Obstacle avoidance between take-off and airway
Old January 13th 08, 01:09 PM posted to rec.aviation.ifr
Default Obstacle avoidance between take-off and airway
On Sat, 12 Jan 2008 22:13:08 +0100, Mxsmanic
Yesterday I tried to plan a flight from Big Bear City (California) to Santa
Monica, in a Bonanza. The routing I worked out was L35..DAWNA.V8.PDZ.V186
TIFNI.ELMOO.DARTS..KSMO. DAWNA is on a portion of the airway that shows a MEA
of 10500 on the chart. Since I was westbound, I figured to climb to 12000. I
planned to depart from runway 26. My calculations showed that the Bonanza
could carry out this climb.
My question is: How do I make sure that I don't hit anything between the
runway and the first fix on my filed route? The ODP for Big Bear only gives
details for runway 8, and says "N/A" for runway 26. The only departure
procedure is an obstacle departure, also for runway 8. So what's the proper
way for me to plan a flight so that I don't run into anything between the time
I leave runway 26 and the time I reach DAWNA? Should I use a VFR sectional?
Is there something on en-route IFR charts that I'm missing? Did I overlook
something in the Instrument Procedures Handbook (it seems surprisingly vague
on this)?
I don't have the plate in front of me. Sounds like there is no ifr
procedure off runway 26, so there is no way to be sure of obstacles
without using a vfr sectional as you say. Personally I don't know of
anyone who has used a vfr sectional in ifr conditions, and I don't
think I ever would. Of course, you could fly visually if weather
permitted. Stan
Old January 14th 08, 11:33 PM posted to rec.aviation.ifr
Robert M. Gary
Monica, in a Bonanza. *The routing I worked out was L35..DAWNA.V8.PDZ.V186
TIFNI.ELMOO.DARTS..KSMO. *DAWNA is on a portion of the airway that shows a MEA
of 10500 on the chart. *Since I was westbound, I figured to climb to 12000. *I
planned to depart from runway 26. *My calculations showed that the Bonanza
My question is: *How do I make sure that I don't hit anything between the
runway and the first fix on my filed route? *The ODP for Big Bear only gives
details for runway 8, and says "N/A" for runway 26. *The only departure
procedure is an obstacle departure, also for runway 8. *So what's the proper
I leave runway 26 and the time I reach DAWNA? *Should I use a VFR sectional?
Is there something on en-route IFR charts that I'm missing? *Did I overlook
on this)?
I don't have the plate in front of me. *Sounds like there is no ifr
without using a vfr sectional as you say. *Personally I don't know of
think I ever would. *Of course, you could fly visually if weather
permitted. *Stan- Hide quoted text -
Your either joking or don't fly IFR in GA aircraft very often. There
are lots of airports where you have to define your own IFR departure
using the sectional charts. Some airports don't even show up on the
EnRoute charts.
-Robert
Old January 15th 08, 12:33 PM posted to rec.aviation.ifr
On Mon, 14 Jan 2008 15:33:25 -0800 (PST), "Robert M. Gary"
EnRoute charts.
You're partially right on the second one. I don't fly ifr GA in light
aircraft.
I didn't realize it was so prevalent, and considered a safe maneuvre.
Stan
Old January 15th 08, 06:51 PM posted to rec.aviation.ifr
Robert M. Gary
On Jan 15, 4:33*am, wrote:
You're partially right on the second one. *I don't fly ifr GA in light
aircraft.
Its probably most common when pilots are leaving their home field. My
airport does not have any IFR procedures at all. When I depart IFR I
only have to consider if I believe I can be VMC before I enter class
E. If I don't think the clouds are that high I don't need any
clearance at all, just throttle up and launch.
-Robert
Old February 1st 08, 04:53 PM posted to rec.aviation.ifr
[...]Personally I don't know of
think I ever would.
I use sectionals all the time in IFR flight, especially when planning
departures from mountainous airports. I used to fly a King Air (part
135), and carried WAC charts so I would know where the low
terrain was.
Looking at the sectional, a runway 26 departure from Big Bear seems
pretty hairy in a Bonanza.
Final Glide Calculation over Obstacle [email protected] Soaring 3 February 7th 07 04:49 PM
How to adhere to this obstacle departure procedure? Peter R. Instrument Flight Rules 38 April 25th 05 09:00 PM
Garmin 196 & obstacle database. max Instrument Flight Rules 11 March 16th 05 08:51 AM
Obstacle Clearance Altitude / Height Tim Instrument Flight Rules 2 November 21st 04 10:33 AM
Notes on NACO Obstacle Departure Procedures John Clonts Instrument Flight Rules 1 July 15th 04 10:20 PM
