Been flying my canard for a few years now - it has a Franklin 6-350
engine and LSE dual ignition. I often noticed a slightly extra engine vibs in the 2500-2700RPM range (maybe its my imagination) and I used to fly it 2400rpm or less. All this time I had the ignition advanced probably an extra 5 degrees to get a little more power. Recently I changed the plugs on it and at same retarded the ignition to standard recommended TDC setting. Now it seems the engine is more uniformly smooth in the whole range. Did two test flights. Can extra advance add to engine vibs? Any A&Ps out there? ----------------------------------------------------------- SQ2000 Canard http://www.abri.com/sq2000 |
The good thing from advanced timing is detonation which hammers those
nasty lead deposits out of there, along with the top of the piston.. denny |
On Wed, 17 Sep 2008 21:59:59 -0700 (PDT), abripl
wrote: Been flying my canard for a few years now - it has a Franklin 6-350 engine and LSE dual ignition. I often noticed a slightly extra engine vibs in the 2500-2700RPM range (maybe its my imagination) and I used to fly it 2400rpm or less. All this time I had the ignition advanced probably an extra 5 degrees to get a little more power. Recently I changed the plugs on it and at same retarded the ignition to standard recommended TDC setting. Now it seems the engine is more uniformly smooth in the whole range. Did two test flights. Can extra advance add to engine vibs? Any A&Ps out there? ----------------------------------------------------------- SQ2000 Canard http://www.abri.com/sq2000 ************************************************** ************************** Don't know how old this posting is, but with ur spark advanced, you might be getting detonation???? WAG Big John |
Sustainer engine ignition noise (Solo2350) | Per | Soaring | 8 | January 4th 07 05:56 AM |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Wierd vibration -- Prop or engine, balance or not??? | Chuck | Owning | 17 | December 1st 04 02:12 PM |
Vibration Testing | Jim Weir | Home Built | 20 | October 10th 04 07:22 AM |
Vibration is Citabria | TIm Gilbert | Owning | 8 | December 14th 03 03:34 PM |
