Emergency Procedures
Old July 15th 06, 08:06 PM posted to rec.aviation.ifr
Mitty
Default Emergency Procedures
I was checking out in a Civil Air Patrol 182T the other day and the
check airman pulled the power on me. No big deal, but then he
demonstrated how the glide improved when the propeller was pulled to
low RPM. No one had ever showed that to me before.
Question is:
In retrospect it seems obvious that there will be less resistance when
the prop is closer to a feathered position. Buy why don't I see this
as part of emergency checklists for airplanes with constant speed
props? What am I missing here?
Old July 15th 06, 08:21 PM posted to rec.aviation.ifr
rod
It, does work, but most people don't know it or teach it. The improvement
in glide isn't great, however.
Rod
Old July 15th 06, 09:27 PM posted to rec.aviation.ifr
Robert M. Gary
Lots of planes include this. The Bonaza I used to teach in gave two
best glide speeds, one for prop forward, one for prop back. My Mooney
also recommends prop back.
Its interesting that he did this in the 182T though. In our wing we
require pilots to be 182 current (annual form 5) before checking out in
the 182T. The 182T checkride is just about the glass cockpit and
autopilot usage.
-Robert, CAP check pilot
Question is:
Old July 15th 06, 09:55 PM posted to rec.aviation.ifr
Tim Auckland
It's a technique I was taught during my commercial license training as
a way of adjusting drag when doing the "180-degree power-off precision
landing".
My guess is that it's not included in emergency checklists beacuse
once the engine stops, you loose oil pressure, and the propellor will
go to the fine-pitch position anyway on a single-engine plane.
It's not something you can rely on in an emergency.
Tim.
Question is:
Old July 15th 06, 10:11 PM posted to rec.aviation.ifr
Mitty
It was a conventional panel "T." The glass is next.
On 7/15/2006 3:27 PM, Robert M. Gary wrote the following:
autopilot usage.
Question is:
Old July 15th 06, 11:00 PM posted to rec.aviation.ifr
Peter R.
My '73 Bonanza V35 has "pull the prop" (or word to that effect) as part of
the delivered emergency checklist.
Peter
Old July 15th 06, 11:05 PM posted to rec.aviation.ifr
Jim Macklin
It works and should be part of a complex check-out. You can
also push the prop back to high rpm and slow down to get
into a short field.
James H. Macklin
ATP,CFI,A&P
"Mitty" wrote in message
and the
then he
pulled to
| Question is:
resistance when
I see this
constant speed
Old July 15th 06, 11:09 PM posted to rec.aviation.ifr
Jim Macklin
If the engine is turning, it has oil pressure.
To get maximum glide, a stopped prop has less drag, but most
instructors do not recommend slowing down enough to stop the
prop,on compression.
James H. Macklin
ATP,CFI,A&P
"Tim Auckland" wrote in message
training as
power-off precision
| landing".
beacuse
propellor will
plane.
| Tim.
day and the
then he
was pulled to
| Question is:
resistance when
don't I see this
constant speed
Old July 16th 06, 12:28 AM posted to rec.aviation.ifr
Roy Smith
Only if it has oil.
Still, I teach pulling the prop all the way back. It may work, it may not,
but it sure can't hurt.
Old July 16th 06, 01:04 AM posted to rec.aviation.ifr
Mitty
On 7/15/2006 6:28 PM, Roy Smith wrote the following:
Only if it has oil.
Makes sense to me.
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Agent86's List of Misconceptions about of FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 12 April 20th 04 02:21 AM
Agent86's List of Misconceptions about FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 9 April 18th 04 06:13 PM
