DG-400 Oxygen Bottle Problems
Old September 1st 05, 05:12 PM
Tim Mara
not exactly......the US bottles have to have a blow out fixture (seal) that
releases if the bottle pressure exceeds the maximum allowed pressures.the
Euro bottles don't have this........or.the DOT stamp of approval....
tim
"Gary Evans" wrote in message
Having it tested will make sure its safe and usually
solve the filling issue. I've had no problem with fill
stations but I'm sure you could find one that would
still be concerned about the lack of a DOT stamp. That
however should have also been an issue before it needed
to be tested.
I'll leave the DOT regs to someone with more interest.
At 23:06 30 August 2005, Tim Mara wrote:
you can Hydro test anything.......even a Pepsi can.......but
you cannot
legally fill oxygen bottles in the USA without the
DOT approval and stamp.
tim
'Gary Evans' wrote in message
German 02 bottles can be hydro tested at the following
facility. Just had mine done and the cost was $47.50
plus shipping.
TYM's
414 West Arbor Vitae Street
Inglewood, Ca 90301
310-673-3330
Fax 310-673-0580
At 18:18 30 August 2005, wrote:
The only test and recertification station to serve
Utah refuses to test
and fill the german factory bottles for the DG-400
since they do not
have a USA DOT stamp on them. The official regulations
(which he
showed me) state that foreign bottles without the DOT
stamp can only be
tested for 'EXPORT' use. ie, airliner, ship, etc....leaving
the USA
for its use. Oxygen suppliers theoretically should
not even be filling
the bottles without the DOT stamp on them. I got two
bottles out of
date and the last one nearing out of date ( so far
I have local
airports filling them if the date stamp is ok, they
don't know about
the DOT stamp requirement regarding refills.) On the
DG-400 as most of
you know the bottle which has a smaller diameter than
USA bottles and
fits in a fiberglass sleeve that threads its way from
the cockpit past
the fuel tank without much room to spare. 90% of my
flight time is on
Oxygen in the Rockies so it is getting critical to
solve this stalmate
with oxygen bottle testing. DG-400 owners, what are
you doing to solve
this problem???
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
Reprise - Oxygen concerns Neptune Soaring 20 May 27th 04 03:27 PM
Need oxygen information Neptune Soaring 4 May 6th 04 08:11 PM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 08:52 PM
