See my other post and clue me in to why they sell 100 octane valves for
A-65s and C-85s. Are they a waste of money? Scott RST Engineering wrote: Oh, not this old wive's tale again. THERE IS NO ADDITIONAL HEAT GENERATED BY A HIGHER OCTANE FUEL. Jim -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) |
On Dec 10, 4:22 pm, Scott wrote:
See my other post and clue me in to why they sell 100 octane valves for A-65s and C-85s. Are they a waste of money? See http://www.fsv2000.at/woche/2001_10/conti_sb_m77_3.pdf for a TCM Service Bulletin about alternate valves for those engines. They say that erosion problems have been encountered with the high lead content of 100LL. It's not because the fuel burns hotter; it's a corrosion issue. If the fuel burned hotter, I would see both higher CHTs and more power out of my A-65. But I don't. You need to do some research on Octane Ratings and Detonation. Google those. Dan |
Let me reccomend a book. It's very old but packed with aero engine
knowledge. It's historically significant and a good read. Read it and you'll know more about airplane piston engines than you could imagine there was to know. "The High Speed Internal Combustion Engine" by Sir Harry Ricardo. See: http://www.ricardo.com/ricardoStore/...t.asp?P_ID=149 (1968) (In this case, "High Speed" refers to MPH and not neccessarilly RPM.) Sir Harry was a British mechanical engineer whose most significant work was between WW1 and WW2. He championed the sleeve valve engines that were developed into the Bristol Centurion but his most historic work was on the Rolls Royce Merlin. He also worked on the last generation of high power piston engines like the Napier Nomad and consulted with all the US engine manufacturers. He is a towering figure in the history of airplane piston engine development. His work with high octane fuels, supercharging and high compression ratios is has been acknowledged as a major contribution to the Allied victory in WW2. Bill Daniels |
Wing Tape - Does Thickness Affect Performance? | ContestID67 | Soaring | 87 | February 1st 07 03:24 PM |
Wing Tape - Does Thickness Affect Performance? | Charles McLaurin | Soaring | 2 | January 30th 07 06:00 PM |
Recent Political Change May Positively Affect GA | Larry Dighera | Piloting | 98 | November 13th 06 01:59 AM |
How does spar protrusion affect performance | Chris Davison | Soaring | 19 | July 13th 04 12:38 AM |
Does WiFi affect your choice of FBO? | [email protected] | General Aviation | 8 | October 16th 03 07:22 PM |
