![]() For us little guys, ANY ICE AT ALL is forbidden. (unless the aircraft is certified for known ice, which very few spam cans are). Forbidden by what? The laws of physics, ultimately. The FARs before that (though I can't find a specific rule, it would certainly be classified as "careless and reckless" if it led to an incident - it might be in the certification rules for aircraft, same as aerobatic stuff and equipment required.) The FAA has made it clear that unless the aircraft is certificated for known ice, you can't even legally enter forecast ice. Now, to open another can of worms, the FAA has produced an excellent video on icing (which they show at various safety seminars) in which they take the viewer through several flight scenarios. Well worth watching several times. However, I take a bit of an issue with one thing - the "unprotected" (non-de-iced) airplane pilot is flying in the clouds in non-icing conditions, towards a front that contains ice (there is ice above). On takeoff the weather briefing indicated that the front would not be an issue, but the weather moved in faster. Temperatures go down, and he gets ice. Now what? IN subsequent discussion, one possibility is to climb and get on top of the overcast, and it would be reasonable if the destination were clear. (mabye also in other situations). This would be legal (he's already in ice and trying to get out). However, if he were not YET in ice, it would be illegal (deliberately entering icing conditions). Seems to me that at that point, (he's in non-icing conditions, non-icing is behind him, temps going down , his destination ahead of him, and ice ahead of him) continuing would be illegal, but the FAA guy didn't have the opinion that continuing would constitute "deliberately entering ice..." and it's all a matter of bablance. Well, yes but... Jose -- (for Email, make the obvious changes in my address) |
![]() "Teacherjh" wrote in message ... The laws of physics, ultimately. The FARs before that (though I can't find a specific rule, it would certainly be classified as "careless and reckless" if it led to an incident - it might be in the certification rules for aircraft, same as aerobatic stuff and equipment required.) The FARs come before the laws of physics? The FAA has made it clear that unless the aircraft is certificated for known ice, you can't even legally enter forecast ice. What law, other than a natural law, would such an action violate? |
Sometimes the FAA will smite you first. Other times they don't get there in time, and you are left facing teh Grand Canonical Ensemble. What law, other than a natural law, would such an action violate? The type certificate. Jose -- (for Email, make the obvious changes in my address) |
![]() "Teacherjh" wrote in message ... The type certificate. I see. So if a type certificate does not mention icing at all then there is no prohibition against flight into known icing conditions in that aircraft, other than, of course, the laws of physics? |
![]() So if a type certificate does not mention icing at all then there is no prohibition against flight into known icing conditions in that aircraft, other than, of course, the laws of physics? Careless and reckless. Jose -- (for Email, make the obvious changes in my address) |
![]() "Teacherjh" wrote in message ... Careless and reckless. I believe you're referring to FAR 91.13, which is Careless OR Reckless Operation, not careless AND reckless. I own the aircraft and fly it solo, how does flying it into known icing conditions endanger the life or property of another? |
![]() I believe you're referring to FAR 91.13, which is Careless OR Reckless Operation, not careless AND reckless. I own the aircraft and fly it solo, how does flying it into known icing conditions endanger the life or property of another? You are right - careless OR reckless. No matter. It's not legal. It's usually not smart. If you have an aircraft that is not certificated for flight into known icing (say, a typical spam can), even if it is older than the regs, doing so puts it at the very real risk of acquiring ice on the airframe. An iced up airplane does not fly very well. It is less stable, has less lift, more drag, less power (as the prop and intake get iced), and more weight. Your instruments will be less reliable, and may fail (i.e. the static port gets iced) If the tail ices up faster than the wing, you can get into a tail stall, which feels simlar to a wing stall but whose recovery is the opposite. What's more, unlike say for turbulence, cloud, or an unusual attitude, exiting the icing conditions does not fix things. The ice that you have picked up doesn't just "go away" right away, especially if it's still cold out. Sublimation is very slow, and you have to get into fairly warm temps to melt the stuff. You can't count on that. One of the big problems occurs on landing iced up... the trim (if it still works) and configuration