#61
On Mon, 10 Dec 2007 20:38:01 -0800, Bob Fry
wrote: "DA" == Dale Alexander writes: DA Now, what would 22K BTU stuff do in an 7 1/2 to 1 aircraft DA engine? Probably nothing as the lower compression would limit DA the amount of work actually being done. If I can reword your statement to "what would higher octane stuff do..." then I can answer not probably, but definitely, it will not do anything different, if the only difference between the two fuels is octane. DA But it will still burn DA hotter than a fuel with a lower BTU content. Where did the difference in "BTU content" (i.e. unit chemical energy content) come from? Not from a mere octane enhancer. Perhaps the fuels used in your road racing experience had not only different octanes, but also different unit energies. Racing fuel, generally, is not even CLOSE to gasoline. It is a very complex witches brew, and generally significantly higher specific gravity, as well as higher BTU per gallon (not necessarily more BTU per lb, hence the higher SG) Eh? Where's this "extra heat" come from? There is no practical unit energy difference between different octane fuels. -- Exactly. "Octane" is, by definition, a measure of a fuel's resistance to knock under specific conditions. "High Octane" fuel does not burn any hotter, generate any more power, or improve your fuel economy (note: see exception below). Higher octane fuel lets the engine designer use a higher compression ratio, or more spark advance, etc. without triggering knock. It is the compression / spark changes that result in more power, etc. -- Posted via a free Usenet account from http://www.teranews.com |
#62
On Tue, 11 Dec 2007 16:19:46 -0500, "Morgans"
wrote: "Jim Logajan" wrote BUT - one is more likely to burn unevenly and/or more quickly (i.e. "knocking" or "pinging") which leads either to unplanned overpressures or localized hot-spots (i.e. _high heat concentrations_). So sure - no _final_ difference in released energy, but time and space concentrations can result in metal melting or breaking in one case and not the other. So, in your example, the high octane would be the cooler burning fuel, because it burns more evenly, and slowly, so it prevents knocking. High and low octane fuel burn at the same rate. Hydrogen burns much faster. Detonation involves "cracking" of the fuel, releasing unstable hydrogen radicals which explode instead of burning. Other scientific data showes that the higher octane fuel, the lower the /btu content. That's fact. Not a lot of difference, but a difference, none the less. High octane fuel does not BY DEFAULT have a lower BTU content. Straight run high octane would be as high or higher in BTUs than straight run regular. HOWEVER the additives used to increase the octane in MOST high octane pump gas today are significantly lower in BTU content than the gasoline they are added to. Look at Ethanol, as an example. E10 has 10% ethanol, and ethanol has roughly half the btu value of gasoline, so E10 has roughly 5% less BTU per gallon. It is also less dense, so the BTU per lb may not be that much lower - but we do not measure our fuel by weight. -- Posted via a free Usenet account from http://www.teranews.com |
#63
On Tue, 11 Dec 2007 23:36:24 -0000, Jim Logajan
wrote: "Morgans" wrote: "Jim Logajan" wrote BUT - one is more likely to burn unevenly and/or more quickly (i.e. "knocking" or "pinging") which leads either to unplanned overpressures or localized hot-spots (i.e. _high heat concentrations_). So sure - no _final_ difference in released energy, but time and space concentrations can result in metal melting or breaking in one case and not the other. So, in your example, the high octane would be the cooler burning fuel, because it burns more evenly, and slowly, so it prevents knocking. Except that it appears what I wrote is not correct. :-( The octane rating appears to be a measure of the activation energy of combustion, not a measure of the combustion rate. And not the activation energy of NORMAL combustion. Octane relates STRICTLY to the resistance to thermal dissassociation of the fuel in the combustion chamber. Under high heat and pressure gasoline/air mixtures can "come unglued" letting the hydrogen "flake off" so to speak. The hydrogen, which normally likes to hang around in couples (as H2) starts running around as H1- an unstable and promiscuous radical that will couple with anything available - in this case excess O2 particals - and when this happens, ALL HELL BREAKS LOOSE inside the cyl.. -- Posted via a free Usenet account from http://www.teranews.com |
