It could be your high end fuel flow is not sufficient. (Yes there is
also a low end setting also.) When you do a normal take off at full rich, does the FF needle go to just about the redline? John soxinbox wrote: I have a piper turbo arrow with a TSIO-360-FB engine. It has the original waste gate on the turbo, and an after market turbo plus intercooler. I recently made a long trip, and got the plane up to 14000 for the first time in a long time. I was having trouble keeping the exhaust temp down. I had the mixture full rich, and the engine was only using 14 gph. It seemed I could not get the mixture rich enough. I don't remember this happening on any of my previous flights at high altitude, but the previous flights were a while back. The plane behaves perfectly normal at altitudes up to 10000 which is were most of my flying is. Does this imply something wrong with the fuel system or fuel pump or is this normal behavior for these planes? |
The take off and low altitude fuel flow is fine. At altitude, the CHTs were
OK, but a little higher than normal. I have an intercooler so it keeps the temps down a bit at the high altitudes. The EGT is what had me worried. It was running close to peak with full rich, and only taking about 15 gph. I pulled the power back to 25 inches, and that dropped the fuel flow to 14 gph, and still high EGTs. Since this is below 65% power, the engine will stay cool at peak EGT. I assume that the high end and low end adjustments are hard limits to the fuel flow. I think the problem is something different since it only shows up at high altitudes, and at low altitudes there is more than enough fuel flow. I hope to have the problem looked at soon. It is scheduled to go into the shop two weeks from now. "The Visitor" wrote in message ... It could be your high end fuel flow is not sufficient. (Yes there is also a low end setting also.) When you do a normal take off at full rich, does the FF needle go to just about the redline? John soxinbox wrote: I have a piper turbo arrow with a TSIO-360-FB engine. It has the original waste gate on the turbo, and an after market turbo plus intercooler. I recently made a long trip, and got the plane up to 14000 for the first time in a long time. I was having trouble keeping the exhaust temp down. I had the mixture full rich, and the engine was only using 14 gph. It seemed I could not get the mixture rich enough. I don't remember this happening on any of my previous flights at high altitude, but the previous flights were a while back. The plane behaves perfectly normal at altitudes up to 10000 which is were most of my flying is. Does this imply something wrong with the fuel system or fuel pump or is this normal behavior for these planes? |
How close is your fuel flow to redline, during take-off?
I caught that part of the question the first time, but I didn't respond to
it because I haven't noticed the flow level before. When I take off, I look quickly at the manifold and RPM, but only a quick glance at the fuel flow. I will try to take more notice if I go up this week. I guess I should expect it to go close to red line if every thing is OK according to your previous posts. Thanks for the reply. "The Visitor" wrote in message ... How close is your fuel flow to redline, during take-off? |
Turbo Lance MP flux ? | John Doe | Owning | 3 | September 28th 05 01:56 AM |
Why turbo normalizer? | Robert M. Gary | Piloting | 61 | May 20th 05 04:33 PM |
turbo stc? | The Weiss Family | Owning | 21 | October 3rd 04 10:35 PM |
First Time Buyer - High Time Turbo Arrow | [email protected] | Owning | 21 | July 6th 04 07:30 PM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