changes may destabilize the aircraft even if it seemed to be flying "just fine" before. Further, once you're in it, you might not be able to get out. It might be that conditions are closing all over. So, you might not end up with "just a peek" but rather, a whole lot of dunk. Certification for known ice includes more than just boots. There's a whole lot of redundancy involved, and significant excess power needed in the powerplant to overcome the effects of ice. This is part of the reason why it's not safe. It endangers people and property below you, far more than simply flying. Because of this, the FAA would consider it careless. It would also consider it reckless. The FAA has already said that "forecast" icing conditions count as "known" icing conditions, even in the face of pireps to the contrary. Jose -- (for Email, make the obvious changes in my address) |
Teacherjh wrote:
For us little guys, ANY ICE AT ALL is forbidden. (unless the aircraft is certified for known ice, which very few spam cans are). Forbidden by what? snip (though I can't find a specific rule, it would certainly be classified as "careless and reckless" if it led to an incident - it might be in the certification rules for aircraft, snip It's usually the aircraft's type certificate that specifies whether it can be flown in ice, but older types don't have any statement about ice in the type certificate. Remove SHIRT to reply directly. Dave |
We have an *authorized procedure* out here in the Pacific Northwest,
developed by the FSDO Aviation Safety Manager and the folks at the TRACON, specifically for use when icing conditions are forecast. It is called "Radar Vectors for Ice" and involves vectors to climb away from the Cascades until high enough to be well above the freezing level or in the clear. Obviously, since this procedure was developed by the FAA and published in the Safety Program newsletter every year at this time, a forecast of icing conditions is not, in and of itself, a bar to flight. There is a CYA caveat, of course, that nothing in the procedure should be taken as encouragment to take off into icing conditions. Bob Gardner "Teacherjh" wrote in message ... For us little guys, ANY ICE AT ALL is forbidden. (unless the aircraft is certified for known ice, which very few spam cans are). Forbidden by what? The laws of physics, ultimately. The FARs before that (though I can't find a specific rule, it would certainly be classified as "careless and reckless" if it led to an incident - it might be in the certification rules for aircraft, same as aerobatic stuff and equipment required.) The FAA has made it clear that unless the aircraft is certificated for known ice, you can't even legally enter forecast ice. Now, to open another can of worms, the FAA has produced an excellent video on icing (which they show at various safety seminars) in which they take the viewer through several flight scenarios. Well worth watching several times. However, I take a bit of an issue with one thing - the "unprotected" (non-de-iced) airplane pilot is flying in the clouds in non-icing conditions, towards a front that contains ice (there is ice above). On takeoff the weather briefing indicated that the front would not be an issue, but the weather moved in faster. Temperatures go down, and he gets ice. Now what? IN subsequent discussion, one possibility is to climb and get on top of the overcast, and it would be reasonable if the destination were clear. (mabye also in other situations). This would be legal (he's already in ice and trying to get out). However, if he were not YET in ice, it would be illegal (deliberately entering icing conditions). Seems to me that at that point, (he's in non-icing conditions, non-icing is behind him, temps going down , his destination ahead of him, and ice ahead of him) continuing would be illegal, but the FAA guy didn't have the opinion that continuing would constitute "deliberately entering ice..." and it's all a matter of bablance. Well, yes but... Jose -- (for Email, make the obvious changes in my address) |
Bob Gardner wrote:
We have an *authorized procedure* out here in the Pacific Northwest, developed by the FSDO Aviation Safety Manager and the folks at the TRACON, specifically for use when icing conditions are forecast. It is called "Radar Vectors for Ice" and involves vectors to climb away from the Cascades until high enough to be well above the freezing level or in the clear. Obviously, since this procedure was developed by the FAA and published in the Safety Program newsletter every year at this time, a forecast of icing conditions is not, in and of itself, a bar to flight. Of course not -- airspace is three-dimensional. I don't cancel a flight planned for 4000 ft in the summer because there's icing forecast from 15,000 to 20,000 ft. I wonder if there is anyone in this group who is seriously arguing that I should cancel such a flight. All the best, David |
