Instrument Training at night? Good Idea or not?
Old September 20th 05, 10:12 AM
David Cartwright
What are your thoughts on instrument training at night? Personally I
don't fly at night and have only for what was required for my PPSEL.
However my goal is to go on to my Commerical and CFI after the
Instrument.
So, I guess my question comes down to added risk. How much additional
risk am I taking by doing some of my Instrument at night?
The main thing with flying at night in a single-engine aircraft is that life
is less encouraging when it comes to engine failures. This said, though, I
can't see that it's really more risky flying on a nice, clear night than,
say, flying single-engine in daytime IMC with a low cloud base.
The main thing to be sure of is that your instructor is experienced and
extremely competent with night flying. Again, no surprises here - if you're
doing an IMC course in real IMC you'd want your instructor to have loads of
experience. The trick is to be confident that (a) they're sharp enough to
stop you getting into trouble; and (b) if, by some misfortune, they were
looking at the map while you got yourself into an inverted, screaming
descent, they'll be able to get you out of it.
I was fortunate in that my IMC instructors were both several-thousand-hours
ex-commercial pilots who had thousands of hours of hands-on IMC between them
(i.e. none of this namby-pamby auto-land stuff for the ex- Hunter and Fokker
50 pilot, and lots of nice North Sea weather for the helicopter captain :-)
Sadly I can only fly at night with an instructor because the CAA thinks I'm
too colour-blind, but it's immense fun and the views are awesome.
D.
Old September 20th 05, 01:26 PM
: I am getting ready to start of Instrument training. I plan on training
: during the day on the weekends and 1 or 2 nights during the week.
: What are your thoughts on instrument training at night? Personally I
: don't fly at night and have only for what was required for my PPSEL.
: However my goal is to go on to my Commerical and CFI after the
: Instrument.
: I know I will have to get proficient at night flying to teach the
: PPSEL, but not while IFR.
: So, I guess my question comes down to added risk. How much additional
: risk am I taking by doing some of my Instrument at night?
I won't reiterate what others have said regarding night flying and instrument
instructor proficiency. When I got my rating, I was adament about getting some actual
IMC time. I waited for "good bad weather" to do my cross-country training flights
for my instrument training. Something like 800-1000' overcast, stable stratus, no
icing or CB's, and good vis below.
As far as instrument training at night, there are good things and bad things.
The only real bad thing is it may be more difficult to read charts and such over dim
and/or colored cockpit lighting. If you're still still learning the intricacies of
reading IFR charts and plates, that can add a bit of congestion to your already
overloaded head.
On the plus side, lots of the subtle visual cues that you get while wearing
foggles aren't there. The small peripheral vision leaks out the side of the foggles,
the sun changing angles on the instrument panels, etc.... those are pretty much gone
at night. You'll have a more realistic environment to train for true "lack of outside
references."
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old September 20th 05, 08:45 PM
xyzzy
overloaded head.
Yes, I started IFR training in the winter of last year and did a lot of
basic manuevers and chartless approaches (talked through it by the
instructor) at night. By the time I was doing aproaches and flying
with charts, it was light at my usual training time. Now that it's
gettting dark earlier, I'm surprised at how hard it is to put together
two things I did well independently (maneuver at night under foggles +
use charts).
references."
I disagree with this. When at night under the foggles, when you fly
over towns or cities, the glow from the ground is really noticeable in
your peripherial vision. Because of this I feel like at night I'm
actually getting more visual cues than I should when under the foggles.
IMO the best VFR conditions for hood training are hazy southeastern
afternoons.
Old September 20th 05, 09:20 PM
Mark Hansen
overloaded head.
use charts).
I too saw this the first time I did a cross county IFR training flight
at night. I had to look at the chart and determine on which bearing
I was from various VORs along the route.
There is a larger work load when having to point a flashlight at the
chart, then at the panel to scan the instruments, then back to the
chart, etc.
It would have been easier if my light had been brighter, but there's
a cost associated with that (in reduced night adaptation).
references."
I agree with this as well. While training, I used to try to ignore all
the visual cues (and was able to get disoriented from time to time) -
flying at night didn't make this any easier... but I was flying over
the valley between Oakland and Sacramento - not the darkest part of
the planet to be sure.
afternoons.
