correction to MDA or DH is not always necessary. For example, many ILS approaches are equipped with a middle marker. The marker is not affected by altimeter errors. It's not really the MAP, but in most cases it's close enough that it can be used to signal a missed approach in situations where the altimeter is suspected of reading high. Let's not forget that the worst case temperature error at 200 ft and -50C is only 60 ft, while altimeters can be up to 75 ft off in some cases and still be legal for IFR use. There used to be a DH penalty for an inop middle marker (either at the transmitter or receiver end) but this penalty no longer applies. All this ignores the possibility that the pilost has a RADAR altimeter available. In the US, it is up to the pilot to decide whether in his particular situation, given the available equipment and his skills, he should adjust the minima as appropriate based on the expected temperature error. Michael |
![]() "David Megginson" wrote in message ... (Michael) writes: I'm sure that Canada is the promised land as far as aviation education goes, Not at all -- I've just been surprised at how many U.S. pilots don't seem to know about altimeter temperature errors. On mailing lists, I've actually had violent reactions from otherwise experienced and competent pilots when I casually mentioned that pressure altimeters are routinely off by hundreds of feet at cruise altitude. I think what they teach us is density altitude differences, but that's for performance during takeoff. I wonder if the new RVSM rules/equipment might refocus some discussion in that direction? Tom |
![]() David Megginson wrote: On mailing lists, I've actually had violent reactions from otherwise experienced and competent pilots when I casually mentioned that pressure altimeters are routinely off by hundreds of feet at cruise altitude. It's pretty simple, really. It doesn't matter at all if your altimeter is off by hundreds of feet at cruise altitude if everybody else at that altitude has the same error. It would be possibly unsafe for you to set your altimeter accurately when everyone else is setting it to the broadcast local altimeter setting. In short, it doesn't matter. Just do it like everyone else. For noise abatement reasons. George Patterson A man who carries a cat by the tail learns something that cannot be learned any other way. Samuel Clemens |
"G.R. Patterson III" writes:
It's pretty simple, really. It doesn't matter at all if your altimeter is off by hundreds of feet at cruise altitude if everybody else at that altitude has the same error. Unless you're trying to clear mountains using an altimeter setting from a low-elevation field. It would be possibly unsafe for you to set your altimeter accurately when everyone else is setting it to the broadcast local altimeter setting. Absolutely -- no one is suggesting changing the altimeter setting. You just have to be aware of how inaccurate the altimeter is when obstacle clearance might be an issue. For example, if you are planning to clear a ridge by only 1000 ft in the winter, you might want to think again. All the best, David |
Not at all -- I've just been surprised at how many U.S. pilots don't seem to know about altimeter temperature errors. On mailing lists, I've actually had violent reactions from otherwise experienced and competent pilots when I casually mentioned that pressure altimeters are routinely off by hundreds of feet at cruise altitude. Yep. They forgot it, since it wasn't really relevant. As for the violent reaction, it's not a pilot thing but a people thing. There are people who are often wrong but never uncertain. It's kind of sad when an experienced pilot gets that way, but it's really terrible when an old experienced instructor falls into that mode, since at that point he's largely worthless. But think for a second - why do you suppose MEA's and OROCA's provide 1000 ft of obstacle clearace normally, but 2000 in designated mountainlous areas? If you're IFR, you're not going to be clearing that peak by less than 2000 ft, and that is going to keep you out of the rocks in even the worst case scenario. If you're VFR, then you can see the peak and don't really need the altimeter anyway. Let's not forget that the worst case temperature error at 200 ft and -50C is only 60 ft, while altimeters can be up to 75 ft off in some cases and still be legal for IFR use. What if the errors compounded? I agree that it's unlikely (and would require a very cold day), but using your numbers someone with a 75 ft altimeter error and a 60 ft temperature error could end up at only 65 ft AGL when the altimeter read 200 ft AGL. Which is still not the end of the world. In a light airplane, you can easily go missed from 65 AGL (or land, if you break out). Anything heavy and fast enought that this isn't true is probably going to have a RADAR altimeter and Cat II certification anyway. Michael |
That's what one would hope. Unfortunately, there are many gradations between CAVU and IMC, and pilots do seem to have an unfortunate tendency to fly into mountains or get stuck in canyons from time to time while (legally) VFR. Some people fly to the legal limits of the certificates and ratings they hold; others do not. I realize this is obvious. What should be equally obvious (but sometimes is not) is that in order to do so with a reasonable margin of safety, you need a much higher level of skill and knowledge than what is required to pass the checkride. What we're doing here is exploring one tiny corner of the knowledge envelope in great detail. Most pilots couldn't care less. Most pilots are also not going to fly in the mountains in anything less than good day-VMC, so they really don't care - or need to. The examiner is not able to check every possible knowledge area in depth - that's not his function. He only performs a rough check to make sure the instructor didn't leave out anything really major. Anything else would take much too long. So really, all you need is a few people who don't know what they don't know and pay the ultimate penalty to observe what you've described. I'm not sure if lack of knowledge of temperature errors has ever caused someone to fly into an obstruction he thought he was clear of, but I can certainly believe it has happened. Michael |
Terminology of New WAAS, VNAV, LPV approach types | Tarver Engineering | Instrument Flight Rules | 2 | August 5th 03 03:50 AM |
Big News -- WAAS GPS is Operational for IFR | Lockheed employee | Instrument Flight Rules | 87 | July 30th 03 02:08 AM |
Garmin Behind the Curve on WAAS GPS VNAV Approaches | Richard Kaplan | Instrument Flight Rules | 24 | July 18th 03 01:43 PM |
High Altitude operations (Turbo charge???) | Andre | Home Built | 68 | July 11th 03 11:59 PM |
