However, doesn't the AI have the potential to tumble in an unusual
attitude? You know, I've heard that too. And it sure seems like it could, by design. Only thing is, I've spent a lot of time teaching unusual attitudes - and I've never seen it happen. I think you need something more radical to happen than what we think of as an unusual attitude - more aerobatic. I see little chance of that happening with dual AI's, and even less chance that the average pilot will recover from an aerobatic attitude partial panel after screwing up enough to get into that mess. But hey - if you have the panel room, why not keep the electric TC too? Michael |
Michael wrote:
I see little chance of that happening with dual AI's, and even less chance that the average pilot will recover from an aerobatic attitude partial panel after screwing up enough to get into that mess. Interesting that you pointed that out. I was thinking the same thing when I posed the question but thought that two tumbling AIs would pretty much guarantee that the pilot would not recover. But hey - if you have the panel room, why not keep the electric TC too? My Bonanza has the original TC along with a backup electric AI located to the left of the TC. However, the electric AI keeps precessing and requires a reset about four times per hour, which concerns me. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
I posed the question but thought that two tumbling AIs would pretty much guarantee that the pilot would not recover. I agree with you - with two tumbled AI's and no TC, recovery is impossible. With a working TC, it is merely highly unlikely. Therefore, if the panel space is there, it might make sense to keep the TC. Not much sense, mind you, because if you manage to screw up badly enough to put the plane into an attitude that would cause both AI's to tumble, well, I'm willing to give very good odds that you're not going to recover on the TC. However, let's say having both the TC and the second (electric) AI is not practical (probably due to space considerations). Would I rather have an electric AI, or the TC? I would still prefer the electric AI. First off, with dual AI's next to each other, I believe that following a dying AI into an unusual attitude becomes far less likely, and thus while the chances of recovery from the unusual attitude are reduced slightly, the chances of encountering it in the first place are reduced dramatically. Not so with a backup vacuum - you have to engage it. And even if you do, half the time (in my experience more) the problem is the AI, not the power source, so backup power for the AI does you no good. The problem with this analysis is the reliability (or lack of same) for electric AI's. I've heard the affordable ones are not good, and the good ones are not affordable. Finally, there is the issue of training. If you have dual AI's with independent power sources, it makes sense to skip partial panel training. If you have only a single AI, even with redundant power sources, that's not the case. In that case, a standby vacuum system seems to be an unjustified expense - the money spent on it is probably better spent on recurrent training. Michael |
keep the TC. I know that FAR 91.205 requires a rate of turn indicator for IFR (except for airliners with three attitude indicators). Is it common for this requirement to be waived to allow substituting a second AI for the TC? |
airliners with three attitude indicators). Is it common for this requirement to be waived to allow substituting a second AI for the TC? In a manner of speaking. No waiver is actually necessary. Advisory Circular 91-75 details the conditions under which this substitution is acceptable. Note that 91.205 states: no person may operate a powered civil aircraft with a standard category U.S. airworthiness certificate in any operation described in paragraphs (b) through (f) of this section unless that aircraft contains the instruments and equipment specified in those paragraphs (or FAA-approved equivalents) 91.75 Details what constitutes an FAA-approved equivalent for a rate-of-turn indicator. Michael |
Michael wrote:
First off, with dual AI's next to each other, I believe that following a dying AI into an unusual attitude becomes far less likely, and thus while the chances of recovery from the unusual attitude are reduced slightly, the chances of encountering it in the first place are reduced dramatically.Â*Â*NotÂ*soÂ*withÂ*aÂ*backupÂ*vacuum *-Â*youÂ*haveÂ*toÂ*engageÂ*it. This is the first of my two major reasons for preferring the backup AI. It helps with problem detection. A backup vacuum doesn't. And even if you do, half the time (in my experience more) the problem is the AI, not the power source, so backup power for the AI does you no good. And this is #2. Some people to whom I've spoken about this have made a big deal about the fact that the backup AI does nothing for a HI during a vacuum failure. My response is typically "who cares?". Given a compass and a GPS, the HI has plenty of backup already. - Andrew |
![]() Andrew Gideon wrote: Michael wrote: First off, with dual AI's next to each other, I believe that following a dying AI into an unusual attitude becomes far less likely, and thus while the chances of recovery from the unusual attitude are reduced slightly, the chances of encountering it in the first place are reduced dramatically. Not so with a backup vacuum - you have to engage it. This is the first of my two major reasons for preferring the backup AI. It helps with problem detection. A backup vacuum doesn't. Which is why the Precise Flight standby systems include a low-vacuum annunciator light. -cwk. |
annunciator light. Which merely gives you a false sense of confidence as the vacuum stays on and the AI fails. Since AI's fail as often as dry pumps (and far more often than wet pumps) the low-vacuum annunciator light really doesn't help much. The real solution would be a tiny magnet integrated into the vacuum gyro and a tiny coil fixed in place. This would act as a generator, and would likely make enough juice to keep an LED lit. LED goes out - problem. Doesn't matter whether it's a failed AI or failed vacuum. Now good luck getting that certified for GA at any sort of reasonable price. Michael |
Michael wrote:
Now good luck getting that certified for GA at any sort of reasonable price. In looking at some AIs and TCs, I did note at least one product where the flag is based not upon power but upon the rate of spin of the gyro. This was the Mid Continental 1394T100-7A according to my notes. - Andrew |
Peter R. wrote:
Michael wrote: I see little chance of that happening with dual AI's, and even less chance that the average pilot will recover from an aerobatic attitude partial panel after screwing up enough to get into that mess. Interesting that you pointed that out. I was thinking the same thing when I posed the question but thought that two tumbling AIs would pretty much guarantee that the pilot would not recover. But hey - if you have the panel room, why not keep the electric TC too? My Bonanza has the original TC along with a backup electric AI located to the left of the TC. However, the electric AI keeps precessing and requires a reset about four times per hour, which concerns me. What brand ? |
Wet vs Dry Vacuum Pump | Fastglasair | Owning | 7 | December 17th 04 11:46 PM |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Backup vacuum pump system STC'ed for Cherokee 180 | Chuck | Owning | 6 | September 18th 04 02:30 PM |
Reverse Vacuum Damging to Instruments? | O. Sami Saydjari | Owning | 8 | February 16th 04 04:00 AM |
Can vacuum AI be removed if a certified electric one is installed?? | Dave | Owning | 11 | January 12th 04 06:08 PM |
