"Will" wrote:
It may just be personal preference, but I see a lot of value in user interfaces that make the data quality a primary display attribute at all times. That way I not only know I have a GPS signal, but I can quickly assess the quality of the signal. I see value in making this more than just a binary state ("good enough for the FAA" GPS signal quality / "not good enough for the FAA" GPS signal quality). Possibly that data could be colored or made to blink in situations where integrity is compromised sufficiently. I disagree. We already have information overload. A binary "go/no-go" is exactly what you want. If I told you that the SNR from satellite 17 was down 6dB, what would you do with that information? RAIM factors in signal strength as well as satellite geometry. To get a good fix, you need to be getting a good signal from 4 satellites positioned appropriately in both azimuth and elevation. Figuring out if the signal strength and geometry is "good enough" is not the kind of problem people can do in their heads. |
Roy Smith wrote:
"Will" wrote: It may just be personal preference, but I see a lot of value in user interfaces that make the data quality a primary display attribute at all times. That way I not only know I have a GPS signal, but I can quickly assess the quality of the signal. I see value in making this more than just a binary state ("good enough for the FAA" GPS signal quality / "not good enough for the FAA" GPS signal quality). Possibly that data could be colored or made to blink in situations where integrity is compromised sufficiently. I disagree. We already have information overload. A binary "go/no-go" is exactly what you want. If I told you that the SNR from satellite 17 was down 6dB, what would you do with that information? RAIM factors in signal strength as well as satellite geometry. To get a good fix, you need to be getting a good signal from 4 satellites positioned appropriately in both azimuth and elevation. Figuring out if the signal strength and geometry is "good enough" is not the kind of problem people can do in their heads. I'm somewhat surprised that no one has mentioned that both the Garmin and Lowrance units that I'm familiar with have a page for satelitte signal strength. I've never felt the need to run thru the 430/530 pages to find a similar page but would not be surprised to find it buried in there somewhere. To answer the OP's question it's there you just need to read the manual to find which sub-menu it's on. If he's using a non-aviation unit then all bets are off but again I would think it would be there somewhere. Also on the units I use regularly the airplane icon flashs on the main display when the signal is lost ala a pseudo RAIM indicator |
John Theune wrote:
.. I'm somewhat surprised that no one has mentioned that both the Garmin and Lowrance units that I'm familiar with have a page for satelitte signal strength. Page 4 of the nav section. |
On 04/25/06 05:03, John Theune wrote:
Roy Smith wrote: "Will" wrote: It may just be personal preference, but I see a lot of value in user interfaces that make the data quality a primary display attribute at all times. That way I not only know I have a GPS signal, but I can quickly assess the quality of the signal. I see value in making this more than just a binary state ("good enough for the FAA" GPS signal quality / "not good enough for the FAA" GPS signal quality). Possibly that data could be colored or made to blink in situations where integrity is compromised sufficiently. I disagree. We already have information overload. A binary "go/no-go" is exactly what you want. If I told you that the SNR from satellite 17 was down 6dB, what would you do with that information? RAIM factors in signal strength as well as satellite geometry. To get a good fix, you need to be getting a good signal from 4 satellites positioned appropriately in both azimuth and elevation. Figuring out if the signal strength and geometry is "good enough" is not the kind of problem people can do in their heads. I'm somewhat surprised that no one has mentioned that both the Garmin and Lowrance units that I'm familiar with have a page for satelitte signal strength. I've never felt the need to run thru the 430/530 pages to find a similar page but would not be surprised to find it buried in there somewhere. To answer the OP's question it's there you just need to read the manual to find which sub-menu it's on. If he's using a non-aviation unit then all bets are off but again I would think it would be there somewhere. Also on the units I use regularly the airplane icon flashs on the main display when the signal is lost ala a pseudo RAIM indicator The OP was asking why this can't be displayed on the main page... You snipped it from your response. Here it is: Is there any way to have the Garmin 430/530 put its current display accuracy on the primary display as an ongoing statistic, based on the number of satellites in view? -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
![]() "John Theune" wrote in message news:Udo3g.5009$bU6.3635@trnddc06... I'm somewhat surprised that no one has mentioned that both the Garmin and Lowrance units that I'm familiar with have a page for satelitte signal strength. I've never felt the need to run thru the 430/530 pages to find a similar page but would not be surprised to find it buried in there somewhere. To answer the OP's question it's there you just need to read the manual to find which sub-menu it's on. If he's using a non-aviation unit then all bets are off but again I would think it would be there somewhere. Also on the units I use regularly the airplane icon flashs on the main display when the signal is lost ala a pseudo RAIM indicator You are right all GPS software usually implements a satellite signal page. It's not in any way shape or form what I asked for. I want the GPS to take all of the inputs for number of satellites and signal strength and derive from that just two integers: 1) Number of feet/meters of horizontal accuracy, within some confidence interval (e.g., 