Joseph D. Farrell know what to add wrote in message . ..
Hello - I have been looking in the AIM and a few other places and am trying to track down where enroute approach control end and Center control altitudes begin. Joseph, I asked basically the same question sometime back, and the bottom line seemed to be I'd have better luck asking for the moon. Typically, the airspace controlled by a small TRACON may go up to 8k or so; a major class B may go up to 14,000 ft or at least require coordination until that height. As for what altitude is best for you to go through an approach airspace, that's going to vary depending upon your route and the approach airspace in question, and even the winds and the time of day. I would say, file for what you want and be prepared to negotiate. Sometimes you can get through if conditions allow you to request the IFR clearance VFR-on-top. Some TRACONs are able and willing to let IFR flights fly through their turf. Others operate on what we call the "GOMAB" principle (Get Out of My Airspace Bugsmasher!) and will give you the wide-around. You gotta understand that when you're IFR, to ATC you're a slow-moving roadblock 5 miles wide and 2000 ft tall (I know, I know, either 5 miles OR 1000 ft but the point is, they gotta think about that swath of airspace surrounding you). So depending upon how your exact route interacts with their approach and departure patterns will govern what they can do. If your flight path is perpendicular to their arrival and departure stream, right over the airport at 4-6k might work OK. If you're in a different place 4-6k might be impossible. Dunno if this helps at all, Sydney |
St. Louis approach does the same at STL for westbound arrivals to SUS.
---JRC--- "Roy Smith" wrote in message = ... (Snowbird) wrote: If your flight path is perpendicular to their arrival and departure stream, right over the airport at 4-6k might work OK.=20 =20 Or lower. I've had NY Approach bring me right over the center of=20 LaGuardia at 1500 with a steady stream of jets landing and departing=20 right below me. Pretty cool. |
"John R. Copeland" wrote in message .. .
St. Louis approach does the same at STL for westbound arrivals to SUS. Westbound, generically? I Don't Think So. If you're approaching from the NE (ie you are SW bound) they will often swing you a little to the west and take you over the top of Lambert. Usually at 4-5000 ft IME. Basically if your direction of flight takes you to the N of ALN. OTOH if you're approaching from due E (ie course 270) or from the SE (ie course NW) you're going to get the wide-around way to the S if you're IFR because you're not just directly impacting the departure/arrival corridor for STL, you're impacting the IFR arrivals and departures from Parks and MidAmerica and Alton. If they are actually taking you over the top of Lambert at 1500 ft, be advised that you are going to pop out of the class B well before you get to SUS, and you'll either be right in the thick of the E-W VFR corridor S. of Hwy 40 (I-64) or if you're further to the W, like W of 270, you're going to be flying through the N-S traffic corridor into 1H0 which is quite busy on weekends and quite often NORDO or monitoring 1H0 Unicom. Usually flying 1500-1700 ft to stay under the approach path into SUS. Keep both eyes peeled and cultivate a neck like an owl. Cheers, Sydney "Roy Smith" wrote in message ... (Snowbird) wrote: If your flight path is perpendicular to their arrival and departure stream, right over the airport at 4-6k might work OK. Or lower. I've had NY Approach bring me right over the center of LaGuardia at 1500 with a steady stream of jets landing and departing right below me. Pretty cool. |
The perfect approach | Capt.Doug | Home Built | 25 | December 3rd 04 03:37 AM |
GPS approaches with Center | Dan Luke | Instrument Flight Rules | 104 | October 22nd 03 09:42 PM |
DME req'd on ILS (not ILS-DME) approach? | Don Faulkner | Instrument Flight Rules | 13 | October 7th 03 03:54 AM |
Which of these approaches is loggable? | Paul Tomblin | Instrument Flight Rules | 26 | August 16th 03 05:22 PM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
