On Sat, 3 Dec 2005 09:59:30 -0800, "Bob Gardner"
wrote in :: Rachel, you will have a heck of a time trying to find a rental. Of course, one can always purchase one: http://www.cubcrafters.com/cci/airpl...PartID=174 96 |
Don't forget Legend Aircraft for the Legend Cub.
"Larry Dighera" wrote in message ... | On Sat, 3 Dec 2005 09:59:30 -0800, "Bob Gardner" | wrote in :: | | Rachel, you will have a heck of a time trying to find a rental. | | Of course, one can always purchase one: | http://www.cubcrafters.com/cci/airpl...PartID=174 96 |
On Sun, 4 Dec 2005 23:58:05 -0600, "Jim Macklin"
wrote in tKQkf.11646$QW2.11307@dukeread08:: Don't forget Legend Aircraft for the Legend Cub. http://www.legend.aero/index.cfm Base price configuration of $74,000, The American Legend Cub is a LSA, so a pilot won't need a medical to fly it, but it's only 100 HP, and lacks the performance of the Cubcrafters 180 HP product (base price about double the Legend). There's a good Legend Cub article he http://www.flyingmag.com/article.asp...age_numb er=1 |
![]() "Larry Dighera" wrote in message ... On Sun, 4 Dec 2005 23:58:05 -0600, "Jim Macklin" wrote in tKQkf.11646$QW2.11307@dukeread08:: Don't forget Legend Aircraft for the Legend Cub. http://www.legend.aero/index.cfm Base price configuration of $74,000, The American Legend Cub is a LSA, so a pilot won't need a medical to fly it, but it's only 100 HP, and lacks the performance of the Cubcrafters 180 HP product (base price about double the Legend). There's a good Legend Cub article he http://www.flyingmag.com/article.asp...age_numb er=1 The only one worth considering http://www.seawind.biz/ |
On Mon, 05 Dec 2005 18:05:19 GMT, "Steph"
wrote in zj%kf.47416$ki.307@pd7tw2no:: "Larry Dighera" wrote in message .. . On Sun, 4 Dec 2005 23:58:05 -0600, "Jim Macklin" wrote in tKQkf.11646$QW2.11307@dukeread08:: Don't forget Legend Aircraft for the Legend Cub. http://www.legend.aero/index.cfm Base price configuration of $74,000, The American Legend Cub is a LSA, so a pilot won't need a medical to fly it, but it's only 100 HP, and lacks the performance of the Cubcrafters 180 HP product (base price about double the Legend). There's a good Legend Cub article he http://www.flyingmag.com/article.asp...age_numb er=1 The only one worth considering http://www.seawind.biz/ I always thought a high-wing would permit landing in rougher water, because of the added height of the wing above the waves. Perhaps someone with some seaplane experience can comment on that aspect. |
Larry Dighera wrote:
I always thought a high-wing would permit landing in rougher water, because of the added height of the wing above the waves. Perhaps someone with some seaplane experience can comment on that aspect. Getting your prop into the water is considered bad thing... |
... The only one worth considering http://www.seawind.biz/ I always thought a high-wing would permit landing in rougher water, because of the added height of the wing above the waves. Perhaps someone with some seaplane experience can comment on that aspect. The position of the wing doesn't affect the water conditions limiting the airplane so much, as does the hull design, whether it's the entire fuselage as the hull or attached floats (a "steeper" hull generally gives better rough-water performance). Note the the new Russian seaplane that has a low-wing design (not even mid-wing, like the Seawind or similar airplanes). It appears to be able to handle waves of roughly the same height as any similarly sized airplane, from the pilot reports I've read. As far as protecting the prop goes... Engine on top may protect the prop in some situations. However, because top-mounted engines are generally pusher engines, they actually are more susceptible in other situations, because spray comes off the hull and heads backwards over the wing and into the prop. At the high angles of attack when the spray is at its greatest, a front-mounted prop may be reasonably away from the spray. In the end, neither design is necessarily better than the other; prop erosion is a fact of life for any seaplane. IMHO, two genuinely important questions with respect to wing position are where and how you interface with land, and stability during turns on the water. A low wing position allows for a lower center of gravity and better stability (though mitigated somewhat by having the engine up high). A high wing position gives the airplane more clearance around solid objects, like docks, rocks, and the like. Finally, you can always be assured, practically anytime someone precedes a statement with a phrase like "the only one worth considering", they are either intentionally engaging in hyperbole, or they are an idiot. It is exceedingly rare for a single airplane to be THE ONLY viable choice for a given application, even when the application is defined narrowly (like "you need to be able to transport a 747 fuselage in one piece"). When the application is defined as broadly as "seaplane", there's no such thing as "the only". Pete |
The ability to land in rough water is limited by the hull strength.
Pontoon type floats have struts and the struts can break. Hull type aircraft such as a Lake use the hull itself to land on, no struts. Although you CAN break anything, usually hull type aircraft can land on the incoming wave's backside (the worst spot), hit and not breakup HARDER than can pontoon aircraft. Of course it depends on the plane. Larger planes tend to do better. But even the Beavers and such can break a strut. Usually when the waves start whitecapping, 15knot winds or so, small GA planes can no longer land safely on whitecapping waves. But there are waves and there are other waves, it all depends. Like Pete said, high wings tend to be able to get into docks better because their wings clear the docks. Low wing planes usually wont clear, so you can't get the fuselage up next to the dock. |
("Larry Dighera" wrote)
The American Legend Cub is a LSA, so a pilot won't need a medical to fly it, ... Question: Is it a LSA or an LSA? I can see "a" ...for a Light Sport Aircraft But here, is it "an" ...for an (L)SA as in elephant? Curious. My eyes see it one way, my ears hear it another. Montblack Never met a comma I didn't like. |
"Montblack" wrote in message
... ("Larry Dighera" wrote) The American Legend Cub is a LSA, so a pilot won't need a medical to fly it, ... Question: Is it a LSA or an LSA? I can see "a" ...for a Light Sport Aircraft But here, is it "an" ...for an (L)SA as in elephant? Curious. My eyes see it one way, my ears hear it another. Montblack Never met a comma I didn't like. I believe it would be an "a" because of how the first word that is abbreviated is actually pronounced. A Light ... and not An Light ... Jay Beckman I Are An College Graduate |
FA: (One Day Left) - 6 BOOKS - FAR, AIM, IFR, AOPA, P-47, Seaplanes... | Josh | Aviation Marketplace | 0 | November 13th 04 01:23 PM |
FA: 6 AVIATION FLYING BOOKS - FAR, AIM, IFR, AOPA, P-47, Seaplanes... | Nemo | Aviation Marketplace | 0 | November 7th 04 08:11 PM |
Question about Seaplanes | Sami | Aviation Marketplace | 11 | September 23rd 04 02:04 AM |
Jet Seaplanes??? | Roy Smith | General Aviation | 7 | August 23rd 04 11:29 AM |
Seaplanes and insurance | Robert M. Gary | Piloting | 1 | August 1st 03 05:55 PM |
