No Such User wrote:
In article et, Matt Young wrote: during descent through the clouds, or will the gyros keep spinning fast enough long enough to make the vacuum pump irrelevant? I question the wisdom of relying on an instrument that you already know to have failed. What makes you think it has failed? If the vacuum guage still shows a vacuum, then the gyro's got to spin (unless you are unlucky enough to have a second failure of the vacuum system at the same time that the engine crumped). What I've never understood is why there isn't more obvious indication that there is no power (vacuum or electric as required) going to the instrument. Jeez, the VOR which isn't as essential to instrument flight has a better indication that it's not on. |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? | Ron | Home Built | 2 | February 24th 04 04:34 PM |
Tiny vacuum pump | Jim Weir | Home Built | 41 | January 24th 04 05:42 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
