"Refusing to Handle You"
Old July 17th 05, 12:27 AM
Michelle P
Mike,
A phone call to their QA/QC dept. in order.
540-349-7500 main number
540-349-7548 QC dept. if no answer in a couple of days call the number
below.
540-349-7505 for the QC Manager.
Have the time, frequency and tail number ready. You will likely need to
leave a phone message.
Let them know they refused the hand off from Washington.
Michelle
Mike Granby wrote:
So, an interesting thing happened today. I am at a fly-in at Hagerstown
and about to head back to my home-base at York (THV). I can see from
the PC they had there that there is a line of heavy rain and possibly
thunderstorms blocking my route back. There is no way around it to the
north, but there is a way to the south. So, instead of the usual
KHGR-SCAPE-THV to take me north of Camp David, I file a route via
HGR-MRB-EMI to so south and get in to York through the back door.
When I pick up my clearance, I am given the route via SCAPE, but I
"unable" that for weather, and they go away for a few minutes, and then
clear me as filed. I take off, and everything is fine, until I'm headed
southbound from the HGR VOR, when the Washington Center controller
calls me and says "Err, 8096J, Potomac Approach is refusing to handle
you, say intentions." So now, here I am, in the air with two small kids
on board, and being turned back towards what was, a while back at
least, some nasty weather. I ask for a hold at HGR to consider my
options, and luckily, by now the StormScope is showing the line has
dissipated. Now, I'm not happy, 'cos I know there's been cells
appearing along that route all PM, but I have little choice, so I take
the SCAPE route. All ends well, and we have an almost smooth ride, but
I was amazed that they gave me a clearance for that route, and then
wouldn't honor it! Comments???
Old July 17th 05, 01:29 AM
Warren Jones
"Michelle P" wrote in message
nk.net...
Mike,
below.
Michelle
Michelle, what good would come of such a phone call? QA will give you lip
service, but you'd be wasting your time calling about this IMO.
Chip, ZTL
Old July 17th 05, 01:38 AM
Mike Granby
Well, I can just about understand if Potomac doesn't want to handle
routes like that, but they ought to find a way of making sure that
clearances don't get issued that contain those routes. I would have
liked to have been able to plan my other options on the ground with a
PC in front of me, instead of in the air relying on the variable
accuracy of 'spherics.
Old July 17th 05, 02:25 AM
Michelle P
You would be mistaken. The QC dept. is not floor supervisors. The have
to look at it. I have made several calls to Potomac TRACON QC and I have
seen improvements in their services. I do the same for Leesburg FSS and
I have seen changes there as well. One controller got a few days off for
being rude and just plain wrong.
Michelle
ink.net...
Mike,
below.
Michelle
Chip, ZTL
Old July 20th 05, 04:41 AM
Warren Jones
link.net...
You would be mistaken. The QC dept. is not floor supervisors. The have to
look at it. I have made several calls to Potomac TRACON QC and I have seen
improvements in their services. I do the same for Leesburg FSS and I have
seen changes there as well. One controller got a few days off for being
Michelle
If it makes you feel good, go ahead and call. You are wasting your time. I
assure you that a call to the QA office of a mac-daddy approach control like
Potomac, Southern Cal, Chicago, New York, Atlanta etc, whining about the
facility's refusal to work you en route through busy terminal airspace,
wouldn't make it out of the QA office. They'd pay you lip service, and then
they'd probably laugh about your temerity/stupidity after they hung up the
receiver. Little airplanes IFR en route don't have the magical power to fly
willy nilly through busy Tracons unless the pilot knows the magic word when
he is refused initial clearance. Also, if he uses the magic word, he'd
better be prepared to formally defend its use.
I can imagine that the controllers and flight service specialists in
Maryland and the Old Dominion tremble when they hear your voice on the
radio.
Chip, ZTL
Old July 31st 05, 05:58 AM
Allan9
Warren
I take exception to your statement.
The situation would have been researched and the user would have had the
situation explained to them right or wrong. Maybe that's what they would do
in your facility.
Al
"Warren Jones" wrote in message
link.net...
link.net...
seen improvements in their services. I do the same for Leesburg FSS and I
Michelle
I assure you that a call to the QA office of a mac-daddy approach control
like Potomac, Southern Cal, Chicago, New York, Atlanta etc, whining about
the facility's refusal to work you en route through busy terminal
airspace, wouldn't make it out of the QA office. They'd pay you lip
service, and then they'd probably laugh about your temerity/stupidity
after they hung up the receiver. Little airplanes IFR en route don't have
the magical power to fly willy nilly through busy Tracons unless the pilot
knows the magic word when he is refused initial clearance. Also, if he
uses the magic word, he'd better be prepared to formally defend its use.
radio.
Chip, ZTL
Old August 1st 05, 09:58 PM
Warren Jones
"Allan9" wrote in message
Warren
do in your facility.
Al
Except away. What ATC facility QA department are you affiliated with?
Quality Assurance at a busy terminal or en route facility is largely
concerned with the technicalities of aircraft separation, air space
separation and incidents/accidents. For a non-incident/accident, all you
are actually going to get is lip service, believe it or not.
Chip, ZTL
Old August 2nd 05, 12:51 AM
Allan9
Four years AMQA ORD/C90
Al
ink.net...
Warren
Al
Chip, ZTL
Flap handle activated Climb/Cruise switching Andy Smielkiewicz Soaring 5 March 14th 05 04:54 AM
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
G103 Acro airbrake handle Andy Durbin Soaring 12 January 18th 04 11:51 PM
How do you handle your EFB in the cockpit? greg Instrument Flight Rules 5 November 17th 03 03:47 AM
Need door handle for 1959 Cessna 175 Paul Millner Owning 0 July 4th 03 07:36 PM
