![]() "bBob" wrote in message news:r5qUf.4989$hC.1856@trnddc08... "jerry wass" wrote in message ... There is a red sealant the auto atores are handling now that is even approved by faa (so I waS told) it acts like an anaerobic sealer with silicone rubber in it. forgot the number--in a red tube quite a bit higher than the other types, but well worth it. Jerry Is it like the red sealant shown here? http://tinyurl.com/znk34 Be careful with sealants on aircraft engine cases. Continental specified a single silk thread because it would compress to almost nothing and still seal the case halves. Remember, with most aircraft engines the main bearings are held by the two case halves. Anything that causes the seam to widen at all reduces the crush on the main bearings and can contribute to early bearing failure. If the case halves are true and they are properly bolted up no sealant other than the single silk thread is required. Don't mess up your main bearings trying to get the case to not leak a tiny amount. It isn't worth it. Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) A reminder, the 11th annual rec.aviation flyin that started here many years ago is coming up May 19, 20, and 21 at Pinckneyville. If you are planning to come please let Mary know at so that she can make sure to have enough steaks on hand to dinner. :-) |
![]() "Highflyer" wrote in message ... "bBob" wrote in message news:r5qUf.4989$hC.1856@trnddc08... "jerry wass" wrote in message ... There is a red sealant the auto atores are handling now that is even approved by faa (so I waS told) it acts like an anaerobic sealer with silicone rubber in it. forgot the number--in a red tube quite a bit higher than the other types, but well worth it. Jerry Is it like the red sealant shown here? http://tinyurl.com/znk34 Be careful with sealants on aircraft engine cases. Continental specified a single silk thread because it would compress to almost nothing and still seal the case halves. Remember, with most aircraft engines the main bearings are held by the two case halves. Anything that causes the seam to widen at all reduces the crush on the main bearings and can contribute to early bearing failure. If the case halves are true and they are properly bolted up no sealant other than the single silk thread is required. Don't mess up your main bearings trying to get the case to not leak a tiny amount. It isn't worth it. Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) A reminder, the 11th annual rec.aviation flyin that started here many years ago is coming up May 19, 20, and 21 at Pinckneyville. If you are planning to come please let Mary know at so that she can make sure to have enough steaks on hand to dinner. :-) That being said, my learned friend, I notice that in TCM's IO-360 overhaul manual, section 72-60-02(G) the following: Spread a thin continuous film of No. 3 Aviation Permatex on the left crankcase parting flange. ... Lay lengths of No. 50 silk thread on parting flange. Thread should be on inside of bolt holes but never on the flange edge. ... Stand No. 1, 3, and 5 rods upright. Being sure that thrust washers have been installed and are properly seated, carefully lower the right crankcase onto the left crankcase. (close quote) Not that a silk thread by itself won't seal, but I have never seen case halves put back together without sealant in addition to silk thread. You could be reasonably sure of proper bearing crush by pre-assembling the case halves over the crank and cam using plastigage. The crush on the plastic thread flattens it out, giving you a clearance measurement in thousandths. One more caution: always check to see if service bulletins supersede instructions in the overhaul manual. |
Highflyer wrote:
"bBob" wrote in message news:r5qUf.4989$hC.1856@trnddc08... "jerry wass" wrote in message ... There is a red sealant the auto atores are handling now that is even approved by faa (so I waS told) it acts like an anaerobic sealer with silicone rubber in it. forgot the number--in a red tube quite a bit higher than the other types, but well worth it. Jerry Is it like the red sealant shown here? NOPE--I'll go get the number & mail you back---JJW http://tinyurl.com/znk34 Be careful with sealants on aircraft engine cases. Continental specified a single silk thread because it would compress to almost nothing and still seal the case halves. Remember, with most aircraft engines the main bearings are held by the two case halves. Anything that causes the seam to widen at all reduces the crush on the main bearings and can contribute to early bearing failure. If the case halves are true and they are properly bolted up no sealant other than the single silk thread is required. Don't mess up your main bearings trying to get the case to not leak a tiny amount. It isn't worth it. Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) A reminder, the 11th annual rec.aviation flyin that started here many years ago is coming up May 19, 20, and 21 at Pinckneyville. If you are planning to come please let Mary know at so that she can make sure to have enough steaks on hand to dinner. :-) |
jerry wass wrote:
Highflyer wrote: "bBob" wrote in message news:r5qUf.4989$hC.1856@trnddc08... "jerry wass" wrote in message ... There is a red sealant the auto atores are handling now that is even approved by faa (so I waS told) it acts like an anaerobic sealer with silicone rubber in it. forgot the number--in a red tube quite a bit higher than the other types, but well worth it. Jerry Well, it used to be in a red tube, made by someone who got bought by Permatex--now in blue tube--Still red sealant---NAME-Permatex Anaroebic gasket maker--automotive grade--part # 51313 Is it like the red sealant shown here? NOPE--I'll go get the number & mail you back---JJW http://tinyurl.com/znk34 Be careful with sealants on aircraft engine cases. Continental specified a single silk thread because it would compress to almost nothing and still seal the case halves. Remember, with most aircraft engines the main bearings are held by the two case halves. Anything that causes the seam to widen at all reduces the crush on the main bearings and can contribute to early bearing failure. If the case halves are true and they are properly bolted up no sealant other than the single silk thread is required. Don't mess up your main bearings trying to get the case to not leak a tiny amount. It isn't worth it. Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) A reminder, the 11th annual rec.aviation flyin that started here many years ago is coming up May 19, 20, and 21 at Pinckneyville. If you are planning to come please let Mary know at so that she can make sure to have enough steaks on hand to dinner. :-) |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
ROP masking of engine problems | Roger Long | Piloting | 1 | September 25th 04 07:13 PM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
