#21
Gary: Did TYM's put a new date stamp on the bottle when they tested it
? Also, what work did they do on the bottle? ie, remove the valve,sand blast the inside, test and reinstall the valve ? or just put a pressure test thru your valve without removing it? The reason I ask is I got the Salt Lake City test site to test one of my bottles 2 years ago and the didn't realise that the thread was metric and when they put their automatic pressure tester on and it auto-screwed up the joint it stripped my bottle threads ! |
They do a lot (perhaps all U.S.) metric bottle testing.
They stamped the bottle and provide a certificate that it passed test. I don't know if they removed the valve and/or cleaned the inside. Give them a call and ask if it matters to you. As explained before the lack of a DOT stamp has not been a problem for me and I have used several different filling stations. All metric bottles obviously have never had DOT stamps and there are many still in use. As Tim pointed out metric bottles also do not have a safety rupture disc installed in the valve, which is to protect against significant over pressurization, such as could be caused by fire. If either is an issue for you a new bottle is the only choice or only fly low. At 19:43 08 September 2005, wrote: Gary: Did TYM's put a new date stamp on the bottle when they tested it ? Also, what work did they do on the bottle? ie, remove the valve,sand blast the inside, test and reinstall the valve ? or just put a pressure test thru your valve without removing it? The reason I ask is I got the Salt Lake City test site to test one of my bottles 2 years ago and the didn't realise that the thread was metric and when they put their automatic pressure tester on and it auto-screwed up the joint it stripped my bottle threads ! |
you can see these bottles (and a lot more) on my page
http://www.wingsandwheels.com/page35.htm the bottles measure 4 3/16" O.D. essentially, when the major manufacturers of these cylinders went to Aluminum bottles they kept the same inside volume, but since steel is stronger they made the wall thickness on the aluminum bottles thicker and gained a few mm in the process... And for what it's worth, I spoke directly with the principles at DG and the former LS a few years ago and told them of the problem....asked why they couldn't just simply make the openings a few silly millimeters larger to accommodate the US owners .they in both cases simply shrugged it off and said to anyone in the USA it's "your problem" in Germany we have no problems.. real satisfaction I'd say... tim Wings & Wheels www.wingsandwheels.com wrote in message oups.com... Tim: I'm glad I posted this item so I could see all these comments. You are right of course that just finding someone to test it isn't the answer because without the DOT stamp an alert O2 station shouldn't fill it. I can't understand why the USA and Germany couldn't have agreed that for EXPERIMENTAL gliders the German bottle was exempt. Mine are certified to 2900psi and we only fill generally to 1800psi. What is the circumference of your "small" diameter bottles? and how long are they? Capacity ? Cost ? |
Duane Eisenbeiss wrote:
so putting it back in should make your insurance invalid and the annual. Doh Take to bottle out at annual inspection!! duh ![]() When you reinstall the bottle just call it "baggage". I might be wrong, but I thought that is exactly what it was all the time. I don't know of any glider with a certified oxygen installation, so we all carry oxygen as "portable" equipment. As such, it does not need FAA inspection and does not affect the aircraft airworthiness anymore than a flashlight or handheld GPS you carry in the glider. The problem isn't the FAA, but the DOT requirements. I'm not familiar with the DOT details, but prudence suggests having the bottle tested periodically, even if you can get it filled without the DOT stamp. I avoid the hassle and expense of commercial filling by owning two glider bottles, which gives me plenty of time to get one filled while the other is in use. I fill the bottles myself from larger tank that will allow several refills to 75% or more capacity. The tank is small enough that I can easily carry it with me on extended soaring trips; however, the two glider bottles are enough for a week of flying with my EDS controller. If you do decide to fill your bottles yourself, be sure to learn how to do it safely and get the right lines/hoses/valves. Improper equipment can lead to fires and explosions (been there, watched it done). It is possible to do it wrong, but done right, it's easy and safe. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
Reprise - Oxygen concerns | Neptune | Soaring | 20 | May 27th 04 03:27 PM |
Need oxygen information | Neptune | Soaring | 4 | May 6th 04 08:11 PM |
Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 08:52 PM |
