You DON'T want to add any capacitors to the P leads!
Have you adjusted the gain, squelch and mike gain (I think that's the nomenclature) on your I-Com radio? The I-com I have is a very sensitive radio. You just may have the squelch incorrectly set (I. e. too sensitive) for your installation. You have to remove the radio from the tray to get access to these 3 controls. A key point - do you get mag noise overriding on normal radio receive signals? or just when the radio breaks squelch? That would tell you if the mags etc are radiating excessive noise. |
Thanks for the great replies. The ICOM radio's squelch is a part of
the volume control. You pull it out and hear the squelch and turning the knob just adjusts the volume of it. If you push it in the squelch noise stops. Doen't seem to me that the squelch is really controllable except to change the volume of it, which also changes the radio volume. I never knew about a squelch and gain controls on the back of the radio. I don't have the manual with me. I'm now at a remote airstrip where there is hardly any radio traffic, so I'll have to get someone to transmit while I try it out. I called Aircraft Spruces radio shop and got a little feedback from a tech. He said to first check out my spark plug connections. He said loosen them one by one and then retighten them. He said that's a common cause of noise. And now that I think of it, I had the CHT wire break and to fix it, one spark plug had to be removed, so I better start with that one. I guess I could actually disconnect that one plug and run the engine to see if the noise disappears. If that doesn't work, he recommends a new ignition harness, which isn't too painfully expensive. Thanks again for the help, especially forgetting about using an external capacitor. Is that what those mag filters basically are? |
![]() "Kensandyeggo" wrote in message oups.com... Thanks for the great replies. The ICOM radio's squelch is a part of the volume control. You pull it out and hear the squelch and turning the knob just adjusts the volume of it. If you push it in the squelch noise stops. Doen't seem to me that the squelch is really controllable except to change the volume of it, which also changes the radio volume. The radio has adjustable squelch. The adjustment is on top of the radio IIRC and should have a piece of tape over the adjustment hole. There is also a sidetone adjustment so make sure you get the correct one. |
Pulling the knob out is the override for the squelch. That's not your
problem. By pulling the volume knob out, you are simply disabling the squelch so that you hear whatever is being received. That would be a lot of static with no real signal for the receiver to latch on to. Turning that knob adjusts the volume of the received signal regardless of whether the knob is in or out. A typical scenario is to listen to ATIS, contact ground, contact tower, etc. Listening to ATIS allowed you to make sure that your volume was up high enough to hear responses from the tower. But, if you were at an airport that did not have an ATIS, you might pull the knob out to make sure that the volume is up high enough to hear any responses on CTAF as you leave the area. Adjust the volume so that the static is at a tolerable level, then push it in. Or, if you are trying to pick up a weak signal (far away ATIS or ATC), you can pull the knob out so that you hear whatever is transmitted as best you can. Of course, there will be a lot of noise as well. If the received signal is strong enough to quiet the noise, then it is probably strong enough to break squelch too. With the knob in for normal operation, the squelch is only broken when the received signal exceeds the set squelch. If you are in a noisy area or your installation is noisy, the squelch level needs to be adjusted. nrp posted the correct information. The limit is set by a "hidden" adjustment. For a demonstration of this, the ICOM and Vertex handheld radios have similar capabilities. I'm sure others do too. I just know that those do. There is a button on the side that can temporarily disable the squelch. To change the squelch threshold, you have to go into the settings mode. Ideally, you would adjust the squelch level down so that the normal noise level breaks the squelch. Then take the squelch level up a number or two. You want a quiet radio except when there is a transmission that is strong enough to break squelch and be heard clearly. If a transmission breaks the squelch but is too weak to be heard clearly, then the squelch is probably too low. That goes for the handhled and for the panel mounted. That sounds like what you are describing. Although, just increasing the squelch level will also supress weak transmissions that you might want to hear. Trying to make the installed environment as quiet as possible is a good goal. Time to get out a hex wrench and a jeweler's screwdriver... ------------------------------- Travis Lake N3094P PWK "Kensandyeggo" wrote in message oups.com... Thanks for the great replies. The ICOM radio's squelch is a part of the volume control. You pull it out and hear the squelch and turning the knob just adjusts the volume of it. If you push it in the squelch noise stops. Doen't seem to me that the squelch is really controllable except to change the volume of it, which also changes the radio volume. I never knew about a squelch and gain controls on the back of the radio. I don't have the manual with me. I'm now at a remote airstrip where there is hardly any radio traffic, so I'll have to get someone to transmit while I try it out. I called Aircraft Spruces radio shop and got a little feedback from a tech. He said to first check out my spark plug connections. He said loosen them one by one and then retighten them. He said that's a common cause of noise. And now that I think of it, I had the CHT wire break and to fix it, one spark plug had to be removed, so I better start with that one. I guess I could actually disconnect that one plug and run the engine to see if the noise disappears. If that doesn't work, he recommends a new ignition harness, which isn't too painfully expensive. Thanks again for the help, especially forgetting about using an external capacitor. Is that what those mag filters basically are? |
Travis Marlatte wrote:
: If a transmission breaks the squelch but is too weak to be heard clearly, : then the squelch is probably too low. That goes for the handhled and for the : panel mounted. That sounds like what you are describing. Although, just : increasing the squelch level will also supress weak transmissions that you : might want to hear. Trying to make the installed environment as quiet as : possible is a good goal. : Time to get out a hex wrench and a jeweler's screwdriver... Not necessarily a good idea. I thought I'd be clever and adjust the squelch on my KY-197 to crank it up a bit. Turns out there were two pots, and they were very sensitive to adjustment (read: I screwed it all up and couldn't get it back reasonable again). I had to obtain the relevant pages in the service manual, put it on the bench with an RF signal generator and some attenuators to get the adjustment back within spec. It's still a little bit twitchy and sensitive to noise and opening squelch, but I *know* it's adjusted to the book now and I'm not going to touch it anymore. Other radios may be more forgiving, but I know this one wasn't. You may be wishing you hadn't fiddled with that particular "knob." -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
The capacitors in the mag filters are there to form a resonant spark
(electrical) tank circuit with the inductance of the magneto coils and protect the ma=gneto points. If you hang additional capacitors on the P leads, the mag functions will get completely screwed up as the resonant frequency of the spark tank system will be depressed - if they even work at all. I should have mentioned that the three controls I noted are accessible thru the top cover of the radio once it is removed. Mess with it gradually and carefully. The ICom radio is very sensitive. Even with my squelch setting modified I'm still picking up transmissions from over 125 miles away. I wish the squelch was more user real time accessible. |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
Cherokee Strobe Noise | Jonathan Goodish | Owning | 20 | November 2nd 04 02:42 AM |
Funny noise update | Peter Duniho | Piloting | 1 | July 1st 04 02:58 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