99.95%) 2) Number of feet/meters of vertical accuracy, within some confidence interval (e.g., 99.95%) Those two numbers could become optional numbers for the primary display. No one is forcing anyone to use them. If you want to simply trust the instrument to give you a go-nogo decision, it's your life and if you feel that is safe it's a free world (as long as you follow FAA rules ![]() my guest. For my personal taste, I understand that a GPS display is always an illusion subject to different levels of inaccuracy. I am sensitive to the difference between a display that is showing me accuracy to 10 ft, 100 ft, or 1000 ft. In the original posted example the GPS was off target by more than 5000 ft. Nothing on the original display gave me any clue that this was the case. The two numbers I am asking for would communicate quite succinctly that no one should rely on the display for anything other than the most gross kind of positioning. While I would love to see the feature I am looking for in any FAA-compliant instrument like a Garmin 530, I think the feature becomes most critical in non-FAA compliant GPS devices/software. The authors of such packages cannot control the quality of the satellite antenna, or mounting, and substandard GPS reception is probably a routine thing for PDA based GPS devices/software. So finding a succinct way to communicate the accuracy of the current signal in numbers that mean something to any user becomes quite important. Making people look at satellite maps and signal strength seems like a pure engineering exercise, and it doesn't collapse the input data into a useful form. -- Will |
Will wrote:
"John Theune" wrote in message news:Udo3g.5009$bU6.3635@trnddc06... I'm somewhat surprised that no one has mentioned that both the Garmin and Lowrance units that I'm familiar with have a page for satelitte signal strength. I've never felt the need to run thru the 430/530 pages to find a similar page but would not be surprised to find it buried in there somewhere. To answer the OP's question it's there you just need to read the manual to find which sub-menu it's on. If he's using a non-aviation unit then all bets are off but again I would think it would be there somewhere. Also on the units I use regularly the airplane icon flashs on the main display when the signal is lost ala a pseudo RAIM indicator You are right all GPS software usually implements a satellite signal page. It's not in any way shape or form what I asked for. I want the GPS to take all of the inputs for number of satellites and signal strength and derive from that just two integers: 1) Number of feet/meters of horizontal accuracy, within some confidence interval (e.g., 99.95%) 2) Number of feet/meters of vertical accuracy, within some confidence interval (e.g., 99.95%) Those two numbers could become optional numbers for the primary display. No one is forcing anyone to use them. If you want to simply trust the instrument to give you a go-nogo decision, it's your life and if you feel that is safe it's a free world (as long as you follow FAA rules ![]() my guest. For my personal taste, I understand that a GPS display is always an illusion subject to different levels of inaccuracy. I am sensitive to the difference between a display that is showing me accuracy to 10 ft, 100 ft, or 1000 ft. In the original posted example the GPS was off target by more than 5000 ft. Nothing on the original display gave me any clue that this was the case. The two numbers I am asking for would communicate quite succinctly that no one should rely on the display for anything other than the most gross kind of positioning. While I would love to see the feature I am looking for in any FAA-compliant instrument like a Garmin 530, I think the feature becomes most critical in non-FAA compliant GPS devices/software. The authors of such packages cannot control the quality of the satellite antenna, or mounting, and substandard GPS reception is probably a routine thing for PDA based GPS devices/software. So finding a succinct way to communicate the accuracy of the current signal in numbers that mean something to any user becomes quite important. Making people look at satellite maps and signal strength seems like a pure engineering exercise, and it doesn't collapse the input data into a useful form. And right on that same page for the Lowrance unit is the EPE ( Estimated Probability of Error ) in feet for the current location. The EPE is for horizontal accuracy as the vertical accuracy is mostly meaningless for GPS as they can only give you vertical guidance from a perfect sphere and the earth does not quite fit that. vertical accuracy would require the GPS to have a complete model of the earth elevation and coralate that to the horizontal location so as to determine the actual vertical location vs calculated position. Now I spent a few moments messing with my unit and found that I can place the EPE on the main map page along side course, heading , speed and so forth. If you want to know more I suggest you look at the manual for your system. |
Read the TSO and then read the description of RAIM other
accuracy monitoring software built into the unit. -- James H. Macklin ATP,CFI,A&P "Will" wrote in message ... | | "John Theune" wrote in message | news:Udo3g.5009$bU6.3635@trnddc06... | I'm somewhat surprised that no one has mentioned that both the Garmin | and Lowrance units that I'm familiar with have a page for satelitte | signal strength. I've never felt the need to run thru the 430/530 pages | to find a similar page but would not be surprised to find it buried in | there somewhere. To answer the OP's question it's there you just need | to read the manual to find which sub-menu it's on. If he's using a | non-aviation unit then all bets are off but again I would think it would | be there somewhere. Also on the units I use regularly the airplane icon | flashs on the main display when the signal is lost ala a pseudo RAIM | indicator | | You are right all GPS software usually implements a satellite signal page. | It's not in any