![]() "Phil Miller" wrote in message ... Robert is being rediculess to claim that a pitot tube produces some total pressure and then the static port pressure is subtracted twice to make IAS. The whole point of using a static port is to be able to take the guts out of a pitot tube and produce only pitot pressure, thus increasing the reliability of the system. Perhaps this will help: "Tarver Engineering" wrote: "Gord Beaman" wrote in message .. . "Jim Knoyle" wrote: Hang on here a second now Jim, you still need two samples. As Dan says you need 'static pressure' to read the altitude from and you need 'pitot pressure' (ram air pressure) as well as the static pressure to derive the airspeed reading from. Sounds like you're saying that you can read 'both' from just the 'ram air pressure' alone. Or did I misunderstand you? Jim has finally figued out what a pitot tube is, but somehow he still wants to be correct in his archive troll. It is a great paradox. I know...ain't life a bitch John ![]() ![]() -- -Gord. |
On Thu, 26 Feb 2004 19:25:26 -0800, "Tarver Engineering"
wrote: "Phil Miller" wrote in message .. . Robert is being rediculess to claim that a pitot tube produces some total pressure and then the static port pressure is subtracted twice to make IAS. The whole point of using a static port is to be able to take the guts out of a pitot tube and produce only pitot pressure, thus increasing the reliability of the system. Perhaps this will help: Yes that does help, because what Robert said and what Gord said are practically identical. "Gord Beaman" wrote in message . .. Hang on here a second now Jim, you still need two samples. As Dan says you need 'static pressure' to read the altitude from and you need 'pitot pressure' (ram air pressure) as well as the static pressure to derive the airspeed reading from. On Thu, 26 Feb 2004 21:06:41 GMT, Robert Moore wrote: The Pitot Pressure from the Pitot Tube is a combination of Static and RAM pressure. The bellows inside the airspeed indicator uses the ambient static pressure from the static port to cancel out the static component from the Pitot Tube leaving only the RAM component to move the airspeed needle. Phil -- Great Tarverisms #2 What is the best selling beer in Oz? Budweiser. Another illusion shattered. John alt.disasters.aviation 18 August 2002 |
On Fri, 27 Feb 2004 14:33:43 +1100, Phil Miller
wrote: On Thu, 26 Feb 2004 19:25:26 -0800, "Tarver Engineering" wrote: "Phil Miller" wrote in message . .. Robert is being rediculess to claim that a pitot tube produces some total pressure and then the static port pressure is subtracted twice to make IAS. The whole point of using a static port is to be able to take the guts out of a pitot tube and produce only pitot pressure, thus increasing the reliability of the system. Perhaps this will help: Yes that does help, because what Robert said and what Gord said are practically identical. Oh! And you didn't enlighten me about the Bombardier GBX? Phil -- Great Tarverisms #1 The Air Speed Indicator (ASI) shows You made that up, didn't you? The IAS indicator says IAS, not ASI. Why do you come here pretending to know something when you don't even know the words? John |