Of course, as others have said - nothing beats actual IMC for giving
you respect for IMC ;-) If any pilot (or prospective pilot) hasn't
experienced it yet, they should grab an instructor and go do it; regardless
of their Instrument Rating aspirations. It will really open your eyes -
Especially if you think "How hard can it be?" ;-)
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
Old September 20th 05, 10:19 PM
: It would have been easier if my light had been brighter, but there's
: a cost associated with that (in reduced night adaptation).
Just for the record, I have made (IMO) the perfect chart light for night
flying. I took a regular minimag flashlight (2-AA type) and replaced the bulb with a
single green LED. The smaller one (3/4 T or something... don't remember the size
packages of LEDs offhand) is almost the same size as the original light bulb. I had
to rig in a resistor (47 Ohm IIRC) in between the two AA's to limit the current.
Anyway, bottom line is that it's just enough light to read the features of the
chart easily, but not too much to destroy your night vision. Useless as a regular
flashlight, but it's perfect for charts and it'll last almost forever on a single set
of batteries.
: I agree with this as well. While training, I used to try to ignore all
: the visual cues (and was able to get disoriented from time to time) -
: flying at night didn't make this any easier... but I was flying over
: the valley between Oakland and Sacramento - not the darkest part of
: the planet to be sure.
I'm a bit skewed. Here in the mountains southwest Virginia, there aren't all
that many lights. Certainly little "glow from below". You'd have to see the lights
out of your peripheral vision to get references from them. I found daylight shadows
moving (and my fixed-pitch prop loading/unloading the engine) the most irritating
"cheats" to simulated IMC.
: IMO the best VFR conditions for hood training are hazy southeastern
: afternoons.
: Of course, as others have said - nothing beats actual IMC for giving
: you respect for IMC ;-) If any pilot (or prospective pilot) hasn't
: experienced it yet, they should grab an instructor and go do it; regardless
: of their Instrument Rating aspirations. It will really open your eyes -
: Especially if you think "How hard can it be?" ;-)
Absolutely agree. My instructor had me do actual for some of my instrument
work for my private. It was a nice, February high overcast chilly day... spent about
20 minutes 500' up in a solid overcast (but above MEA for the area). It felt like 20
hours and I never knew I could sweat so quickly. Here I am... probably about 30 hours
total, flying in solid soup using 98% of my brainpower to keep the shiny side up.
Instructor leans over and points at the windshield saying, "See that? That's airframe
ice."
Anyway... enough to instantly instill respect for IMC and icing. Good
experience to have under controlled circumstances so you don't blunder into it
yourself.
-Cory
* Cory Papenfuss *
Old September 21st 05, 06:28 AM
Stan Gosnell
wrote in
for night
the bulb with a single green LED. The smaller one (3/4 T or
something... don't remember the size packages of LEDs offhand) is
almost the same size as the original light bulb. I had to rig in a
I have a minimag that uses AAA batteries, and put a green LED in it. The
T3 is the right size. I got it from Mouser. I haven't seen the need for
a resistor - it just plugs into the holes for the regular bulb. I wear
it on a lanyard around my neck so I can always find it. But I seldom use
this. I normally use a cheap headlight, which has 2 bright white bulbs
and a single green LED. It came with red, but I changed it out for
green. The white is very useful for preflights and startup, and the
green works well for flying. It always points where I'm looking, and
doesn't blind my FO when I need to read charts and do the company
paperwork. I also carry a regular AA minimag, with a 2 Amp LED bulb and
a diffusion lens, for when I really need light, especially for preflight
walkarounds. White LEDs are great for preflights, because the synthetic
turbine oil in the sightglasses can be hard to see using a weak yellow
incandescent lens. The white LED light makes it show up very well.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old September 20th 05, 02:32 PM
Brad Zeigler
Instrument.
As an instrument instructor, I prefer teaching instruments at night. Here's
why:
1) It's more realistic to simulate instrument conditions in VMC at night.
2) Most airports seem to be less busy so busting into the pattern from a
practice approach is less problematic.
3) In my area, ATC tends to be less busy so controllers tend to be more
patient with my students
4) The air is smoother (although sometimes its *too* smooth)
5) the night environment forces good cockpit management habits. Fishing
around for a chart is harder at night when they all look alike in the dark.
There are challenges and risks though...
1) I tend not to do aggressive unusual attitudes or stalls at night. At
night a stall is an instrument manuever for both the student and the
instructor, especially on a dark night with no moon.
