On Feb 23, 9:40 pm, "DonMorrisey" wrote:
I am looking to get some specs, particularly dimensions of Lord Engine Mounts, J-7402-1 and J-7402-5. I checked Lord's website but unless I'm just not finding it, the info is not there and I tried calling them but haven't gotten a return call. Does anyone know where to get this info? Thanks. Don.. I thought I'd answer my own question in case anyone was looking in the future for the same information. I got a return phone call from Lord and they were very helpful. Basically all mounts of a particular designation, like a J-7402, are the same size. The dash number at the end, simply refers to a variation of the mount. For instance the J-7402-1, which you can pick up on ebay (set of four for about $85) requires that the dynafocal ring be modified with the addition of a pin and a hole so the spacer, which is shaped like a bicycle pedal, will fit properly. That must be why those are so cheap. I got the dynafocal ring at Aircraft Spruce and their website recommended the 7402-5 for the mount but according to Lord that is a very hard bubber and meant for aerobatics. He recommended a J7402-16 or J7402-24, with the -24 being a very smooth starting mount because of how the spacer is constructed. BTW I am installing a Lycoming O 235 L2C. Don. |
Lord Engine Mounts | DonMorrisey | Home Built | 2 | December 16th 06 04:05 PM |
1957: Naval Type Specification 146 | Marco P.J. Borst | Naval Aviation | 0 | May 10th 05 07:14 PM |
Mandatory ELT specification (N-reg aircraft, 1400kg) | Jürgen Exner | General Aviation | 4 | January 13th 05 10:07 PM |
Mandatory ELT specification (N-reg aircraft, 1400kg) | Jürgen Exner | Owning | 4 | January 13th 05 10:07 PM |
Searching info about headsets | Mad Mark [P.E. #65] | Home Built | 1 | July 24th 03 08:44 PM |
