oil blow out IO-360
Old July 14th 06, 05:54 PM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary
Default oil blow out IO-360
I have an IO-360-A3B6 900 SFNEW in '97. I used to be able to keep about
7 quarts in it without it blowing out. Now it seems to be blowing oil
down to about 5.5 quarts. Since I live in the 100F OATs part of the
country, the extra oil really helps cooling.
Should I worry about what is causing the extra oil blow out or just
chock it up to an aging engine. I know some engines always blow out to
6ish quarts.
If I shouldn't worry about the extra blow out I'll just put a separator
on it, but I don't want to mask a problem first. One recent change is
we raised the oil pressure since the regulator had been slipping prior
to annual.
-Robert
Old July 14th 06, 09:11 PM posted to rec.aviation.piloting,rec.aviation.owning
Jim Macklin
Do a differential compression test and pay attention to
valve guides play and seals, often the oil is not being
blown out the breather, but is leaking around the valves
[even one valve] and burning. If you have high leakage
during the differential compression test, you're getting too
much blow-by and that is raising the crankcase pressure and
blowing oil out the breather tube. If the breather is
blocked, it will blow the main seal and you'll see oil
behind the prop. If the oil level goes down fast and then
stabilizes, you may have a dipstick that is not calibrated
properly and you're over filling.
The engine is old, nearly ten years, check all the seals and
mating surfaces. You only have 900 hours, but that is less
than 100 hours a year. Corrosion in the cylinders and blow
by, and oil being sucked past the ring into the combustion
chamber are all possible, Check valve guides and seals,
differential compression and if available, borescope it.
Higher oil pressure would increase the leakage, but not
effect the valve guides or rings. An oil separator will
only help if the oil is going out the breather tube.
James H. Macklin
ATP,CFI,A&P
to keep about
blowing oil
part of the
out or just
blow out to
| 6ish quarts.
put a separator
recent change is
slipping prior
| to annual.
| -Robert
Old July 14th 06, 10:06 PM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary
The only place I'm seeing any oil is at the breather. I had a full
prop/gov overhaul last year and they replaced the front engine seal. I
wasn't having any problems with the prop, I had it overhauled because
oil was leaking from the gov. Now I think I've got a clean enough
engine that I can actually tell where the oil is leaknig from.
-Robert
Old July 14th 06, 10:45 PM posted to rec.aviation.piloting,rec.aviation.owning
Jim Macklin
You might see about plumbing in a pressure gauge to read the
crankcase pressure in flight, also, there should be a baffle
to keep the oil from directly splashing on the breather
pick-up.
It is possible that the work that was done reduced the
leaking from the crankcase [reduced venting] and it is now
increased at the breather. If there is too much blow by, a
top overhaul or perhaps just a bad cylinder needs honed and
new rings. But a sudden change in the oil usage pattern is
cause for more investigation. You see oil at the breather
because it is not burned, but is atomized particles and
vapor. But you can be burning oil because of bad rings or
valve guide leakage and that could be masked in the exhaust
stack. Check plug condition and the stacks should be chalky
gray, not black or brown greasy. Have someone do a full
power run-up and you look at the exhaust for color, oil
smoke
is bluish, excess fuel is black smoke. White smoke is a
cold engine and water condensation, or a water jacket leak
on a water cooled engine.
see
http://www.lycoming.textron.com/main...ons/index.html
James H. Macklin
ATP,CFI,A&P
and
less
blow
combustion
had a full
engine seal. I
overhauled because
enough
| engine that I can actually tell where the oil is leaking
from.
| -Robert
Old July 14th 06, 11:11 PM posted to rec.aviation.piloting,rec.aviation.owning
Jim Burns[_1_]
It seems like I'm agreeing with Jim these days, I'd also say that something
is creating excessive case pressure. Along those lines I just tore down a
horizontally opposed Kohler that was blowing oil from the breather faster
than I could dump it in. It had blown a cylinder barrel seal, not a gasket,
just an RTV seal. The key is that something caused the seal to blow. What
did I find? Cracked exhaust valve guide that allowed exhaust pressures into
the case.
I think a valve wobble test and compression test could shine a lot of light
on your problem.
6ish quarts.
to annual.
-Robert
Old July 15th 06, 12:24 AM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary
the case.
Would that show up in a compression test though? I"m getting 79's all
around in the compression test. The IA seemed impressed with the
compression. Also, my EGTs seem to be running about the same.
-Robert
Old July 15th 06, 12:31 AM posted to rec.aviation.piloting,rec.aviation.owning
Jim Burns
No, remember on a compression check your valves are closed, thus why I
suggested the valve wobble test. Not saying the guide is cracked, but it or
they could be worn. I was just trying to keep the symptom (excess oil out
the breather) separated from the cause (unknown) and relate what I had
discovered.
Let us know what you find.
something
a
faster
gasket,
What
into
the case.
-Robert
Old July 15th 06, 12:49 AM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary
discovered.
If it were caused by a valve problem though would the oil still come
out the breather? My engine seems extreamly clean of oil. I can see oil
dripping from the breather.
-Robert
Old July 15th 06, 01:09 AM posted to rec.aviation.piloting,rec.aviation.owning
Jim Macklin
Check the valve guides and seals, with the valve closed,
compression will be good. But when the valve opens, if the
guide is worn or the seal is bad, oil will be sucked from
the top end.
say that something
I just tore down a
the breather faster
seal, not a gasket,
seal to blow. What
| the case.
getting 79's all
with the
same.
| -Robert
Old July 15th 06, 01:15 AM posted to rec.aviation.piloting,rec.aviation.owning
Jim Burns
The breather exhausts excess pressure built up in your crank case. Anything
that would allow pressure created in the combustion chambers into your crank
case can lead to additional pressure and excess oil being emitted from your
breather along with the gasses. A bad oil ring on a piston or anything not
sealing in the valve train... valve not seating properly or a worn valve
guide.
I'm not an A&P, and this would be better confirmed by Jim or others, but I
would imagine that either a oil return line or even a pushrod sleeve would
allow pressure from a cylinder head into the case. Guys?
it or
out
discovered.
-Robert
oil blow out IO-360 Robert M. Gary Piloting 18 July 17th 06 05:44 PM
Blow out static port [email protected] Owning 36 May 13th 05 03:59 PM
Aviation song for US? Jürgen Exner Piloting 39 March 7th 05 03:01 AM
Cambridge Fuse Question Brian Iten Soaring 9 January 4th 05 03:43 PM
Boxer to blow billions on MANPADS Henry J. Cobb Military Aviation 0 December 3rd 03 05:44 PM
