First Time in IMC and vacuum problem
Old January 2nd 05, 03:59 PM
Wizard of Draws
On 1/2/05 8:46 AM, in article , "Jon
Kraus" wrote:
Here is what I'll do different next time:
1. Make sure that I have had the vacuum indicator "in the green" for
several minutes before departing to ensure that the gyros are spooled up.
2. Have the approach for returning to the airport loaded or in standby
just in case you need to return quickly. I did not do this and it added
needless stress loading everything.
It is true what they say:
"It is better to be on the ground wishing you were in the air, then
being in the air wishing you were on the ground"
Jon Kraus
PP-ASEL-IA
Student Mooney Owner
Congratulations Jon! Sounds like a "fun" flight.
We should all remember that aviation quotes are first written in blood and
tears.
It seems you're like me, you learn a few good items to add to that checklist
every time you fly. Happy new year and fly safe.
Jeff 'The Wizard of Draws' Bucchino
Cartoons with a Touch of Magic
http://www.wizardofdraws.com
More Cartoons with a Touch of Magic
http://www.cartoonclipart.com
Old January 2nd 05, 04:07 PM
Gary Drescher
"Jon Kraus" wrote in message
Thanks for the advice Gary. I am familiar with what a ASRS report is but
was wondering how to file one and why one is needed?
You can get the form and instructions at
http://asrs.arc.nasa.gov/main_nf.htm. The ASRS program analyzes reports of
hazardous situations in order to figure out how to improve aviation safety.
(Their limited-immunity policy is an extra incentive to file reports when
pilots inadvertantly violate the FARs, but that aspect isn't pertinent in
this case.)
Yes I was below 700 feet when I cancelled my IFR plan. Thanks again!!
Cool. Pilots often get that wrong, canceling before they have the required
VFR cloud clearance in controlled airspace, and sometimes get busted for it.
--Gary
Jon Kraus
PP-ASEL-IA
Glad it worked out. It would be useful to file an ASRS report of the
event.
Really after I "calmed" down and the AI started acting correctly I didn't
have any problems navigating in the clouds. I shot the ILS 36 and broke
out 1000 feet above the runway, canceled my IFR flight plan and made an
uneventful landing.
I hope you waited until you were below 700' AGL before canceling IFR. (If
not, that's another good reason for the ASRS report.)
--Gary
Old January 2nd 05, 04:08 PM
Jon Kraus
Once I calmed myself down it was "kinda" fun. I would have preferred to
have this happen after many flights in IMC though..
Jon Kraus
PP-ASEL-IA
Jon Kraus
PP-ASEL-IA
tears.
Old January 2nd 05, 04:09 PM
A Lieberman
Hey Jon,
Go to http://asrs.arc.nasa.gov/forms.htm for the form and instructions on
how to file one.
Allen
Old January 2nd 05, 04:46 PM
Hilton
it.
I hear it here (SJC) at bunch. GA plane gets a IFR to VFR on top, and
reports: "OK, we just broke out, tops 2400, cancel IFR" - something like
that. When I get that clearance, I feel bad spending more than a minute in
perfect visibility while the 'big iron' sits on the ground at SJC, but it's
the rules and it does prevent one of those 'big-irons' climbing into me (or
at least helps prevents it).
Hilton
Old January 2nd 05, 04:52 PM
Andrew Sarangan
My guess is you have a failing vacuum pump. It might have been acting up
then corrected itself during flight once you had full RPM. Even if the
vacuum is below green during idle, it should not take more than a few
seconds to bring the gryos to full speed at takeoff power. I would
definitely have the vacuum system checked out.
(Paul Tomblin) wrote in news:cr8uan$4n2$1
@allhats.xcski.com:
It couldn't hurt to have a mechanic look at your vacuum system.
Old January 2nd 05, 04:54 PM
John R. Copeland
"Gary Drescher" wrote in message =
"Jon Kraus" wrote in message=20
=20
=20
Cool. Pilots often get that wrong, canceling before they have the =
required=20
VFR cloud clearance in controlled airspace, and sometimes get busted =
for it.
=20
--Gary
You might be referencing that odious piece of fiction from (I think) =
IFR.
Someone (I forget who) fabricated such a circumstance and wrote a
magazine article about it as though it really happened a couple years =
ago.
I think that was unforgivably dishonest journalism.
It's OK to write about observing rules concerning IFR cancellations,
but I object to sensationalizing *fictitious* enforcement actions.
Old January 2nd 05, 05:04 PM
John R. Copeland
Dry vacuum pumps normally fail catastrophically by shattering their
graphite vanes. Personally, I've never detected warning signs other =
than
gradually accumulating carbon dust around the pump outlets.
When I see that, I schedule pump replacement without waiting for =
failure.
Jon's doing right by getting the whole vacuum system checked.
He could have a clogged filter, a small leak, or even a bad gyro =
bearing.
"Andrew Sarangan" wrote in message =
1...
=20
My guess is you have a failing vacuum pump. It might have been acting =
up=20
then corrected itself during flight once you had full RPM. Even if =
the=20
vacuum is below green during idle, it should not take more than a few=20
seconds to bring the gryos to full speed at takeoff power. I would=20
@allhats.xcski.com:
=20
1. Make sure that I have had the vacuum indicator "in the green" for =
several minutes before departing to ensure that the gyros are spooled =
up.
2. Have the approach for returning to the airport loaded or in =
standby=20
just in case you need to return quickly. I did not do this and it =
added=20
=20
=20
Old January 2nd 05, 05:26 PM
Jon Kraus
I think I'll get this IFR thing more practice first. This incident
helped cement the fact that I don't know diddly about IFR flight. But
for the grace of God that I got down safely. Have you been solo IMC yet.
It is quite a rush (even without the instrument issue)
Jon Kraus
PP-ASEL-IA
Cecil Chapman wrote:
GREAT JOB!!! Sounds like you did just fine despite having 'this is NOT a
simulation' flashing in your brain GRIN
So, when are you going to get your CFII... sounds like your instructor did
you right! :0)
Old January 2nd 05, 05:27 PM
Jon Kraus
for the grace of God that I got down safely. Have you been solo IMC yet?
Jon Kraus
PP-ASEL-IA
you right! :0)
