another gelcoat story
Old August 27th 08, 09:31 PM posted to rec.aviation.soaring
RL
Default another gelcoat story
Do the factories offering polyurethane paint as an option to gel coat
still use a thin layer gel coat? How much does that method extend the
life of the gel coat?
Yes, it is necessary to use gel coat or an in-mold primer gel coat. As
Hank mentioned it is not practical to laminate directly on the mold
surface. The laminate will be full of pinholes and require extensive
post-mold priming and sanding before a finish coating can be applied.
Now here's a catch 22 - It is not feasible to apply a "thin" layer of
polyester gel coat. The normally recommended wet film thickness ranges
from a low of 14 mils (mil =.001") to 18+ mils. With anything thinner
than 14 mils the proportional amount of styrene lost through
evaporation becomes so high that there is not enough styrene left for
complete crosslinking. Bottomline - overly thin gel coat will be
permanently under-cured regardless of catalyst level or curing
temperature.
A linear urethane topcoat will extend the life of a well applied gel
coat substrate condsiderably.
Bob
Old August 27th 08, 09:38 PM posted to rec.aviation.soaring
Craig[_2_]
temperature.
Bob
http://www.dg-flugzeugbau.de/gelcoat-e.html
http://www.dg-flugzeugbau.de/pur-lack-e.html
Old August 27th 08, 09:43 PM posted to rec.aviation.soaring
Brad[_2_]
temperature.
Bob,
You just solved my gelcoat problem. The layer was to thin. In the
areas where it was thicker, I had to use a DA to get it off,
everywhere else, it flaked off with the sandpaper or by sliding a
putty knife under the paint and removing "leaves" of it.
I have had ISP problems the last several days, hence my dissapearance
on this thread!
Will give you a call tonight Bob.
Brad
Old August 28th 08, 12:33 AM posted to rec.aviation.soaring
John Scott[_2_]
I believe AMS-Fligth in Slovenia is building gliders with only PU. They
have developed a method for spraying the PU in the mold prior to layup so
that the pieces comeout with a PU finish. This is the way my APIS was
built. The finish is all PU, no gelcoat that I am aware of.
http://www.ams-flight.si/ abour 1/3 of the way down the
page "AMS Sets The Standard In Glider Finishes".
John Scott
Old August 28th 08, 01:26 AM posted to rec.aviation.soaring
Brad[_2_]
On Aug 27, 4:33*pm, "John Scott" wrote:
I believe AMS-Fligth in Slovenia is building gliders with only PU. *They
that the pieces comeout with a PU finish. *This is the way my APIS was
built. *The finish is all PU, no gelcoat that I am aware of.
* * * * * *http://www.ams-flight.si/* * * *abour 1/3 of the way down the
John Scott
My Apis was built by Albastar, not sure what they used as a mold coat.
Whatever it was, it was really thin, and I used it as a primer coat
for Prestec 2781.
Brad
Grob gelcoat Gary Emerson Soaring 1 December 19th 07 05:55 AM
Gelcoat sag? [email protected] Soaring 10 December 17th 07 08:07 PM
First Glider no gelcoat Doug Reeve Soaring 0 February 10th 06 10:05 AM
Ferro gelcoat Basil Fairston Soaring 0 December 16th 03 08:34 AM
Refinishing gelcoat tango4 Soaring 21 November 3rd 03 07:29 AM
