kevmor wrote:
When flying a plane that doesn't have a lot of climbing power, is it quicker to get to your destination if you climb at a slower rate, but faster speed? Or is it quicker if you climb faster to your altitude? Depends on the winds at any given altitude. For example, say I took off at sea level and want to cruise at 6,500. I don't need to be that high for terrain clearance for some time. In a fixed pitch plane, I could climb at Vy to get to the altitude using full throttle, but this gives lesser engine cooling. If I climb at a speed greater than Vy, I'll need to reduce the throttle more (fixed pitch) to keep RPMs in range. When I do this, it seems like it'll take forever to get to the altitude, however. In the smaller fixed pitch AC you want to climb at full throttle. After arriving at or above pattern altitude it is normal to push the nose over a bit to increase airspeed to cruise climb. |
| Thread Tools | |
| Display Modes | |
| Step climbs | Mxsmanic | Piloting | 56 | March 2nd 07 06:17 PM |
| ASW 19b performance | Jim Crowhurst | Soaring | 1 | July 8th 05 02:31 PM |
| Complex / High Performance / Low Performance | R.T. | Owning | 22 | July 6th 04 09:04 AM |
| Climbs, Descents, and Approaches | pdxflyer | Aviation Marketplace | 0 | March 7th 04 02:37 AM |
| Climbs and Descents | pdxflyer | Piloting | 0 | March 1st 04 08:17 AM |
