Anybody know whether this is an airworthiness issue? I was flying CAP cadets
today and discovered the problem. We have a kid taking a private ride on Monday and would not like to switch airplanes on him. Obviously it's not on the required VFR equipment list, but since without it you no longer know the airframe or engine hours for ADs, inspections, etc. it seems to me that there is likely to be a requirement for it buried somewhere. TIA |
The aircraft time is recorded by the tachometer in most
cases and the Hobbs meter is used to record time for billing users. But if the tach works for RPM, you should be able to log the hours from the clock/wrist watch and note the inop condition of the hourmeter. When the tach is replaced the new total time will be entered in the logbook. See the required equipment list in the POH to see what is required. As long as the RPM is working, the hour/meter portion should be placarded as "inop, record clock time in the logbook" to meet the airworthiness requirements. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Mitty" wrote in message ... | Anybody know whether this is an airworthiness issue? I was flying CAP cadets | today and discovered the problem. We have a kid taking a private ride on Monday | and would not like to switch airplanes on him. | | Obviously it's not on the required VFR equipment list, but since without it you | no longer know the airframe or engine hours for ADs, inspections, etc. it seems | to me that there is likely to be a requirement for it buried somewhere. | | TIA |
... Anybody know whether this is an airworthiness issue? I was flying CAP cadets today and discovered the problem. We have a kid taking a private ride on Monday and would not like to switch airplanes on him. Obviously it's not on the required VFR equipment list, but since without it you no longer know the airframe or engine hours for ADs, inspections, etc. it seems to me that there is likely to be a requirement for it buried somewhere. So long as hours are recorded by some other reasonable means (e.g. simply by looking at the clock) and the precise nature of the measurement is known and, preferably, documented (e.g. whether it's the time from startup to shutdown, or the time from brakes off to brakes on), there should be no problem. Actually I've only ever used one aircraft whose owner charged based on the time recorded from the Hobbs meter - everything else has been a case of looking at your wris****ch and recording the time from brakes off to brakes on. Actually I like this idea, because it removes the financial incentive to rush your after-start and power checks. D. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
First 2 1/2 hours PPL(H) today! | Simon Robbins | Rotorcraft | 42 | September 25th 05 12:54 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
