GNS430W: Parallel offset course feature
Old September 9th 07, 01:11 AM posted to rec.aviation.ifr
Matt Barrow[_4_]
Default GNS430W: Parallel offset course feature
"B" wrote in message
Peter Clark wrote:
On Fri, 07 Sep 2007 08:11:19 -0700, B wrote:
It would be nice to have victor airways in the box....
All the necessary components of Victor airways are in the box. What you
want, I presume, is an airway database. I guess you have to go to a
G-1000 to get that.;-)
Airways from a GPS: That's like buying a $1000 stereo and listening to
monaural AM radio. :~(
Old September 9th 07, 12:49 PM posted to rec.aviation.ifr
Peter Clark
On Sat, 8 Sep 2007 17:11:45 -0700, "Matt Barrow"
Maybe where you're flying. In the northeast (and even entering the
northeast, pretty much from PA east from what I've seen) clearances
aren't "direct", they're KLOU IIU J78 PSB J49 ALB GDM LOBBY KBED. I'd
rather just be able to dial that into the box. Heck, even going from
BED to PWM (Hanscom to Portland, ME - 83NM leg whos only airspace
issue is the 3000' and 4000' shelf of the Boston bravo ) always gets
clearned via the PSM and ENE VORs.
Old September 9th 07, 02:27 PM posted to rec.aviation.ifr
Matt Barrow[_4_]
"Peter Clark" wrote in message
I guess all I'm essentially asking is, "Can't you just do airways on the
VOR?" like they always did?
Old September 9th 07, 04:11 PM posted to rec.aviation.ifr
Peter Clark
On Sun, 9 Sep 2007 06:27:08 -0700, "Matt Barrow"
Can't we use NDB and A-N ranges like they used to?
Sure, you can use NAV1 and fly VOR and flip-flops to identify
intersections, but when there should be a perfectly good way to do it
with the automation available there's no reason to do it the hard way.
It's a trivial amount of additional code for the 430/530 series - the
G1000 is basically a headless 430. It's Garmin's "nobody does
airways" attitude that's preventing it.
Old September 10th 07, 05:56 AM posted to rec.aviation.ifr
Matt Barrow[_4_]
Not for airways, and the topic is AIRWAYS.
Using your previous analogy, why not add ADF/DNB navigiation to GPS as well?
Sure, they're dying; so, too, will airways. Why add functionality to a GPS
that will be obsolete soon enough? Expecially when, as you put it, you can
use NAV1 and flip-flops? That's already in most GPS systems with built in
COM/NAVs.
I notice that (most? All?) the other GPS manufacturers aren't adding airways
either.
Old September 9th 07, 09:21 PM posted to rec.aviation.ifr
Mike Adams[_2_]
message ...
to monaural AM radio. :~(
I'd rather just be able to dial that into the box. Heck, even going
from BED to PWM (Hanscom to Portland, ME - 83NM leg whos only
airspace issue is the 3000' and 4000' shelf of the Boston bravo )
always gets clearned via the PSM and ENE VORs.
That's true here in the Southwest as well. With all the restricted areas, MOA's, and high MEA's, if you
want to go IFR, you're going to be on the airways.
the VOR?" like they always did?
Given that you have to fly the airway, it's much easier to call it up out of the database and have the GPS
automatically insert all the course changes and intersections. Without the database, you're forced to get
out the chart and find all the significant waypoints where a course change occurs, and put them in
manually, or else fly the VOR raw data as you said. Either one is a lot of work by comparison.
Mike
Old September 9th 07, 10:43 PM posted to rec.aviation.ifr
B[_2_]
Mike
Anyone who flies IFR without the chart out isn't in complete command of
the flight in any case
Old September 9th 07, 11:21 PM posted to rec.aviation.ifr
Mike Adams[_2_]
B wrote:
out of the database and have the GPS automatically insert all the
to get out the chart and find all the significant waypoints where a
course change occurs, and put them in manually, or else fly the VOR
Mike
of the flight in any case
I don't disagree, but it's still easier to get the route into the box if the airways are in the database, rather
than just the navaids and intersections as waypoints.
Mike
Old September 9th 07, 11:39 PM posted to rec.aviation.ifr
Roy Smith
Mike
Mike
Of course, this whole thing is complete stupidity. For the most part (at
least around here), there's just a small set of canned routes that you
always get. They should just tell you "GPS route 347", that should already
be in the Jepp database, and off you go.
Yeah, I know, it's starting to happen, but it's amazing how long it takes
for the most obvious things to get rolled out in aviation.
Old September 10th 07, 05:59 AM posted to rec.aviation.ifr
Matt Barrow[_4_]
"Mike Adams" wrote in message
message ...
I've been all over the SW with the exception of Kalifornia and I've haven't
filed an airway in a few years now.
I just put a well defined waypoint outside the MOA and go. As for high MEA's
I find it even easier going GPS than airways.
Matt Barrow
Performance Homes, LLC.
Cheyenne, WY
grover cares, then Faris publicly designates a mere parallel apart from Jeremy's riot R. Hamid Piloting 0 August 13th 07 01:19 AM
Jeppesen database subscription for Garmin GNS530W / GNS430W WAAS GPS jbskies Owning 7 February 4th 07 09:21 AM
Jeppesen database subscription for Garmin GNS530W / GNS430W WAAS GPS jbskies Instrument Flight Rules 1 January 29th 07 07:58 PM
Parallel Track function in GPS? Roy Smith Instrument Flight Rules 25 April 30th 04 12:57 AM
Engine Mount Tilt and Offset Barrie Gittens Home Built 7 April 21st 04 01:22 AM
