OK... 1st, stepdown fixes are after the FAF... they are between the FAF
and the MAP. The only IFR altitude that your are allowed to go below on an IFR flight plan is the MDA or DA, and then only after you have the three requirements satisfied as specd in FAR 91.175. There is no provision for going below a step-down fix under an IFR flight plan... VMC or IMC. Gene |
what is MBS approach and please quote me the FAR this opinion is based
upon |
hsm--
See FAR 91.177 Minimum Altitudes for IFR Operations It does contain a caveat "except as necessary for takeoff and landing," but 'necessary' you must remember is going to be determined by the NTSB judge at your hearing, not by you. Gene |
Looked it up, still do not see it
harry |
On 7 Jan 2005 08:35:13 -0800, "hsm" wrote:
Looked it up, still do not see it harry Read an up to date version of 91.177 *from the beginning*. What do you not see or not understand? It seems pretty clear to me. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Be careful of the 'cancel IFR' trick as well. If you cancel, and at
that moment are not the required 500 below the overcast, (controlled airspace) you are instantly in violation. I am intimately familiar with the SMX approaches, and can tell you that there are at least some of the tower personnel there that seem to be, well, difficult. Deliberately putting yourself in a position to be considered violating a minimum altitude on an approach there while IFR is an invitation for a legal problem. Better just to slow down and get the flaps out so you can descend more quickly after you pass the fix. Gene |
descent below minimums | hsm | Instrument Flight Rules | 82 | January 11th 05 06:33 PM |
Landing Gear Parts, Antique Part, EXP Airplane Auction | Bill Berle | Home Built | 0 | November 24th 04 05:11 PM |
Stiffness of finished Carbon Fiber part | RKT | Home Built | 3 | April 8th 04 02:00 PM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
CAT II Minimums on a CAT I Approach | Giwi | Instrument Flight Rules | 11 | July 24th 03 07:46 AM |