#64
On Tue, 11 Dec 2007 18:08:03 -0700, "Bill Daniels"
bildan@comcast-dot-net wrote: "Jerry Wass" wrote in message .net... GeorgeB wrote: On Mon, 10 Dec 2007 09:23:52 -0800, Richard Riley wrote: If you're flying a homebuilt you can burn whatever you want - but the alcohol restriction wasn't put there at random, it increases vapor lock problems dramatically, How do the planes which do fly on ethanol handle that problem, pressurized tanks? and is incompatable with many of the materials commonly used in aircraft fuel systems. The sealant sloshed in the tanks is one, I think ... Do automobiles with flex-fuel capability do anything to minimize the vapor lock issues? I'm sure the materials were selected to be ok. Ole Jerry said: most of the automobiles in the last 20 yrs or so have the GAS PUMP inside the GAS Tank. Vapor lock is usually induced by Sucking on the fuel at some point in the fuel system. Maybe off topic but this involves fuel pumps in tanks. They fail way too often and when they do, you aren't going to fix it on the road side. After five failures at $800 a pop, I removed the pump from the tank and put an aftermarket pump in the fuel line where I can replace it with a screw driver for $50. No vapor locks yet. Strange. I have 362000km on my current vehicle (pump in tank - still original and 14 years old) and had 240,000 on each of my last two vehicles - 14 and 18 years old - all on the original in-tank pumps. I NEVER got that kind of mileage out of a mechanical pump, and frame mounted electric pumps virtually ALL rusted out in less than 10 years, requiring replacement. This is why, to a large degree, most manufacturers went to in-tank pumps a long time ago. If you don't change fuel filters, you WILL burn out pumps. If you always run on the bottom 1/4 tank you will LIKELY burn out pumps - but the top 1/4 doesn't cost any more to keep full than the bottom 1/4. -- Posted via a free Usenet account from http://www.teranews.com |
#65
Yeah, I might have gone over the top there with that comparison. But the
subsequent posts started into high octane not burning any hotter and I used the info that I was familiar with. Everybody was so damned sure that high octane didn't burn any hotter and I knew of instances where that was not true. I listed my sources with a website for the manufacturer of the fuel I was using as a reference. You could put an end to this by showing a source that definitively showed that in every instance (with regard to aviation fuel), there is no difference in heat output or flame speed between the various fuels. By the way, other than vapor pressure, do you believe that there is a difference between winter and summer blends of automotive fuels? And if you don't mind my asking, what is your training/schooling in this field? The statements I have seen attributed to you show a disciplined mind. Dale Alexander clare at snyder.on.ca wrote in message ... On Mon, 10 Dec 2007 20:38:01 -0800, Bob Fry wrote: Racing fuel, generally, is not even CLOSE to gasoline. It is a very complex witches brew, and generally significantly higher specific gravity, as well as higher BTU per gallon (not necessarily more BTU per lb, hence the higher SG) Eh? Where's this "extra heat" come from? There is no practical unit energy difference between different octane fuels. -- |
#66
OK, so us poor bastages with A-65s with no mixture control might be
screwed anyways Anybody have any ideas on how to get a mixture control onto an A-65? If I recall, my carb is an NAS3A1 Stromberg. I THINK there might be a plate on top of the carb where a mixture control may have been present at one time??? Scott Aggressive leaning at less than peak power will also help reduce this lead build-up. |
#67
"Scott" == Scott writes:
Scott OK, so us poor bastages with A-65s with no mixture control Scott might be screwed anyways Anybody have any ideas on howScott to get a mixture control onto an A-65? If I recall, my Scott carb is an NAS3A1 Stromberg. I THINK there might be a Scott plate on top of the carb where a mixture control may have Scott been present at one time??? Can't answer that question, but you might try adding TCP to your fuel to help scavenge the lead out. -- We choose our joys and sorrows long before we experience them. ~ Kahlil Gibran |
#68
I will check into that...
