Out-of-calibration transponder operation
Old September 18th 07, 06:26 PM posted to rec.aviation.owning
Jim Stewart
Default Out-of-calibration transponder operation
Ray Andraka wrote:
in Class G airspace, ATC radar in most cases won't illuminate your
transponder, so it won't reply anyway, so as far as ATC is concerned it
probably doesn't matter if you have it on or not. However, TCAS
equipped aircraft will interrogate your transponder, so to be visible to
them you might want to keep it on mode3/A so that it doesn't report a
misleading altitude but does return a reply.
Well, not where I live. My airport is
under Sac Intl. class C and I'm less than
10 miles away from 2 class D airports.
Beal is about 25 miles north and class C.
The transponder lamp is blinking almost
continuously whenever the transponder is
on.
Old September 19th 07, 02:06 AM posted to rec.aviation.owning
Ray Andraka
it probably doesn't matter if you have it on or not. However, TCAS
to them you might want to keep it on mode3/A so that it doesn't report
a misleading altitude but does return a reply.
on.
OK, my bad. I was thinking of the larger areas of class G in the
mountains out west, but someone else here tells me there is radar
coverage over a significant part of that too. When I flew to Taos about
10 years back, I remember there being no radar coverage once you got
below the peaks, and I was going off that limited experience.
My point though was that if your transponder is working but not
squawking altitude correctly, leaving it on but in the Mode 3/A position
still has some benefit, even if you are outside of radar coverage.
60 Days for Calibration [email protected] Soaring 7 May 1st 06 03:00 AM
IGC badge calibration [email protected] Soaring 8 May 2nd 05 05:32 AM
EW Model D Calibration Wayne Paul Soaring 3 January 15th 05 01:06 AM
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
Volkslogger Calibration Ray Lovinggood Soaring 5 September 13th 03 04:56 PM
