Looking for a math wiz!
Old December 17th 06, 06:34 AM posted to rec.aviation.piloting,rec.aviation.ifr
d&tm
Default Looking for a math wiz!
"Stefan" wrote in message
d&tm schrieb:
if you know HDG ( ie where you are pointing), GS and TAS then there is
only
1 possibility for the wind speed and direction.
Actually, there are two.
I give up, can you please explain how there can be 2 ?
Old December 17th 06, 02:12 PM posted to rec.aviation.piloting,rec.aviation.ifr
Michael Ware
"d&tm" wrote in message
only
There are two possible situations for the wind correction. You do not know
the direction of the correction for wind ( i.e. is the plane crabbing left
or right to compensate for x-wind) you only know the magnitude (wind speed).
Think of the triangle that is formed by vectors on the e6b. Without the
direction, you have an ambiguous answer, looks like two similar triangles, a
lefty and a righty.
Someone else could probably explain this better, that's the basic idea.
Mike
Old December 18th 06, 05:05 AM posted to rec.aviation.piloting,rec.aviation.ifr
Everett M. Greene[_2_]
"Michael Ware" writes:
"d&tm" wrote
"Stefan" wrote
only 1 possibility for the wind speed and direction.
lefty and a righty.
And a simple explanation of the whole process is that
the wind triangle has three (vector) components:
heading, course, and wind. The vector sum of heading
and wind gives course which is the problem that pilots
are accustomed to solving. Rearranging the equation
so as to compute wind given heading and course is not
at all difficult. The law of cosines allows determination
of the third side of a triangle given two sides and
the included angle. The law of sines allows determining
the other two angles given the three sides. There is no
left/right ambiguity given the course and heading.
Old December 18th 06, 11:54 PM posted to rec.aviation.ifr
Jim Carter[_1_]
-----Original Message-----
Posted At: Sunday, December 17, 2006 11:05 PM
Posted To: rec.aviation.ifr
Conversation: Looking for a math wiz!
Subject: Looking for a math wiz!
The problem given one aircraft has many solutions because neither
heading nor wind vector can be determined by radar. Two unknowns for the
3 factor problem. Heading will change as a function of wind vector and
vice-versa.
As a sidebar: is this just an exercise or is the goal to empower the
controllers to provide accurate real-time winds aloft?
Old December 19th 06, 05:56 AM posted to rec.aviation.ifr
Chad Speer
This is just a training tool, Jim. Basically a replay system that
allows us to take control of an aircraft an demonstrate how a situation
could have been handled differently by a trainee. It should be really
cool, but none of this will be used on live traffic.
Chad Speer
PP-ASEL, IA
ATCS, Kansas City ARTCC
Old December 19th 06, 05:14 PM posted to rec.aviation.ifr
Everett M. Greene
"Jim Carter" writes:
Everett M. Greene ]
vice-versa.
I recall the original posting said that heading was known
as it would be in many approach/departure scenarios.
Old December 19th 06, 09:12 PM posted to rec.aviation.ifr
Kobra
No...the OP said the GROUND TRACK was known. The heading would not be known
unless the controller asked the pilot for his heading.
I was thinking that controllers should have an accurate knowledge of the
winds aloft direction and speed while vectoring aircraft to the localizer.
On a couple of occasions a controller assigned me a heading to intercept the
localizer that did not allow me to intercept the localizer until after the
FAF due to his misunderstanding of how the winds were carrying me downwind.
Kobra
Old December 19th 06, 11:40 PM posted to rec.aviation.ifr
Doug[_1_]
This is why ground track (and ground speed) is actually now perferable
to heading and airspeed. But what with all the FAA certification and
all planes not having GPS (or SOME kind of rnav), we're stuck using the
antiquated heading and indicated airspeed.
Ah, I pine for the days a good old 4 course range....when all pilots
were men...........
Kobra
Looking for a math wiz! Chad Speer Piloting 41 December 28th 06 10:11 AM
Help with 152 math pittss1c Piloting 12 May 13th 05 01:47 PM
# of Aircraft Club Members - Math Formula Wanted Rich Owning 3 September 16th 04 04:08 PM
Math help request ? Snead1 Soaring 5 June 8th 04 11:15 PM
Student invents new math process Otis Willie Military Aviation 29 December 2nd 03 02:13 AM
