"Wyatt Emmerich" wrote in
: Controllers forgetting to hand you off to tower is a fairly common problem in the IFR environment, especially when it's practice. I just say something like "Should I got to tower" and that usually does the trick. *smile* If I don't get transferred to tower within a couple of miles from the FAF, I was told by my instructor to "report" my position to appraoch controllers as a memory jogger that I am still with them. I.E. Jackson Approach 43L one mile outside Brenz. Usually, approach will come back and then say 43L, contact tower on 1xx.xx Allen |
On Thu, 08 Feb 2007 23:22:15 GMT, A Lieberma
wrote: "Wyatt Emmerich" wrote in : Controllers forgetting to hand you off to tower is a fairly common problem in the IFR environment, especially when it's practice. I just say something like "Should I got to tower" and that usually does the trick. *smile* If I don't get transferred to tower within a couple of miles from the FAF, I was told by my instructor to "report" my position to appraoch controllers as a memory jogger that I am still with them. I.E. Jackson Approach 43L one mile outside Brenz. Usually, approach will come back and then say 43L, contact tower on 1xx.xx Allen In Actual: Ahhh... *** approach, this is XXX 20 North at 4,000. How far do you want me to keep going for traffic avoidance? Ahhhh XXX ... turn heading 180 and expect vectors to the ILS. Know what to expect when and ask why if not. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Roger wrote in
: In Actual: Ahhh... *** approach, this is XXX 20 North at 4,000. How far do you want me to keep going for traffic avoidance? Ahhhh XXX ... turn heading 180 and expect vectors to the ILS. I knew instrument flying required patience, but you exceeded the patience of Job *big smile*. Musta woke the controller up from a nap? Allen |
On Fri, 09 Feb 2007 04:43:22 GMT, A Lieberma
wrote: Roger wrote in : In Actual: Ahhh... *** approach, this is XXX 20 North at 4,000. How far do you want me to keep going for traffic avoidance? Ahhhh XXX ... turn heading 180 and expect vectors to the ILS. I knew instrument flying required patience, but you exceeded the patience of Job *big smile*. At 3 miles a minute it doesn't take very long and when you are busy 5 or 6 minutes can go by in a hurry. They were really busy and it was hard to get a word in.:-)) At least the ride was smooth even if I couldn't see anything. That was the same day and same airport where they told me to follow the airliner ahead when I couldn't see past the Deb's wing tips. I believe my reply was something to the effect of "I would if I could, but I can't see my own wingtips". Which was followed by another... "Uhhh... when you break out, follow the airliner." :-)) Musta woke the controller up from a nap? I think it certainly woke him up, but not from a nap:-)) Over the years I've had them make just about as many mistakes as I have. On one particular trip I was cleared to land at the wrong airport. So pilots aren't the only ones making that mistake. When I reminded them my flight plan called for the neighboring airport, the usual short pause was followed by a "can you make the runway from your current position?". It was visual and I could. Some one else must have called the tower as they were expecting me and I was well inside where I'd have normally switched for approach to the tower. The one approach (at the other field) handles both fields although they have separate towers. It's a good thing they cleared me for 17 instead of 23 as both airports have a 23 but where I was headed doesn't have a 17. :-)) Actually I was already suspicious as approach was almost taking me over the end of the runway I was expecting to use. Allen Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
RNAV vectors | Dan Luke | Instrument Flight Rules | 74 | December 26th 06 10:31 PM |
Vectors over water | paul kgyy | Instrument Flight Rules | 22 | May 4th 05 09:15 PM |
Lost Comms While on Vectors for traffic | O. Sami Saydjari | Instrument Flight Rules | 14 | April 26th 05 10:08 PM |
Approach to an LOM/IAF with PT (not vectors to final) | O. Sami Saydjari | Instrument Flight Rules | 35 | April 13th 04 09:54 PM |
Slam dunk into Janesville | Steven P. McNicoll | Piloting | 0 | July 31st 03 01:08 AM |
