True. But if there is a fix in the approach that is defined by a distance
from something that is in the GPS database, you can use that fix and the distance from it as a substitute for the LOC distance. That works, but in my opinion does require advance planning to calculate the relevant distances from that fix and write them down. It's way too easy to make a mistake to do the figuring in real time during the approach. "Andrew Sarangan" wrote in message . 4... Yes, you may, but you have to aware that the GPS may not contain the LOC station in its database. VOR stations should be fine. |
Substitute Routes - what exactly are they? | Andrew Sarangan | Instrument Flight Rules | 3 | July 12th 04 02:55 AM |
Substitute for Mahogany plywood | Kelvin & Janice Rempel | Home Built | 1 | September 5th 03 08:02 PM |
Substitute for MEK? | Rich S. | Home Built | 3 | August 30th 03 08:14 PM |
GPS SUbstitute for DME or ADF | S. Ramirez | Instrument Flight Rules | 12 | August 20th 03 04:04 PM |
