Lead Radial Question
Old November 25th 04, 04:28 AM
Stan Prevost
Thanks, JPH and Tim.
Stan
"J Haggerty" wrote in message
news:q2cpd.102277$tU4.84228@okepread06...
Seems likes it there just to let a pilot that doesn't have DME know that
they haven't yet passed the localizer.
The way the regulation is worded, it's required only for an Initial
segment when the initial course and intermediate course differ by more
than 90 degrees, so it's not technically needed for this feeder. There's
nothing to prevent adding it, and if you don't have DME, it gives you a
good idea when you're about to reach the LOC intersection.
The actual wording can be found in FAAO 8260.3 para 232
http://av-info.faa.gov/terps/Directi...260.3_1-18.pdf
JPH
Stan Prevost wrote:
This question concerns the ILS or LOC RWY 36R approach into Huntsville
(AL) International Airport (KHSV).
http://www.naco.faa.gov/d-tpp/0412/05488IL36R.PDF
Just to the left of the HIL pattern, there is a lead radial RQZ LR-200
shown. I assume this is for use by aircraft flying the feeder route from
DCU on R-149. But why is it needed? I thought LRs were required for
turns of more than 90 degrees. The HIL is required for arrival on the
feeder, and the feeder route makes a perfect teardrop entry into the
hold, so no turn is required after crossing ENIKY.
So why the LR?
Stan
Wanted 5-cylinder B-75 Lawrence radial Chris Wertman Home Built 5 April 8th 10 02:11 AM
Help ! SMALL Radial engine Chris Wertman Home Built 12 July 18th 05 02:46 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Garmin 430 question smf Instrument Flight Rules 4 December 1st 03 03:03 AM