Bob Fry wrote: "Scott" == Scott writes: Scott OK, so us poor bastages with A-65s with no mixture control Scott might be screwed anyways Anybody have any ideas on howScott to get a mixture control onto an A-65? If I recall, my Scott carb is an NAS3A1 Stromberg. I THINK there might be a Scott plate on top of the carb where a mixture control may have Scott been present at one time??? Can't answer that question, but you might try adding TCP to your fuel to help scavenge the lead out. -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) |
#69
On Tue, 11 Dec 2007 20:18:54 -0800, "Dale Alexander"
wrote: Yeah, I might have gone over the top there with that comparison. But the subsequent posts started into high octane not burning any hotter and I used the info that I was familiar with. Everybody was so damned sure that high octane didn't burn any hotter and I knew of instances where that was not true. I listed my sources with a website for the manufacturer of the fuel I was using as a reference. You could put an end to this by showing a source that definitively showed that in every instance (with regard to aviation fuel), there is no difference in heat output or flame speed between the various fuels. By the way, other than vapor pressure, do you believe that there is a difference between winter and summer blends of automotive fuels? Definitely. In most cases the formulation is quite different. And if you don't mind my asking, what is your training/schooling in this field? The statements I have seen attributed to you show a disciplined mind. Dale Alexander I am a long time (now semi-retired) auto mechanic, former auto shop instructor at both secondary and trade level, and quite widely read on the subject. I tend to be "curious" and research things quite thoroughly when trying to get a handle on something. I am also a partner in a Pegazair project which will be flying a lightly modified Corvair engine. clare at snyder.on.ca wrote in message .. . On Mon, 10 Dec 2007 20:38:01 -0800, Bob Fry wrote: Racing fuel, generally, is not even CLOSE to gasoline. It is a very complex witches brew, and generally significantly higher specific gravity, as well as higher BTU per gallon (not necessarily more BTU per lb, hence the higher SG) Eh? Where's this "extra heat" come from? There is no practical unit energy difference between different octane fuels. -- -- Posted via a free Usenet account from http://www.teranews.com |
#70
On Dec 12, 5:03 am, Scott wrote:
OK, so us poor bastages with A-65s with no mixture control might be screwed anyways Anybody have any ideas on how to get a mixturecontrol onto an A-65? If I recall, my carb is an NAS3A1 Stromberg. I THINK there might be a plate on top of the carb where a mixture control may have been present at one time??? That's it. Finding the bits and pieces might be a hassle. I made mine, since it's a homebuilt, and it works OK. It's a back- suction type of mixture control, where the lever rotates a valve under that cover. There's a hole into the float bowl, another into the dead airspace behind the venturi, and another into the venturi itself. The area behind the venturi is at roughly atmospheric pressure, and the venturi, of course, is much lower than that. The mixture control valve, when rotated toward "Lean," gradually shuts off that port to the dead airspace, allowing the venturi port to start sucking against the fuel in the bowl. That decreases the differential pressures at the fuel nozzle and flow decreases. It won't work as an idle cutoff. There's so little flow through the venturi at idle that nothing happens when you pull the mixture all the way out. Carbs with idle cutoff are using a valve inside the carb that varies the flow of the fuel itself from the main jet in the bottom of the bowl, so that if it's pulled full lean, all flow, including idle fuel, stops. Dan |
| Thread Tools | |
| Display Modes | |
| Wing Tape - Does Thickness Affect Performance? | ContestID67 | Soaring | 87 | February 1st 07 04:24 PM |
| Wing Tape - Does Thickness Affect Performance? | Charles McLaurin | Soaring | 2 | January 30th 07 07:00 PM |
| Recent Political Change May Positively Affect GA | Larry Dighera | Piloting | 98 | November 13th 06 02:59 AM |
| How does spar protrusion affect performance | Chris Davison | Soaring | 19 | July 13th 04 01:38 AM |
| Does WiFi affect your choice of FBO? | [email protected] | General Aviation | 8 | October 16th 03 08:22 PM |
