Approach Question
Old August 26th 08, 02:14 PM posted to rec.aviation.ifr
Sam Spade
Default Approach Question
David Kazdan wrote:
And perhaps they were drinking "decent" wines while preparing the chart,
rather than worrying about "descent" angles.
David
Old August 26th 08, 07:12 PM posted to rec.aviation.ifr
Gino Marchetti
Sam Spade wrote in
chart, rather than worrying about "descent" angles.
David
"VGSI and decent angles not coincident" had spelling error on the chart.
Old August 27th 08, 05:56 AM posted to rec.aviation.ifr
Sam Spade
Gino Marchetti wrote:
Sam Spade wrote in
David
Maaybe they have very loose morals?
Old August 29th 08, 03:31 AM
J. Baker J. Baker is offline
Junior Member
First recorded activity by AviationBanter: Aug 2008
If you don't mind my taking a stab at this. I've been working as a Terminal Procedures Specialist, contractor, for the FAA for the last couple of years. While not an expert, or even close, I may have some insights that others may not.
Quote:
Originally Posted by Thomas Borchert View Post
Vor-Dme,
If so, have a look at this one :
http://204.108.4.16/d-tpp/0808/00382G22.PDF
GPS22, KSCH. I believe there is an error in the hold in lieu of PT, which
cannot be both "1-min" AND "4NM, but perhaps there is a good reason why
it is charted this way.
Notice that this is a GPS and not an RNAV (GPS) procedure. In the early days of building these procedures rules and criteria were, well, mixed. You'd see VOR or GPS approaches, GPS overlays of existing approaches, etc. The criteria now is miles only for RNAV procedures.
My real question though concerns the IAF waypoints. Why are OTOLE and
GALWA charted as fixes or reporting points, and not as GPS waypoints? [/i][/color]
The way a fix is charted depends upon it's make up. These were probably existing fixes made up of ground based navaid radials/bearings/courses. A fix will only be charted as a WP if the procedure is an RNAV type. As I mentioned before, this is a mix and match procedure build.
If
entering using OTOLE as IAF, is one required to fly the hold in lieu of?[/i][/color]
Yes. The HIL is required whenever thre is no specific NoPT directive. OTOLE is on a NNW -SSE airway. Since there isn't a proper INTERMEDIATE you must fly the HIL where, upon turning to the inbound course toward OTOLE, that is considered the IF, thence to the FAF. We don't do this anymore.
Yup...a typo. Our QA has gotten a lot better as has the automation in procedure production. Over four sets of eyes look at each procedure before it ever gets to flight check.
The Jeppesen chart shows OTOLE as a flyby waypoint and GALWA as a
flyover waypoint. Thus, more NACO charting issues
Not so. Jeppesen has their own set of rules. GALWA is a FO fix. You must fly over it to hold else the obstacle evaluation area would mean nothing. OTOLE is a FO fix as well but since it's on an airway and existed prior to GPS inception, it gets charted as a fix. Take alook at AIRNAV and the AIRSPACE FIXES section...has all the fix make-up data there.
Jim Baker
Old August 29th 08, 03:19 PM posted to rec.aviation.ifr
Sam Spade
Jeppesen may have its own set of rules, so to speak, but since they
distribute the RNAV database, their view is the one that counts.
Every one of those "fixes" is flown as a waypoint by anyone using a 129
or 245/146 navigator.
Nearly every missed approach waypoint charted is a FO waypoint. This
one is a very early design and is non-compliant because the HIL is at
the FAF. It should have been redesigned years ago, but you know that
biannual reviews are a farce.
Thomas Borchert;655278 Wrote:
Vor-Dme,
which
why
it is charted this way. -
If
of?
anymore.
chart.
there.
[/i][/color]
Jim Baker
[/i][/color]
Old August 29th 08, 05:26 PM posted to rec.aviation.ifr
Sam Spade
I meant to say missed approach holding waypomt. The MAP itself is a FO.
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 03:54 AM
Another approach question Andrew Sarangan Instrument Flight Rules 5 November 7th 04 05:44 PM
GPS approach question Matt Whiting Instrument Flight Rules 8 November 1st 04 10:51 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
where to ask question about approach? J Haggerty Instrument Flight Rules 1 August 17th 04 06:30 AM