2) Some fields do not allow practice approachs later in the evening. My
local class C doesn't allow them after 10pm, presumably for noise abatement.
3) Airports services are less likely to be available...locked FBOs, no fuel
truck, empty vending machines, etc.
4) Greater potential for ground fog...must watch the temperature dewpoint
spread.
5) less options available for forced or precautionary landings. Highways and
parking lots become viable options.
6) night generally occurs at the end of the day, so stress and rest are
factors for both the student and the instructor. An IMSAFE audit is real
important.
I will fly in IMC at night in a single provided:
1) I am familiar with the aircraft. While engine failure can occur anytime
to any engine, the probability is much less on a well maintained aircraft.
2) We are over flat terrain. I will fly over mountains (east coast
mountains, that is) at night in VMC provided we have enough visibility,
altitude and options below us (i.e. valleys, highways, etc.)
3) We have a GPS with an independent electrical source. This is my rule for
day IMC as well.
Old September 20th 05, 09:09 PM
pgbnh
Most definitely do some instrument training at night. As others have said,
you do not want your first encounter to be real IMC when it is real dark.
Having said that, I add the following:
Do some night IFR simulated in VMC with a competent instructor
Do some night IFR in ACTUAL IMC, but with good enough visibiity and high
enough ceilings to provide an 'out' if you need it (I would vote for a
4-5000 ceiling and 5-8 vis.). These are my personal minimums for night IFR.
I scared the crap out of myself with a night flight in actual, with family
aboard, and about 1000/3. Will not do it again.
Instrument.
Old September 21st 05, 01:57 AM
A Lieberman
Having the fact that I own my plane, I would fly at night in a heart beat.
I had my engine overhauled shortly after I bought the plane, and I have
managed to nurse my plane to where every button, knob and lever works. It
took me 2 years to get to this point.
Having said this, my first night flight in IMC was not expected. I managed
to get 8.6 actual in the daylight (all training flights) before my first
night cross country flight in actual conditions.
My flight from Stuebenville Ohio to Madison MS, when I left, the forecast
was for severe clear on departure. I knew I would be flying 2 hours after
sunset.
I planned a fuel stop in Bowling Green KY. It was at that fuel stop where
I found out the cold front that was suppose to move south instead became
stationary and turned into a warm front. I had got a flight briefing the
night before, but didn't get one that morning, so I was surprised how
quickly things had changed.
It was severe clear on my first leg, and it was bumpier then I am used to
(should have been my first clue the weather pattern was changing).
Night IFR in the clouds, TO ME, was actually easier then severe clear. The
nav lights gave a very soft glow inside the clouds, making it a soft grey
rather then pitch black. So, while I had to continuously scan my
instruments, I found the nav lights a rather soothing feeling, that I
wasn't in a dark hole and to rest my eyes, I would look at each wing tip to
force myself not to focus on one instrument. I felt no different flying
night IFR then flying VFR as my instrument scan was the same.
I was in and out of rain showers at night, and the only way I knew this was
from hearing the rain beat on the windshield. It was bumpier then all get
out in the clouds, and ATC was more then accommodating when I ask for
altitude changes.
For this flight, I flew 2.5 in actual conditions at night which terminated
as an VOR Alpa approach where I broke out at 1400 feet at MBO.
There is a lot more work at night in cockpit management. You can't just
glance down and pick up a chart, you must be organized. If you have good
cockpit management at night, day IFR operations will be that much simpler.
Radio is much quieter at night! Almost too quiet! I would fly 10 minutes
without hearing a voice. While that is nice in some respect, it also makes
you paranoid, did I lose my radios.
The plane doesn't care if it's IMC or severe clear, day or night. As long
as you have a plane you can trust your life in the daytime, night time IFR
is no different in my opinion.
After all, when you are in the clag, you won't have too many landing
options to look for anyway especially if ceilings are only 1000 feet day or
night.
So, to answer your question, based on my experienced, a big yes, night IFR
training would be a good idea.
Allen
Hey! What fun!! Let's let them kill ourselves!!! [email protected] Naval Aviation 2 December 17th 04 09:45 PM
Student night solo? Peter MacPherson Piloting 50 November 10th 04 01:51 AM
Why was the Fokker D VII A Good Plane? Matthew G. Saroff Military Aviation 111 May 4th 04 05:34 PM
CFI logging instrument time Barry Instrument Flight Rules 21 November 11th 03 12:23 AM
