Is the need for carb heat affected by ambient humidity? In low
humidity conditions, and also at very low temperatures, is the propensity for carb ice reduced thus 'eliminating' the need for carb heat? Just curious what the discussion might bring. Thx. |
It sure is. I tried to take off once in Shenandoah on a humid day, and the engine failed its runup - when I pulled the power back, it quit entirely. I did this a few times and called the mechanic over. We couldn't find anything - the final theory was that carb ice had built up while I was taxiing and during the runup. This had never happend to me before, in this aircraft, or any other. I preflit and took off with carb heat, and had no problem. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
![]() vlado wrote: Is the need for carb heat affected by ambient humidity? In low humidity conditions, and also at very low temperatures, is the propensity for carb ice reduced thus 'eliminating' the need for carb heat? Just curious what the discussion might bring. You may want to hang out behind the back of your local ground school and grab one of the old Private Pilot manuals they are throwing out. -Robert |
![]() Robert M. Gary wrote: vlado wrote: Is the need for carb heat affected by ambient humidity? In low humidity conditions, and also at very low temperatures, is the propensity for carb ice reduced thus 'eliminating' the need for carb heat? Just curious what the discussion might bring. You may want to hang out behind the back of your local ground school and grab one of the old Private Pilot manuals they are throwing out. -Robert OK OK. Here's the deal, Outside the weather is "frightful" with no visible moisture, 30% humidity & -12 centrigrate. Any chance of carb ice in this condition? (The manuals are gone; they've gone to CDs if not on their iPods.) Thx |
AOPA has an excellent chart showing the likelyhood (sp?) of carb ice at
http://flighttraining.aopa.org/membe...rticles/58.cfm I'm surprised it isn't more widely published. |
"nrp" wrote:
AOPA has an excellent chart showing the likelyhood (sp?) of carb ice at http://flighttraining.aopa.org/membe...lo/articles/58. cfm I'm surprised it isn't more widely published. I clicked through and got: "The section that you're trying to access requires membership in AOPA." Does this AOPA public link have the same chart you intended to reference?: http://www.aopa.org/asf/epilot_acc/nyc02fa025_1.html The chart (if it is the same one you mean) also appears on these pages: http://www.faa.gov/ats/afss/newyork/ENROUTE.htm http://www.tc.gc.ca/CivilAviation/pu...71/AIR/2-1.htm |
Yes they appear to be similar charts. The AOPA chart actually shpws a
strange anomaly for pressure carbs that limits the severe icing to about 80% humidity. I'm not sure why that is so, and it may only be an artist's mistake. At any rate the general trend for when to expect icing from those charts is clear. |
![]() nrp wrote: Yes they appear to be similar charts. The AOPA chart actually shpws a strange anomaly for pressure carbs that limits the severe icing to about 80% humidity. I'm not sure why that is so, and it may only be an artist's mistake. At any rate the general trend for when to expect icing from those charts is clear. \ The OP's post indicates the increasing trend to ignore training about carb ice. There have been several accidents in the last few years around our part of the country involving carb ice, and in my teaching i find that pilots don't know the mechanism of carb ice, nor do they know how to recognize and manage it. Dan |
![]() vlado wrote: OK OK. Here's the deal, Outside the weather is "frightful" with no visible moisture, 30% humidity & -12 centrigrate. Any chance of carb ice in this condition? Nope, way too cold. |
![]() Newps wrote: vlado wrote: OK OK. Here's the deal, Outside the weather is "frightful" with no visible moisture, 30% humidity & -12 centrigrate. Any chance of carb ice in this condition? Nope, way too cold. Newps.....Thanks for the quick answer. The AOPA chart shows that as well. It is true, a good chart with not enough distribution. Thx again. |
Carb heat. sprung hot or cold? | Hayden | Home Built | 0 | May 31st 06 11:07 PM |
Lycoming Carb Heat | Mitty | Instrument Flight Rules | 19 | September 21st 05 06:43 PM |
Have you ever experienced carb ice with an injector carb? | flybynightkarmarepair | Home Built | 1 | January 31st 05 01:48 AM |
Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 05:29 AM |
Use of Carb Heat | John Kirksey | Piloting | 4 | November 30th 04 07:26 PM |