way shape or form what I asked for. | | I want the GPS to take all of the inputs for number of satellites and signal | strength and derive from that just two integers: | | 1) Number of feet/meters of horizontal accuracy, within some confidence | interval (e.g., 99.95%) | | 2) Number of feet/meters of vertical accuracy, within some confidence | interval (e.g., 99.95%) | | Those two numbers could become optional numbers for the primary display. | No one is forcing anyone to use them. If you want to simply trust the | instrument to give you a go-nogo decision, it's your life and if you feel | that is safe it's a free world (as long as you follow FAA rules ![]() | my guest. | | For my personal taste, I understand that a GPS display is always an illusion | subject to different levels of inaccuracy. I am sensitive to the | difference between a display that is showing me accuracy to 10 ft, 100 ft, | or 1000 ft. In the original posted example the GPS was off target by more | than 5000 ft. Nothing on the original display gave me any clue that this | was the case. The two numbers I am asking for would communicate quite | succinctly that no one should rely on the display for anything other than | the most gross kind of positioning. | | While I would love to see the feature I am looking for in any FAA-compliant | instrument like a Garmin 530, I think the feature becomes most critical in | non-FAA compliant GPS devices/software. The authors of such packages | cannot control the quality of the satellite antenna, or mounting, and | substandard GPS reception is probably a routine thing for PDA based GPS | devices/software. So finding a succinct way to communicate the accuracy of | the current signal in numbers that mean something to any user becomes quite | important. Making people look at satellite maps and signal strength seems | like a pure engineering exercise, and it doesn't collapse the input data | into a useful form. | | -- | Will | | | | |
You will never get the display you are looking for in a handheld device.
IMHO handhelds will never have RAIM. Bob Gardner "Will" wrote in message ... "John Theune" wrote in message news:Udo3g.5009$bU6.3635@trnddc06... I'm somewhat surprised that no one has mentioned that both the Garmin and Lowrance units that I'm familiar with have a page for satelitte signal strength. I've never felt the need to run thru the 430/530 pages to find a similar page but would not be surprised to find it buried in there somewhere. To answer the OP's question it's there you just need to read the manual to find which sub-menu it's on. If he's using a non-aviation unit then all bets are off but again I would think it would be there somewhere. Also on the units I use regularly the airplane icon flashs on the main display when the signal is lost ala a pseudo RAIM indicator You are right all GPS software usually implements a satellite signal page. It's not in any way shape or form what I asked for. I want the GPS to take all of the inputs for number of satellites and signal strength and derive from that just two integers: 1) Number of feet/meters of horizontal accuracy, within some confidence interval (e.g., 99.95%) 2) Number of feet/meters of vertical accuracy, within some confidence interval (e.g., 99.95%) Those two numbers could become optional numbers for the primary display. No one is forcing anyone to use them. If you want to simply trust the instrument to give you a go-nogo decision, it's your life and if you feel that is safe it's a free world (as long as you follow FAA rules ![]() be my guest. For my personal taste, I understand that a GPS display is always an illusion subject to different levels of inaccuracy. I am sensitive to the difference between a display that is showing me accuracy to 10 ft, 100 ft, or 1000 ft. In the original posted example the GPS was off target by more than 5000 ft. Nothing on the original display gave me any clue that this was the case. The two numbers I am asking for would communicate quite succinctly that no one should rely on the display for anything other than the most gross kind of positioning. While I would love to see the feature I am looking for in any FAA-compliant instrument like a Garmin 530, I think the feature becomes most critical in non-FAA compliant GPS devices/software. The authors of such packages cannot control the quality of the satellite antenna, or mounting, and substandard GPS reception is probably a routine thing for PDA based GPS devices/software. So finding a succinct way to communicate the accuracy of the current signal in numbers that mean something to any user becomes quite important. Making people look at satellite maps and signal strength seems like a pure engineering exercise, and it doesn't collapse the input data into a useful form. -- Will |
Will,
I want the GPS to take all of the inputs for number of satellites and signal strength and derive from that just two integers: What you want is in the values for PDOP, VDOP and HDOP - and EPE. -- Thomas Borchert (EDDH) |
![]() "Roy Smith" wrote in message ... I disagree. We already have information overload. A binary "go/no-go" is exactly what you want. If I told you that the SNR from satellite 17 was down 6dB, what would you do with that information? That's not useful information the way you present it. I want conclusions and not data. Specifically I want to know the number of feet/meters of accuracy of my current position, that's all. If my current accuracy is 10 ft vertical versus 100 ft vertical versus 1000 ft vertical, that means something to me about how much trust I should put in the GPS display. -- Will |
Garmin backing away from additional GDL-69 features for 430/530 products? | Andrew Gideon | Owning | 2 | September 9th 05 11:36 PM |
Inexpensive Garmin 430/530 question | vlado | Owning | 2 | May 19th 05 03:21 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
WAAS and Garmin 430/530 | DoodyButch | Owning | 23 | October 13th 03 04:06 AM |
Garmin 430/530 Questions | Steve Coleman | Instrument Flight Rules | 16 | August 28th 03 09:04 PM |
