Needle deflection as you fly outbound on the back course are the same as
those seen inbound on the front course...if you are right of course, the needle deflects to the left. The rule on intersections is: If the needle is on the same side as the station, you aren't there yet. So answer C is correct. Your problem is that you think needle deflections change as you fly over the localizer antenna, and this is just plain wrong. Bob Gardner wrote in message ... I'm having some trouble with question 4488. In the Insturment rating exam Text ![]() confirm that you are approaching WAGGE intersection slightly to the right of the LOC centerline on departure? A 1 and 3 -My answer B 1 and 4 C 2 and 3 -Book answer I read this question as right of centerline from the airplane perspective. Since this is a departure procedure you will be flying the localizer outbound. (back course) So localizer indications should be reversed. If you are right of course the localizer needle will point to the right. (Back course) However the answer book says thats wrong. It says the loc needle should point to the left. There are one of three possible explainations: 1)I'm lost, possible but I don't think so. 2)They mean to the "Right" not of course but of the depicition of the course on the printed page. 3)The words (fine print next to the localizer depiction) "Back Course" refer to the localizer inblound to the airport direction, or to the direction that you are flying the localizer for this procedure? The chart does not have the shading on the localizer, which would resolve the front course back course issues In general this WASHOE TWO Departure seems to be confusing from the front course backcourse perspective unless you also have the approach plate in hand to resolve the actal direction of the localizer.. Thoughts or comments? |
"Bob Gardner" wrote:
The rule on intersections is: If the needle is on the same side as the station, you aren't there yet. I learned that as the easy to remember phrase, "Same Side, Safe". |
Another Painting Question | c hinds | Home Built | 6 | December 6th 04 01:39 AM |
Newbie Question, really: That first flight | Cecil Chapman | Home Built | 25 | September 20th 04 05:52 AM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
