http://www.airnav.com/depart?http://...5320LDA19R.PDF
Suppose I am approaching the KANAN NDB IAF from the south, maintaining 2500', which nav aid do I use to track 001 deg outbound? When I first looked at the chart I assumed it would be the CCR VOR 001 radial, but on closer examination it looks like I should be tracking from the KANAN NDB. Thanks in advance. |
On 2007-11-02, Terence Wilson wrote:
http://www.airnav.com/depart?http://...5320LDA19R.PDF Suppose I am approaching the KANAN NDB IAF from the south, maintaining 2500', which nav aid do I use to track 001 deg outbound? The localizer I-CCR on 108.5 |
![]() "Terence Wilson" wrote in message ... http://www.airnav.com/depart?http://...5320LDA19R.PDF Suppose I am approaching the KANAN NDB IAF from the south, maintaining 2500', which nav aid do I use to track 001 deg outbound? When I first looked at the chart I assumed it would be the CCR VOR 001 radial, but on closer examination it looks like I should be tracking from the KANAN NDB. I'd use the localizer. |
http://www.airnav.com/depart?http://...5320LDA19R.PDF Suppose I am approaching the KANAN NDB IAF from the south, maintaining 2500', which nav aid do I use to track 001 deg outbound? I would use the localizer, just as I would inbound to the airport. Don't forget the reverse sensing. |
![]() Use anything you want, including a ham sandwich. On Thu, 01 Nov 2007 19:35:21 -0700, Terence Wilson wrote: http://www.airnav.com/depart?http://...5320LDA19R.PDF Suppose I am approaching the KANAN NDB IAF from the south, maintaining 2500', which nav aid do I use to track 001 deg outbound? When I first looked at the chart I assumed it would be the CCR VOR 001 radial, but on closer examination it looks like I should be tracking from the KANAN NDB. Thanks in advance. |
wrote: Use anything you want, including a ham sandwich. I tried keeping one of those in my flight bag as a backup, but it got really really stinky after a few days. -- Dane |
![]() "Dane Spearing" wrote in message ... In article , wrote: Use anything you want, including a ham sandwich. I tried keeping one of those in my flight bag as a backup, but it got really really stinky after a few days. You're lucky it wasn't tuna. |
http://www.airnav.com/depart?http://...5320LDA19R.PDF Suppose I am approaching the KANAN NDB IAF from the south, maintaining 2500', which nav aid do I use to track 001 deg outbound? When I first looked at the chart I assumed it would be the CCR VOR 001 radial, but on closer examination it looks like I should be tracking from the KANAN NDB. Thanks in advance. The localizer outbound. The chart would make it clear if some other nav aid were to be used outbound. Example ILS at Knoxbille, requires VOR outbound: http://www.naco.faa.gov/d-tpp/0711/00218IL23R.PDF |
... http://www.airnav.com/depart?http://...5320LDA19R.PDF Suppose I am approaching the KANAN NDB IAF from the south, maintaining 2500', which nav aid do I use to track 001 deg outbound? When I first looked at the chart I assumed it would be the CCR VOR 001 radial, but on closer examination it looks like I should be tracking from the KANAN NDB. I would use the localizer. That said, there a couple of things that are confusing. CCR looks like it's depicted as a bit west of the localizer. I'm assuming it is to scale since it is within the plan view's circle. However, JOANS intersection is on the localizer but it is identified as being 8.1 miles on the DME from CCR. Usually when an intersection is identified using an off route VOR, there's some sort of reference line that is thinner than the route. Either the VOR *is* on the localizer or it's too close to the localizer for a separate line depiction. Marco |
Marco Leon wrote:
"Terence Wilson" wrote in message ... http://www.airnav.com/depart?http://...5320LDA19R.PDF Suppose I am approaching the KANAN NDB IAF from the south, maintaining 2500', which nav aid do I use to track 001 deg outbound? When I first looked at the chart I assumed it would be the CCR VOR 001 radial, but on closer examination it looks like I should be tracking from the KANAN NDB. I would use the localizer. That said, there a couple of things that are confusing. CCR looks like it's depicted as a bit west of the localizer. I'm assuming it is to scale since it is within the plan view's circle. However, JOANS intersection is on the localizer but it is identified as being 8.1 miles on the DME from CCR. Usually when an intersection is identified using an off route VOR, there's some sort of reference line that is thinner than the route. Either the VOR *is* on the localizer or it's too close to the localizer for a separate line depiction. Marco COLLI and REJOY via JOANS are the only authorized non-radar transitions to this AIP. From the north it is VOR to LOC, from COLLI it is NDB to KANAN. |
finding approach chart URLs | Dave Butler | Instrument Flight Rules | 10 | May 14th 07 03:19 PM |
Interpreting AC 43.13 | Michael Horowitz | Home Built | 0 | July 16th 06 12:51 PM |
peculiar approach chart | Dave Butler | Instrument Flight Rules | 11 | May 27th 06 11:42 PM |
Anyone use Air Chart? | Steven Barnes | Owning | 23 | March 25th 04 05:14 PM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
