Mxsmanic wrote:
If it becomes impossible to respect your descent schedule, is it permissible to ask ATC to give you a hold temporarily so that you can descend in the hold pattern until you're back to your planned descent? If so, is this a fairly common procedure, or very unusual? I'm thinking with respect to large commercial jets in particular (or potentially any jet, since they usually seem to be fast and slippery). Never happens. Like the other gentleman says, the spoilers (actually speed brakes when used in flight) are the "ace in the hole." |
Sam Spade wrote:
Never happens. Like the other gentleman says, the spoilers (actually speed brakes when used in flight) are the "ace in the hole." Sam, Never say never ![]() lose altitude, after arriving at the final fix about 10,000 feet high. This was due to descent restrictions from center because of other approaches in progress. The flight spoilers on a 727 are *very* effective, but they can't perform miracles! Happy Flying! Scott Skylane |
Scott Skylane wrote:
Sam Spade wrote: Never happens. Like the other gentleman says, the spoilers (actually speed brakes when used in flight) are the "ace in the hole." Sam, Never say never ![]() lose altitude, after arriving at the final fix about 10,000 feet high. This was due to descent restrictions from center because of other approaches in progress. The flight spoilers on a 727 are *very* effective, but they can't perform miracles! Happy Flying! Scott Skylane Your mileage may vary. ;-) I've got almost 8,000 hours in the 727 and never, ever did an approach hold or procedure turn. Delay vectors, yes. |
![]() -----Original Message----- From: Sam Spade ] Posted At: Tuesday, January 02, 2007 2:15 PM Posted To: rec.aviation.ifr Conversation: Requesting a hold from ATC for descents Subject: Requesting a hold from ATC for descents .... Your mileage may vary. ;-) I've got almost 8,000 hours in the 727 and never, ever did an approach hold or procedure turn. Delay vectors, yes. And then there was the time several years ago an American 727 into TUL was hot, high, and straight-in -- but he wasn't going to sequence behind my lowly Cherokee 6. He ended up going around after blowing across the boundary well above Vref and ended up landing #2 behind the Bonanza that followed me in. I wonder what that little excursion cost? Of course I still love to hear the tower tell a pilot "left or right turn at the end if able". |
![]() Scott Skylane wrote: Never say never ![]() lose altitude, after arriving at the final fix about 10,000 feet high. This was due to descent restrictions from center because of other approaches in progress. The flight spoilers on a 727 are *very* effective, but they can't perform miracles! You also must also factor in pilot incompetence. I can't begin to tell you how many times these jet pilots, almost always from the majors like NWA and UAL as well as from the regionals like Skywest, report on the freq 35 miles out at FL230 or higher. This is not centers fault as the descent clearance was given about 200 miles out. Center usually gives a PD descent and these guys continually foul it up. So to illuminate your mistake I will drive you right at the airport and make you beg for mercy. |
![]() -----Original Message----- From: Newps ] Posted At: Tuesday, January 02, 2007 2:24 PM Posted To: rec.aviation.ifr Conversation: Requesting a hold from ATC for descents Subject: Requesting a hold from ATC for descents .... You also must also factor in pilot incompetence. I can't begin to tell you how many times these jet pilots, almost always from the majors like NWA and UAL as well as from the regionals like Skywest, report on the freq 35 miles out at FL230 or higher. This is not centers fault as the descent clearance was given about 200 miles out. Center usually gives a PD descent and these guys continually foul it up. So to illuminate your mistake I will drive you right at the airport and make you beg for mercy. I seem to remember a "keep-em-high" program years ago that kept everyone as high as possible for as long as possible to preserve fuel and reduce noice. Could that policy still be in effect for some carriers? |
Jim Carter writes:
I seem to remember a "keep-em-high" program years ago that kept everyone as high as possible for as long as possible to preserve fuel and reduce noice. Could that policy still be in effect for some carriers? I was thinking the same thing. They may have company policies that require them to stay as high as possible for as long as possible to save fuel (noise abatement probably isn't as much of an issue, but it might still be a factor). -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Jim Carter wrote: I seem to remember a "keep-em-high" program years ago that kept everyone as high as possible for as long as possible to preserve fuel and reduce noice. Could that policy still be in effect for some carriers? The Keep 'em High program was an ATC program to keep aircraft at about 10K until 20 miles from the aiport. That program is no longer in effect. All airlines have their own policies about this. As well all modern aircraft can be told when to be at what altitude when and the computer will handle it. |
Newps writes:
The Keep 'em High program was an ATC program to keep aircraft at about 10K until 20 miles from the aiport. What was its purpose? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Newps writes: The Keep 'em High program was an ATC program to keep aircraft at about 10K until 20 miles from the aiport. What was its purpose? It was eons ago. Primarly to keep the noise in near the airport. It was when the majority of airline jets made much more noise then the Stage III birds today. |
Requesting a hold from ATC for descents | Mxsmanic | Piloting | 10 | January 3rd 07 02:31 AM |
Different categories of ILS hold short lines at large airports | Peter R. | Piloting | 3 | March 6th 06 08:08 PM |
IFR hold short line at uncontrolled airports? | Peter R. | Instrument Flight Rules | 30 | June 9th 04 04:47 AM |
S-TEC 60-2 requires re-trim after altitude hold? | Peter R. | Owning | 7 | March 2nd 04 03:46 PM |
Hold "as published"? | John Clonts | Instrument Flight Rules | 83 | November 13th 03 03:19 PM |
